Anyone working on their bikes?
stevo as b4
PostPosted: 22:21 - 30 Dec 2003    Post subject: Anyone working on their bikes? Reply with quote
Just wondered if anyone has been doing any bike maintainance, or working on a project etc, during the Holidays (for some). i'm off this week, so after spending boxing day and 2ltrs of Gunk, to try and get my KMX200 reasonably clean again, i decided to get it sorted today. i've give it a general service, and fixed a few faults, such as front brakelight switch, and loose chain, and removed the cracked chain guard. It runs again now and looks a bit cleaner, so i took it out for a ride in the cold.
I hate knobbly tires, feels like the front wheel is square, and also i need to have a look at the carb, as the motor keeps revving to around 3k in traffic, and adjusting the tickover doesn't help. If i can get some better tyres for road, instead of the serious MX hoops its currently wearing, i might ride it a bit until April when the Tax and MOT are up. The only other real problem is the noisy exhaust, not yet sure if theres a hole in the pipe, or its just the dented and rusty silencer causing the racket. i've been up to 65mph on it, and even tho the motor seems to run ok, and take off at 6k, it still rattles, and the clutch is very grabby. Hoping by easter that ill have the money for a full re-build, with new plastics, powdercoated frame, and a full motor re-build for peace of mind! But its going to cost me more than i thought, as just a set of SM wheels built to my OE hubs will be over £400! i'm justifying it all with the idea that i couldn't get a new DT125 for less than £2K, and of course my KMX S'motard will be far better than that i hope!
EuropeanNC30R...
Gay Hairdresser
PostPosted: 22:27 - 30 Dec 2003    Post subject: Reply with quote
I've just finished fitting heated grips, topped up the oil, oiled chain and bolted on a non-burnt number plate.
The heated grips, advertised as being ridiculously easy to fit, were about as far opposite from that as you could get! I spent over an hour sanding down the left clip-on so I could get it on, then had to cut off some rubber from the end of the right grip so the throttle wouldn't stick.
Shame no-one's gonna be able to see the left clip-on, it'd have come up nicely with some autosol Smile
PostPosted: 22:29 - 30 Dec 2003    Post subject: Reply with quote
I've been fitting a mountain bike speedo, which appears to work but will probably fall off when I test what speed it will read up to (on a private road of course Wink )
Also been glueing the swingarm back together so as I can fit a hugger Smile
Scotty
Scooter Boi
PostPosted: 22:34 - 30 Dec 2003    Post subject: Reply with quote
Bikes been a bit of a slow on gonig project since i binned it, (back in Feb i think it was)
Since then in the last few months i've generally got the fairing done, decals, wheels, rebuilds and other maitence.
Also been stocking up on parts i'll need for the future.
Such as tires, chains and sprokets (Thx Danny). A few cables,
oils some grips and a few other bits and bobs.
Regards
Scott
Sparks!
Sir Tart-a-lot
PostPosted: 22:38 - 30 Dec 2003    Post subject: Reply with quote
maintenance? in the lovely cold icy garage?
Sure...
PostPosted: 22:41 - 30 Dec 2003    Post subject: Reply with quote
You got the hacksaw there... so what wasn't co-operating? Laughing
Phoenix
Twisted Firestarter
PostPosted: 23:00 - 30 Dec 2003    Post subject: Reply with quote
A rusty fuckin bolt holding the CDI in place across the battery, it didn't get beheaded in the end.
cagiva gezzer
PostPosted: 23:14 - 30 Dec 2003    Post subject: Reply with quote
I was planning on putting my supercity back together over christmas, but i forgot to bring my tools back from uni, so ive only been able to prep the piston and paint the cylinder.....
I'm not normally that stupid! Rolling Eyes
Sparks!
Sir Tart-a-lot
PostPosted: 23:16 - 30 Dec 2003    Post subject: Reply with quote
as Alex says...
but we didn't cut it off in the end, we just bent in back and forced the battery out.
Theres also some garden prune things on the seat which I was going to use to just cut the plastic battery cover off with Razz
stevo as b4
PostPosted: 23:31 - 30 Dec 2003    Post subject: Reply with quote
I take it that someone may be fitting an undertray to their Kwak?
Erm i have plenty to do on my ZX6 when it gets a bit warmer. First job will be getting a set of Pirelli Diablos fitted, and my braided lines. Ive also got an ignition advancer to fit, and at some point next year id like to give it the K&N+Jetkit+Ti can with one of them fasionable removable baffle things! BSD said id get around 2-4bhp across the range, even with the DB killer thing, and maybe one or two more without! Most important mod tho will be the black screen (Stealth look) lol!
Also been dreaming of my future next bike, while reading my bike mags in the warm! Me thinks a tricked up CB1300 will do very nicely!
PostPosted: 23:32 - 30 Dec 2003    Post subject: Reply with quote
Sometime over the next month or two I will be:
KR1S;
Fitting new clutch springs and a sump cover (well crank cover style thing that holds the sump bolt).
NSR;
Fitting new rear suspension unit and seeing about getting the forks straightened as well as a few other bits for the MOT.
ZX9R;
Dropping the sump so I can have a look at the gears, to make sure that is the problem, before I pay somewhere to take it apart.
RD350;
Poking at the carbs to find out why it sometimes doesn't like running with the clutch in when staionary in gear.
Replacing the head bearings and a few other bits in the hope of blagging an MOT Smile.
Polini 910;
Finding (the new one) and replacing the rear axle.
Of those, the KR1S is likely to get sorted. Hopefully I'll get one or two bits on the others done, wouldn't be too hopefull though Confused.
Danny
Ask Me About Stoppie School
PostPosted: 23:44 - 30 Dec 2003    Post subject: Reply with quote
I've been doing some fixing/maintainance of my bike over the last few days (thanks to all those that helped Smile Karma ).
Today (well about an hour ago) new spark plugs, ht leads have been messed with and loose luggage rack removed.
On the weekend, front wheel bearings replaced, carbs removed twice (much swearing involved Evil or Very Mad ), zaust now not leaking like a Russian dam and a few others minor things sorted.
Sparks!
Sir Tart-a-lot
PostPosted: 23:47 - 30 Dec 2003    Post subject: Reply with quote
Not sure if you mean me or not? But the pic is of my ZXR400 Kwak
Not doing nice things like under trays i'm afraid Crying or Very sad
Have stripped it off to replace fuel filter , fuel pump, carb slides, fuel tap , check all hoses, optimate the battery,check main jets, check needle size and slide diaphrams (which i think i'm now replacing) and i had to replace my headlight bulbs which was a pain in the arse cos i kept taking the dead bulb out, forgetting, then putting it back in and wondering why it don't work... Laughing
next week it'll be rear brake pads and it's MOT time...
i take the rear seat unit off cos its easier access to everything and less chance of damaging the seat, it only took an extra minute to take off and could save it if i was to break it in anyway.
PostPosted: 23:53 - 30 Dec 2003    Post subject: Reply with quote
Was reading on MCN Ninjas that the K&N air filters are not as good as the OE ones for airflow. However you have to clean and tinker with the standard ones more often than a K&N which is quoted as being able to not need replacing for upto 50,000 miles!
And for "stealth" look, ie, not standing out you want to keep your bike OE, no aftermarket mods which would make it standout. Plain black kit with a blacked out visor as well for the best stealthness Smile
PostPosted: 00:19 - 31 Dec 2003    Post subject: Reply with quote
Well, the Bandit should be getting stripped down to a bare frame again to get it powder coated again. Had it done just over a year ago and the clear coat is cracking up (it is a silver colour, with a clear coat of laquer on top), so they have said they will do it again.
Ant
PostPosted: 00:35 - 31 Dec 2003    Post subject: Reply with quote
I intend to de-rust and re paint the rear part of my frame!
Weather i get round to it or not is a different matter tho! but for sure ill grease my chain! Laughing
04 ZX10R ~
PostPosted: 00:43 - 31 Dec 2003    Post subject: Reply with quote
From experience, cleaning it up and painting it yourself is not worth it for cosmetic reasons. Worth doing to stop corrosion but the results are likely to look worse. Think on your CBR those bits are hidden so it should be easy to do, but if they are visable then strip the bike down and get the frame powder coated.
MIKEY B
PostPosted: 10:05 - 31 Dec 2003    Post subject: Reply with quote
Well my 600 Bandit has been an ongoing project for the last year.
I bought it before I got my liscence and now that I have it and the bike is still not finished I am getting really aggrivated!!
The main problem I have is that the bike is stored in South East London at my mums house. And I live in Greenhithe in Kent so I only get to work on it on Saturday's.
But it is almost there, just need to get a new set of keys cut and I can get it Mot'd.
I will be (over the next month) removing a snapped bolt out of the Clutch case, Removing the swingarm and giving it a proper good clean and polish, might get the wheels polished or painted (not sure what yet) or maybe both!! And then taking it for a right good thrashing. (Not before I get breakdown recovery though!!!! Very Happy )
Mike.
GSXR 1000 K3 "Silver Bullet"
Yamaha XS 650 Hardtail bobber
The last post was made 22 years, 253 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.44 - MySQL Queries: 13 - Page Size: 103.19 Kb
