Tyre Sizes (Metric vs Imperial)
Scotch Bonnet
PostPosted: 12:41 - 11 Jan 2008    Post subject: Tyre Sizes (Metric vs Imperial) Reply with quote
Since my rear lost an argument with a broken bottle the other day, I've been trying to get hold of a new inner tube. Most places seem to only do a 3.00 x 18, where Honda and Haynes seem to state it as 90/90 x 18.
I realise the two are supposed to be equivalent, but is there much of a difference?
At the end of the day it's just a CG so I always feel a bit silly taking such things quite so seriously, but hey, it might be relevant later on down the line.
Hmmmm..... is it supposed to do that?
2001 CB500
spikenipple
PostPosted: 12:47 - 11 Jan 2008    Post subject: Reply with quote
The majority of innertubes are measured in inches diameter, so a 3.00" x 18" innertube will be the right one.
The tyre is marked as a 90/90 which is width/profile in relation to width.
C50 > GN250 > XJ600 > SV650S K7 > 2001 RSV Mille R > MT-09, XR400R > 2005 Fireblade (trackbike) + 2022 MT-09 + ZXR400 race bike
map
Mr Calendar
PostPosted: 12:52 - 11 Jan 2008    Post subject: Reply with quote
FWIW tyre sizes are almost all metric sizes (ok, the numbers may refer to inches but they are metric). The only manufacturer bikes I know of (and I'll wait to be corrected) that use imperial sizes are Harley Davidson and the Yamaha Virago VX535.
Scotch Bonnet
PostPosted: 13:21 - 11 Jan 2008    Post subject: Reply with quote
Good to hear on the inner tube measuerments Thumbs Up but it also applies to the tyre itself too.
For some reason the site crashes explorer on my work PC, but Honda's specs for the CG on their website uses both systems - a 2.75 at the front and a 90/90 at the back,
Having a look elsewhere I see that a 3.00 and a 90/90 are definitely different, I just don't know if i should be bothered about which they use.
2001 CB500
PostPosted: 13:41 - 11 Jan 2008    Post subject: Re: Tyre Sizes (Metric vs Imperial) Reply with quote
Basically equivalent.
Older tyres had an assumed profile (of 90% of width), hence the size was just given as a width and rim size. Newer tyres specify the width, the profile as a percentage of the width and the rim size.
Think an 80/90 tyre would be a closer match to a 3.00 tyre. However if the 90/90 physically fits and is recommended then I would not expect any problems at all.
PostPosted: 13:43 - 11 Jan 2008    Post subject: Reply with quote
3.00 is 3" wide at the widest point.
90/90 is 90mm wide and has a height which makes up 90% of the width.
90mm = 3.54".
Either tyre size will fit on the rim.
In reality, the tubes are almost certainly one and the same, what with rubber being very stretchy.
The last post was made 18 years, 34 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.62 - MySQL Queries: 13 - Page Size: 50.84 Kb
