| Wave2k |
 Wave2k G's Stalker
| Robby |
 Robby Dirty Old Man
 Posted: 13:50 - 10 Jan 2008 Post subject: |
Halfords does sell araldite and chemical metal.
I'll start the classic disclaimer that if this sort of bodge fails you might kill your motor.
Take the rad off the bike, and get it properly dry- a few hours an airing cupboard or on top of a rad might do this.
I presume you're dealing with a hole made by a stone. Clean out the broken rad pipes with a cotton bud, make up some chemical metal, and plug the hole with it.
Let it dry for a good while before using it- water and slightly cured epoxy don't mix well. It should cure quicker if you put it somewhere warm.
Pop the rad back on the bike, refill with coolant, a warm the bike up to operating temp, turn off, top up with coolant, pop the rad cap back on and run it for a few minutes to see if the pressure pushes out the epoxy plugs.
If it holds, use it until your new rad turns up. Chemical metal is good stuff, and although its not adviseable to ride with a bodge like this plce, it might work quite well.
I wouldn't go for any radweld or similar - you don't want to be chucking crap into your cooling system, and it only really works on pinprick holes. |
| Wave2k |
 Wave2k G's Stalker
| curryfishball |
 curryfishball Nova Slayer
| Wave2k |
 Wave2k G's Stalker
| stinkwheel |
 Posted: 14:22 - 10 Jan 2008 Post subject: |
Clean the area with a stiff brush and soapy water, then clean water, then solvent of some sort. It needs to be totally clean, dry and grease free for adhesive to stick properly.
Araldite is probably one of the worse chemicalmetals. See if you can find some JB weld, it is teh seks. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Wave2k |
 Wave2k G's Stalker
 Posted: 14:44 - 10 Jan 2008 Post subject: |
A solvent, like what ? i got limted solvents in my house  ____________________ Ducati 1299 Panigale
2009 Corvette C6 z51
RS125->CBR400->RXS100->GSXR750K2->Ducati749S->CBR600RR5->TL1000R->DRz400->RSVR1000->Honda VTR SP1->CBR400->GSXR1000K6->Honda H100->CBR600RR3->Ducati1299 |
| Type_Mo |
 Type_Mo World Chat Champion
 Posted: 14:46 - 10 Jan 2008 Post subject: |
cantcha put one of your power ranger plasters on the boo boo?  ____________________ - Typhoon ?0 - Yamaha DT125R - Aprilia SR125 - Yamaha DT125R - Honda Hornet 600 - |
| cagiva gezzer |
 cagiva gezzer World Chat Champion
| tatters |
 tatters Exxon Valdez
 Posted: 16:13 - 10 Jan 2008 Post subject: |
Had good results repairing radiator holes with a pair of long nose pilers and super glue in the past as a temporary repair. plus at work we repair condenser coils (massive radiators the size of buses) with brazing solderer which you could try on a little bike radiator. ____________________ Past:NRG50,AF1125(x2),NSR125RR,ZZR250,CX500,VFR400,KR1S,ZZR600(x2),CB400N,YZF1000(x2),KH125,Z200,FX400R,CBR954RR(x2)GPZ500S,GT550,VFR750F(x2),RD350N,XR650R,CBR600F,CB250,KDX250,YZF750R,CRM250,400EXC,KLR650,TTR600RE,DR350S,R100GSPD,RGV250,VMAX1200,DL650,KZ750 Present:G650XC,C12,CRF450X,1190ADV |
| Polarbear |
 Polarbear Super Spammer
| stinkwheel |
 Posted: 16:38 - 10 Jan 2008 Post subject: |
Meths is fine too. Or lighter fluid.
Motorbike radators are usually alloy. You'd need to use aluminium solder such as lumiweld. There is about a 50 degree difference between the temperature the solder fluxes at and the temperature the alloy melts at.
It is possible to solder one but with the amount of heat-sinking that will be going on, it would be VERY easy to lose your patience, apply too much heat to a single point and blast a large hole in it with your blowlamp. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
| Wave2k |
 Wave2k G's Stalker
| Damon |
 Damon World Chat Champion
| teampots |
 teampots Spanner Monkey
| Polarbear |
| Polarbear |
| teampots |
 Posted: 22:46 - 11 Jan 2008 Post subject: |
to each his own i suppose, never use a full bottle if you do no need on such a small cooling system ____________________ Current - Fazer 600
Prev - Bandit x2 (Killed) CB400 (Superfour) CBR125
Currently Restoring - Kawasaki S1 250 Triple (Slowly but surely) |
| the grim reaper |
 the grim reaper World Chat Champion
The last post was made 18 years, 11 days ago. Instead of replying here, would creating a new thread be more useful? |
