master cyclinders, and getting the right one
pocket_Rocket
PostPosted: 17:59 - 06 Jan 2008    Post subject: master cyclinders, and getting the right one Reply with quote
im looking to get a new master cyclinder for my bike. its a zx6r j1. was wondering which one to go for, as i have read that getting the wrong one will leave my brakes like a all or nothing switch. could anyone point me in the right direction to which piston size to buy and which master cyclinder.
thanks
PostPosted: 18:22 - 06 Jan 2008    Post subject: Re: master cyclinders, and getting the right one Reply with quote
thanks
Why not just use a ZX6R J1 master cylinder? Or am I being thick?
pocket_Rocket
PostPosted: 18:27 - 06 Jan 2008    Post subject: Reply with quote
lol. sorry maybe im not being clear, i want to upgrade to a better master cylinder, with more braking power and that looks good.
hmmmnz
PostPosted: 18:43 - 06 Jan 2008    Post subject: Reply with quote
you already have 6 pot brakes, so i would be looking for the biggest master cylinder you can find,
or get a radial brembo one
or https://cgi.ebay.co.uk/KAWASAKI-ZX-10-R-RADIAL-MASTER-CYLINDER-ZX-10R-ZX10R_W0QQitemZ160195228287QQihZ006QQcategoryZ10464QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
some thing along those lines should be sweet Very Happy
the humans are dead
I kick arse for the lord
pocket_Rocket
PostPosted: 18:49 - 06 Jan 2008    Post subject: Reply with quote
would i need a radial conversion kit if i got a brembo one? and would i need a brake light lead or something? also how hard would it be to fit?
thanks
PostPosted: 18:54 - 06 Jan 2008    Post subject: Reply with quote
I'd be wary of buying a radial master cylinder for 6-pot brakes. In my research I found that generally they will have too small a piston.
pocket_Rocket
PostPosted: 18:58 - 06 Jan 2008    Post subject: Reply with quote
so what would your recommend buying because at the moment my brakes are good but they have to be fully adjusted out to work well. they just don't push enough fluid
thanks
craigs23
Mr Muscle
PostPosted: 19:01 - 06 Jan 2008    Post subject: Reply with quote
A refurb.
When was the last time you checked/bled them?
pocket_Rocket
PostPosted: 19:04 - 06 Jan 2008    Post subject: Reply with quote
bled them when i put braided hoses on them, they aren't bad but you do have to pull the lever in far and on the furthest out setting.
craigs23
Mr Muscle
PostPosted: 19:05 - 06 Jan 2008    Post subject: Reply with quote
Sure you've bled them out properly? I wouldn't expect that from a standard setup in good working order, more or less one fitted with braided lines. Will certainly be my first port of call before considering an aftermarket item.
pocket_Rocket
PostPosted: 19:09 - 06 Jan 2008    Post subject: Reply with quote
im sure i did bled them well maybe a master cylinder rebuild would help, but as it is my b day soon i thought i would just get a swanky master cylinder Laughing
PostPosted: 19:16 - 06 Jan 2008    Post subject: Reply with quote
I fitted a Performance Technology master cylinder on my 'busa, big improvement. Got it from BigCC. You have to get a reservoir to go with it (I used a VFR400 one). You also have to buy a fine-thread banjo-bolt with integral switch for the brake light.
pocket_Rocket
PostPosted: 19:39 - 06 Jan 2008    Post subject: Reply with quote
nice one, that looks good, where do i get a fine-thread banjo-bolt with integral switch from and wont the standard reservoir be fine?
also how hard is it to wire up the brake light?
thanks
PostPosted: 19:46 - 06 Jan 2008    Post subject: Reply with quote
Well the 'busa has a built-in reservoir so I had to find another, if your bike has a seaparate res then you can use that no problem.
The bolts you can get from BigCC too, or from most places just tell them if you got 1 or 2 pipes going to it (and make sure you get the fine thread). The wiring is simple, all you do is take the 2 wires from your current brake light switch, to the 2 connectors on the new one.
pocket_Rocket
PostPosted: 20:10 - 06 Jan 2008    Post subject: Reply with quote
just making sure but my braided lines will fit on ? Confused
PostPosted: 21:12 - 06 Jan 2008    Post subject: Reply with quote
Depends on the exact mounting but probably.
If you are worried about the stroke then get one of the adjustable ratio master cylinders. Not cheap though.
Suspect the real problem is some air stuck in the system though (assuming the calipers are in decent condition, quite possibly a silly assumption with those quick seize 6 pots).
Big Pete
PostPosted: 16:41 - 07 Jan 2008    Post subject: Reply with quote
prolly worth stripping and cleaning the calipers as well, after a while the gunge build up can tighten up the seals, sometimes the pistons drag, other times they tend to stick in, which will give the symptoms you describe.
Trust me, I`m an engineer
GarageOfPower.co.uk
McJamweasel
BCF Junkie
PostPosted: 20:26 - 07 Jan 2008    Post subject: Reply with quote
As per the other comments, you need to strip and clean the calipers, possibly replace the seals as well. Those 6 pots are well known for seizing and as Big Pete says that causes the symptoms that you describe.
pocket_Rocket
PostPosted: 20:37 - 07 Jan 2008    Post subject: Reply with quote
i will do this anyway as this is the second zx6r j1 i have had, i had to do this on the last bike, all the pistons totally seized up. will order a set of piston seals and do that when i can but they were changed when i bought the bike about 7 months ago Confused
McJamweasel
BCF Junkie
PostPosted: 20:46 - 07 Jan 2008    Post subject: Reply with quote
If they are not very old then the pistons might just need cleaning/greasing. I'd try that before ordering seals - always try the cheap bits first!
The last post was made 18 years, 173 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 3.47 - MySQL Queries: 13 - Page Size: 109.51 Kb
