Chemical Metals ( hole in rad )
Wave2k
G's Stalker
PostPosted: 13:40 - 10 Jan 2008    Post subject: Chemical Metals ( hole in rad ) Reply with quote
My new radiator came today, but its the wrong bloody one, so im gonna have to use some kinda chemical metal for now.
Can i get something like Araldite from Halfords, where do i need to go to get this ?
Ducati 1299 Panigale
2009 Corvette C6 z51
Robby
Dirty Old Man
PostPosted: 13:50 - 10 Jan 2008    Post subject: Reply with quote
Halfords does sell araldite and chemical metal.
I'll start the classic disclaimer that if this sort of bodge fails you might kill your motor.
Take the rad off the bike, and get it properly dry- a few hours an airing cupboard or on top of a rad might do this.
I presume you're dealing with a hole made by a stone. Clean out the broken rad pipes with a cotton bud, make up some chemical metal, and plug the hole with it.
Let it dry for a good while before using it- water and slightly cured epoxy don't mix well. It should cure quicker if you put it somewhere warm.
Pop the rad back on the bike, refill with coolant, a warm the bike up to operating temp, turn off, top up with coolant, pop the rad cap back on and run it for a few minutes to see if the pressure pushes out the epoxy plugs.
If it holds, use it until your new rad turns up. Chemical metal is good stuff, and although its not adviseable to ride with a bodge like this plce, it might work quite well.
I wouldn't go for any radweld or similar - you don't want to be chucking crap into your cooling system, and it only really works on pinprick holes.
Wave2k
G's Stalker
PostPosted: 14:06 - 10 Jan 2008    Post subject: Reply with quote
Its basically a temp fix so i can go out on sunday, the rad is already off the bike as im waiting for a new one.
ill pop it in the airing cupboard now and pop to Halfrauds.
curryfishball
i used araldite on the track. and it took 30 minutes to fix. but it was a small hole, nothing massive
once my engine was cool enough, there was no pressure from the inside forcing the hole to continue squirting. got a heat gun and dried the area around the hole, then applied the araldite sparingly and then applied the heat gun to it.
all done in 30 minutes and ready for another session.
i wouldn't use the stuff that you pour inside the rad though
The world is a book, and those who do not travel, read only a page.
Wave2k
G's Stalker
PostPosted: 14:16 - 10 Jan 2008    Post subject: Reply with quote
nah i never intended to use radweld, ive only heard bad things.
What should i clean the area with, as its an Enduro its quite muddy.
white spirit maybe ?
PostPosted: 14:22 - 10 Jan 2008    Post subject: Reply with quote
Clean the area with a stiff brush and soapy water, then clean water, then solvent of some sort. It needs to be totally clean, dry and grease free for adhesive to stick properly.
Araldite is probably one of the worse chemicalmetals. See if you can find some JB weld, it is teh seks.
Wave2k
G's Stalker
PostPosted: 14:44 - 10 Jan 2008    Post subject: Reply with quote
A solvent, like what ? i got limted solvents in my house Razz
Type_Mo
PostPosted: 14:46 - 10 Jan 2008    Post subject: Reply with quote
cantcha put one of your power ranger plasters on the boo boo? Laughing
cagiva gezzer
PostPosted: 14:47 - 10 Jan 2008    Post subject: Reply with quote
I've fixed a huge generator radiator using solder and a mini blow torch. Just normal solder and a good aim.
tatters
Exxon Valdez
PostPosted: 16:13 - 10 Jan 2008    Post subject: Reply with quote
Had good results repairing radiator holes with a pair of long nose pilers and super glue in the past as a temporary repair. plus at work we repair condenser coils (massive radiators the size of buses) with brazing solderer which you could try on a little bike radiator.
PostPosted: 16:24 - 10 Jan 2008    Post subject: Reply with quote
Isopropyl alcohol from maplins - cleans anything
https://www.maplin.co.uk/Search.aspx?criteria=isopropyl&source=15&SD=Y
Triumph Trophy Launch Edition
PostPosted: 16:38 - 10 Jan 2008    Post subject: Reply with quote
Meths is fine too. Or lighter fluid.
Motorbike radators are usually alloy. You'd need to use aluminium solder such as lumiweld. There is about a 50 degree difference between the temperature the solder fluxes at and the temperature the alloy melts at.
It is possible to solder one but with the amount of heat-sinking that will be going on, it would be VERY easy to lose your patience, apply too much heat to a single point and blast a large hole in it with your blowlamp.
Wave2k
G's Stalker
PostPosted: 16:49 - 10 Jan 2008    Post subject: Reply with quote
Well i had a go, i just flooded the hole and area with the stuff.
Damon
PostPosted: 22:01 - 10 Jan 2008    Post subject: Reply with quote
Is that normal araldite? Shouldnt you use the metal one which is grey in colour?
teampots
PostPosted: 22:19 - 10 Jan 2008    Post subject: Reply with quote
i would've said to use barrs leaks, is better stuff than Radweld although basically the same and managed to fill the many holes in my CBR 125's radiator
Current - Fazer 600
Prev - Bandit x2 (Killed) CB400 (Superfour) CBR125
Currently Restoring - Kawasaki S1 250 Triple (Slowly but surely)
PostPosted: 00:10 - 11 Jan 2008    Post subject: Reply with quote
I used normal araldite to repair a petrol tank and it was still tight after a year when I sold the bike
PostPosted: 00:13 - 11 Jan 2008    Post subject: Reply with quote
I wouldn't use anything like that on a bike engine, I suppose I'm worried about the cooling being restricted and it affecting the coolant mixture ad the engine corroding.
It's probably stupid but I'd rather not take the risk.
teampots
PostPosted: 22:46 - 11 Jan 2008    Post subject: Reply with quote
to each his own i suppose, never use a full bottle if you do Razz no need on such a small cooling system
Current - Fazer 600
the grim reaper
PostPosted: 22:50 - 11 Jan 2008    Post subject: Reply with quote
Depending on the type of rad, you need to be careful you don't block flow. Should be OK for a temp fix though.
Grim
The last post was made 18 years, 11 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.32 - MySQL Queries: 13 - Page Size: 104.13 Kb
