Urgent Help Required
MIKEY B
PostPosted: 17:11 - 29 Dec 2003    Post subject: Urgent Help Required Reply with quote
Hello Guys and Gals,
Just a quickie.........I have mislaid the Keys to the Bandit and unfortunately I did not get a spare when I bought it. Now getting a spare cut is on my to do list, but I had not got round to doing it.
They will probably pop up sooner or later but is it possible to get a key cut without actually having the key??? This may (probably is Mike!!!) be a stupid question but the Bike is due in for its MOT soon.
I was going to get a new ignition fitted at some point anyway but the key wont fit the Seat lock will it???
Heeeeeeelllllppppp.
Mike.
GSXR 1000 K3 "Silver Bullet"
Yamaha XS 650 Hardtail bobber
Cheza
PostPosted: 17:13 - 29 Dec 2003    Post subject: Reply with quote
You should be able to order one from a dealer with the chassis number i think. Might cost you though!
Pink Rhino Rider Wink
Demonic69
The Pink Rhino
PostPosted: 17:16 - 29 Dec 2003    Post subject: Reply with quote
You can buy an entire new set of lock for the bandit mate. That's probably the only way forward
Back on a Blade. Just feels so right.
MIKEY B
PostPosted: 17:22 - 29 Dec 2003    Post subject: Reply with quote
Well I was going to get a new ignition as mentioned above, because the one on there at the moment is a bit naff.
Any ideas how much it would set you back for a new one?
Mike.
Demonic69
The Pink Rhino
PostPosted: 17:23 - 29 Dec 2003    Post subject: Reply with quote
I paid £35 I think for the set, including ignition, fuel cap and seat lock
MIKEY B
PostPosted: 17:26 - 29 Dec 2003    Post subject: Reply with quote
Thats pretty cheap, Where was that from and did you fit them yourself? or did you get the place you got them from to fit them?
Mike.
Demonic69
The Pink Rhino
PostPosted: 17:30 - 29 Dec 2003    Post subject: Reply with quote
That was from a local shop. You should be able to get them from any local place.
I fit them myself, was only a few bolts/screws
Dusty
King of the Rim
PostPosted: 17:31 - 29 Dec 2003    Post subject: Reply with quote
As far as I know it'll probably be a fair bit cheaper to get a new ignition than to get a key from the manufacturer, they tend to charge ridiculous prices because they can.
The only drawback as you say, is that it's unlikely to fit your rear seat lock, although I would assume the seat lock is not as sophisticated as the ignition? You might be lucky. I used to be able to take my DT's seat off with a screwdriver. Confused
Gallery
MIKEY B
PostPosted: 17:37 - 29 Dec 2003    Post subject: Reply with quote
Thanks for the help guys, I shall bare all in mind when I am tearing my flat apart for the 20th time tonight making sure I am not blind.
Mike.
TiN
Pocket Tin
PostPosted: 19:33 - 29 Dec 2003    Post subject: Reply with quote
I dunno if Suzukis are the same, but the key number was stamped on the ignition barrel on my Blade. You'd have to remove the ignition barrel, and it should be stamped near the steering lock pin (if there is a number).
It's about £12.50 for a set of 2 keys, and it's a lot less hassle than getting a new set of locks. Failing that, you might be able to get a key cut from the ignition barrel itself.
TiN
dotgems.net
The last post was made 22 years, 260 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 62.38 Kb
