| pocket_Rocket |
 pocket_Rocket Scooby Slapper
| MarJay |
 MarJay But it's British!
| pocket_Rocket |
| hmmmnz |
 hmmmnz Super Spammer
 Posted: 18:43 - 06 Jan 2008 Post subject: |
| pocket_Rocket |
| Pete. |
 Pete. Super Spammer
 Posted: 18:54 - 06 Jan 2008 Post subject: |
I'd be wary of buying a radial master cylinder for 6-pot brakes. In my research I found that generally they will have too small a piston. ____________________ a.k.a 'Geri'
| pocket_Rocket |
| craigs23 |
 craigs23 Mr Muscle
| pocket_Rocket |
| craigs23 |
 craigs23 Mr Muscle
| pocket_Rocket |
 Posted: 19:09 - 06 Jan 2008 Post subject: |
im sure i did bled them well maybe a master cylinder rebuild would help, but as it is my b day soon i thought i would just get a swanky master cylinder  |
| Pete. |
 Pete. Super Spammer
 Posted: 19:16 - 06 Jan 2008 Post subject: |
I fitted a Performance Technology master cylinder on my 'busa, big improvement. Got it from BigCC. You have to get a reservoir to go with it (I used a VFR400 one). You also have to buy a fine-thread banjo-bolt with integral switch for the brake light. ____________________ a.k.a 'Geri'
| pocket_Rocket |
| Pete. |
 Pete. Super Spammer
 Posted: 19:46 - 06 Jan 2008 Post subject: |
Well the 'busa has a built-in reservoir so I had to find another, if your bike has a seaparate res then you can use that no problem.
The bolts you can get from BigCC too, or from most places just tell them if you got 1 or 2 pipes going to it (and make sure you get the fine thread). The wiring is simple, all you do is take the 2 wires from your current brake light switch, to the 2 connectors on the new one. ____________________ a.k.a 'Geri'
| pocket_Rocket |
 Posted: 20:10 - 06 Jan 2008 Post subject: |
just making sure but my braided lines will fit on ?  |
| Kickstart |
 Kickstart The Oracle
| Big Pete |
 Big Pete Spanner Monkey
| McJamweasel |
 McJamweasel BCF Junkie
| pocket_Rocket |
 Posted: 20:37 - 07 Jan 2008 Post subject: |
i will do this anyway as this is the second zx6r j1 i have had, i had to do this on the last bike, all the pistons totally seized up. will order a set of piston seals and do that when i can but they were changed when i bought the bike about 7 months ago  |
| McJamweasel |
The last post was made 18 years, 176 days ago. Instead of replying here, would creating a new thread be more useful? |
