| Scotch Bonnet |
 Scotch Bonnet Scooby Slapper
| spikenipple |
 spikenipple Crazy Courier
| map |
 map Mr Calendar
 Posted: 12:52 - 11 Jan 2008 Post subject: |
FWIW tyre sizes are almost all metric sizes (ok, the numbers may refer to inches but they are metric). The only manufacturer bikes I know of (and I'll wait to be corrected) that use imperial sizes are Harley Davidson and the Yamaha Virago VX535. ____________________ ...and the whirlwind is in the thorn trees, it's hard for thee to kick against the pricks...
Gibbs, what did Duckie look like when he was younger?  |
| Scotch Bonnet |
 Posted: 13:21 - 11 Jan 2008 Post subject: |
Good to hear on the inner tube measuerments but it also applies to the tyre itself too.
For some reason the site crashes explorer on my work PC, but Honda's specs for the CG on their website uses both systems - a 2.75 at the front and a 90/90 at the back,
Having a look elsewhere I see that a 3.00 and a 90/90 are definitely different, I just don't know if i should be bothered about which they use. ____________________ Hmmmm..... is it supposed to do that?
2001 CB500 |
| Kickstart |
 Kickstart The Oracle
| stinkwheel |
 Posted: 13:43 - 11 Jan 2008 Post subject: |
3.00 is 3" wide at the widest point.
90/90 is 90mm wide and has a height which makes up 90% of the width.
90mm = 3.54".
Either tyre size will fit on the rim.
In reality, the tubes are almost certainly one and the same, what with rubber being very stretchy. ____________________ “Rule one: Always stick around for one more drink. That's when things happen. That's when you find out everything you want to know.”
The last post was made 18 years, 34 days ago. Instead of replying here, would creating a new thread be more useful? |
