How do scooters work?
Jull
PostPosted: 21:35 - 13 Jan 2008    Post subject: How do scooters work? Reply with quote
I am the least mechanically minded person there is and I don't get how scooters work in the following situations:
I think that the back wheel is powered when the engine is on, so how do you wheel a scooter backwards to park etc? Does the engine have to be off?
Also, say you accidently knock the engine cut off switch when riding (I don't know what happens on a geared bike either), because you can't declutch would the engine seize and throw you off, and how would it know to be back in first gear when you started it again? Confused
PostPosted: 21:43 - 13 Jan 2008    Post subject: Re: How do scooters work? Reply with quote
Scooters work using a centrifugal clutch, at low rpms this is disengaged so the rear wheel doesn't spin, it is like neutral.
When you rev the bike the clutch expands touching the walls (like a drum brake) and you move.
Scooters don't have kill switches so the only way you could turn the engine off is with the ignition switch. If this did happen the engine would just slow down until you stop, it's not going to seize as fuel is still going into the engine, it may flood though.
Don't know how it gets back into first gear but I guess it works in the same way as an automatic car. How does that work?
Small scooters only tend to have 2 gears.
HTH Mark
Richard_Schmid
PostPosted: 21:45 - 13 Jan 2008    Post subject: Reply with quote
I recomend you take whats known as a CBT (compulsary bike training). Contact your local Motorbike training centre for more info.
Here you will learn the basicvs of riding. Will probably answer most of your questions.
Regards,
Richard
EDIT: sorry that should be Compulsary BASIC Training..My bad
Jull
PostPosted: 21:52 - 13 Jan 2008    Post subject: Reply with quote
Regards,
Richard
I passed my test on a geared bike and due to an ongoing injury from an accident a couple of years back am considering a scooter for my 'bad' days when my left side is too weak for my big bike.
I had a go on one at the bike show ages ago and it's only now I'm thinking of getting one that I realised I don't really get how they work. Embarassed
Charlie
PostPosted: 21:55 - 13 Jan 2008    Post subject: Reply with quote
https://www.twistngo.com
Is a scooter magazine might help you if you decide to get one. Also they have forum: https://www.twistngo.com/userforum/index.php
divuk83
PostPosted: 22:01 - 13 Jan 2008    Post subject: Reply with quote
https://auto.howstuffworks.com/cvt2.htm
Dave
TheShaggyDA
Repost Police
PostPosted: 22:03 - 13 Jan 2008    Post subject: Reply with quote
From here :-
https://www.teamcalamari.com/zuma/pix/variatoranimation.gif
Variator in action :-
https://www.youtube.com/watch?v=9TnkUIecRE4
Better, shorter video :-
https://www.youtube.com/watch?v=2XDqgGFfCso
Stalk
PostPosted: 22:05 - 13 Jan 2008    Post subject: Reply with quote
This may help:
https://en.wikipedia.org/wiki/Variomatic
PostPosted: 22:10 - 13 Jan 2008    Post subject: Reply with quote
Is it just light weight you want, or do you need the automatic too?
If it's just light weight, there are a variety of options.
For instance the CCM CR40 is listed at 119kg I believe and looks quite pretty, not so much underseat storage, however:
https://www.ccmmotorcyclesuk.com/images/stories/cr-40-large.png
Paivi
PostPosted: 22:10 - 13 Jan 2008    Post subject: Re: How do scooters work? Reply with quote
Mine does. If I accidentally hit it, the engine dies but not suddenly. The bike just starts to grind to a halt.
Jull
PostPosted: 22:41 - 13 Jan 2008    Post subject: Reply with quote
Cheers folks! Thumbs Up
I'm feeling as excited as I was when getting my first Bike!
My 500cc is fine when on the go it's just a right pain to manoeuvre when parking up and getting it in and out of the garage. Also once I've gone over 80 miles on a run out it creases my neck and left arm, whether that would be the same on a different bike remains to be seen.
At the mo, the new Honda Lead is top of the list, but the 2008 model isn't out yet and nobody's got a price on one. Sat on one at the bike show and the initial reviews are favourable so might give it a go. Very Happy
PostPosted: 23:00 - 13 Jan 2008    Post subject: Reply with quote
TheShaggyDA wrote:
I did not know that is how a scooter worked.
I've learnt something aswell.
Just out of interesting, how do the pullies change sizes?
colin1
Captain Safety
PostPosted: 23:17 - 13 Jan 2008    Post subject: Reply with quote
there are rollers, that roll outwards in a path from the centre to the edge of the disc as rpm increases. The rollers then push apart the discs or bring them nearer depending on rpm.
You can change the rollers, to change the behaviour of the system.
Noxious89123
PostPosted: 23:54 - 13 Jan 2008    Post subject: Reply with quote
https://img265.imageshack.us/img265/8271/powerbandsn3.jpg
Middle Finger Mr. Green
So what are the pulleys made of as it looks like metal but how can metal change shape like that?
darkangel
PostPosted: 00:06 - 14 Jan 2008    Post subject: Reply with quote
yes, what demon magic is this?
divuk83
PostPosted: 00:23 - 14 Jan 2008    Post subject: Reply with quote
Very simply and badly explained:
As the variator (driven pulley) spins, centrifugal force acting on the rollers (weights) in the variator cause the two side of the variator to come together pushing the belt away from the centre of the shaft which increases the gearing. ie as the rev's build the gearing and the speed increase, as the decrease the gearing lowers again.
Dave
PostPosted: 00:34 - 14 Jan 2008    Post subject: Reply with quote
Dave
After looking at Shaggy's animation again, I understand exactly what is happening.
Cigaro
PostPosted: 15:55 - 14 Jan 2008    Post subject: Reply with quote
The Honda Lead is a good choice of scoot. Used to ride one when I worked at Domino's and they're really easy to ride.
TheShaggyDA
Repost Police
PostPosted: 15:57 - 14 Jan 2008    Post subject: Reply with quote
If you had read the links I (and others) posted, you'd know.
DidierD
PostPosted: 16:10 - 14 Jan 2008    Post subject: Reply with quote
hahaha, how much did that go for in the end and did anyone pay for it? Razz
panpan
PostPosted: 20:14 - 14 Jan 2008    Post subject: Reply with quote
They are usually made of rubber. However, you can get kevlar belts which in my opinion offers slighlty less grip, but longer life.
stan hyd
PostPosted: 20:24 - 14 Jan 2008    Post subject: Reply with quote
mine does.
DAS Passed 12/12/07 2 minors!
Looking for a hornet - ?1900 mark
PostPosted: 20:32 - 14 Jan 2008    Post subject: Re: How do scooters work? Reply with quote
As above, pretty sure our DNA has a kill-switch.
Even on a fuel injected bike, the engine will not seize without fuel when you hit the kill switch. It will just slow you down until you stop, as you suggest. On a rear bike the clutch will remain engaged so it will slow down quicker than on a scooter where it disengages at lower rpm.
Skudd
PostPosted: 23:20 - 14 Jan 2008    Post subject: Reply with quote
I always thought they worked on acne.
The last post was made 18 years, 253 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.15 Sec - Server Load: 0.79 - MySQL Queries: 15 - Page Size: 130.59 Kb
