Reg Plate Meltage
EuropeanNC30R...
Gay Hairdresser
PostPosted: 13:58 - 27 Dec 2003    Post subject: Reg Plate Meltage Reply with quote
A short while ago I fitted a gorgeous Scorpion can to my VFR, sounds very nice Smile. On Wednesday I finally got to take it out for a quick run, when I got back I noticed the registration plate had took a bit of a hammering Laughing
https://www.mauriceb.btinternet.co.uk/bike/nc30/plateback.jpg
And that ^ was about 3 hours max riding.
I'm just wondering what i'm going to do with it. I could get a small plate, but then there's the risk of police attention/aggro off my dad. Or I was thinking of maybe fitting some kind of heat shield to the back of the plate, but then what material could I use? Any opinions/suggestions welcome.
Milo
PostPosted: 14:25 - 27 Dec 2003    Post subject: Reply with quote
It looks quite close to the plate so surely that would also be dodgyifying the airflow out of the exhaust causing a drop in power?
I'd probably offset the plate or maybe try to change the angle of the plate.
Maybe get some thin sheet of metal the size of the plate and mount it behind...or tin foil and glue if you're feeling cheap and lazy Smile
Shaft drives rule. Razz
chunkielad
PostPosted: 22:43 - 27 Dec 2003    Post subject: Reply with quote
You may be able to bent the exhaust bracket slightly to get the exhaust to stick out further or even add a few washers then a cheap metal plate over the back and it'll be alreet!!!
Mark Harrison R.I.P - 26th March 2003.
Remember you always and will ride in your honour.
Big revvs up for Mark!
EuropeanNC30R...
Gay Hairdresser
PostPosted: 02:04 - 28 Dec 2003    Post subject: Reply with quote
The can isn't that close to the plate, it's the angle of the photo that suggests that. A cheap metal plate sounds the ideal job, i'll look into it. Maybe I should get some sheets of sticky carbon fibre for the 'trick' look. Smile
PsychoHippy
Jammy Git
PostPosted: 02:06 - 28 Dec 2003    Post subject: Reply with quote
I'd just glue some baking foil to it Very Happy
I spend all my money on bikes and beer, the rest I simply waste!
EuropeanNC30R...
Gay Hairdresser
PostPosted: 02:09 - 28 Dec 2003    Post subject: Reply with quote
Laughing I might do that for the time being, the front went a bit greener today.
Kickstart@Work
PostPosted: 00:20 - 29 Dec 2003    Post subject: Reply with quote
You can get self adhesive heat protective tape. Certainly places like Demon Tweeks sell it, but there must be cheaper places.
Atheism is a not for prophet organisation
EuropeanNC30R...
Gay Hairdresser
PostPosted: 01:40 - 29 Dec 2003    Post subject: Reply with quote
Earlier on today I partly sorted it by re-arranging the exhaust bracket so it was a bit further out, and then sticking turkey foil on the rear of the plate. Smile I'll see how it goes, it should be alright now, will try the tape if it's not.
The last post was made 22 years, 261 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 54.8 Kb
