go out and measure your rear wheels!
feef
Energiser Bunny
PostPosted: 17:56 - 15 Jan 2008    Post subject: go out and measure your rear wheels! Reply with quote
...pretty please....
I'm looking for a 17" rear wheel for my race bike, and options are thin on the ground.
If your wheel is 175mm from inside side of disk to inside side of sprocket, then it might be a candidate.
Sooo... if any of you can be arsed to do a bit of measuring for me, then I'd very much apreciate it.
tia
a
Mudskipper wrote: feef, that is such a beautiful post that it gave me a lady tingle Laughing
Windchill calculator - London Bike parking
Blog and stuff - PlentyMoreFish dating
EddyJones
PostPosted: 18:01 - 15 Jan 2008    Post subject: Reply with quote
Would it not just be R17 on the tyre?
If so Bt090 Smile
garth
PostPosted: 18:03 - 15 Jan 2008    Post subject: Reply with quote
Read again, he's after hub width.
I'll have a look on the goose and gsxr later. Thumbs Up
PostPosted: 19:04 - 15 Jan 2008    Post subject: Re: go out and measure your rear wheels! Reply with quote
Have you measured SV650 ones?
I presume you don't want 180 width tyre?
Reckon my SM wheels might be quite skinny, that'd be 'different' definitely Smile.
TUG
PostPosted: 19:22 - 15 Jan 2008    Post subject: Reply with quote
You still doing the FZR for race?
Did that guide come to good use i sent you? Why you changing the front now? after a 120 tyre now?
Haz ER-5, innit!
feef
Energiser Bunny
PostPosted: 19:42 - 15 Jan 2008    Post subject: Reply with quote
I haven't measured an SV650 one, since I don't know anyone with an SV650 Razz a 180 tyre would be bad.. the stock one is a 140 I think... so something around that size.
Who mentioned the front? and what sort of Front do you know that has a sprocket on it? Razz
That guide didn't 'specify' that it was for the 3EN2 model, so I can't rely on it. Also, the wheels mentioned i'm finding hard to locate, so am looking to see what other options there are.
a
PostPosted: 19:53 - 15 Jan 2008    Post subject: Reply with quote
But you do know someone that has several sets of SV wheels Wink.
Suspect it will be too wide though.
Will try and attach a ruler to one when I get a min, bit busy at the mo.
TUG
PostPosted: 20:08 - 15 Jan 2008    Post subject: Reply with quote
Does the 3EN2 have an 18 inch rear wheel? Then i would presume the rules apply, why not just make it easier for yourself and fit a 3TJ rear swinger setup? Or measure the distance between the legs of the swing arm so you know if a wider rim will fit or not?
I misread your OP sorry for the mistake, and the rim size of a 3EN model is 4 x 18(inch) and on the 3tj's its 4.50 x 17(inch) by manuals.
The 3TJ rim uses a 160 width tyre, so measure the distance of your swingarm legs, but on my model (3EN1) it would rub on the swing arm.
Haz ER-5, innit!
feef
Energiser Bunny
PostPosted: 20:33 - 15 Jan 2008    Post subject: Reply with quote
the 3EN2 has an 18 rear. The rules allow for the wheel change, as it's Still an FZR400 standard size.
I'm also fitting 3TJ bodywork simply because 3EN2 bodywork isn't around.
on the 3EN2 you CAN fit a 4.5
There's enough difference and variety between all the models that you can get away with it.
a
TUG
PostPosted: 20:37 - 15 Jan 2008    Post subject: Reply with quote
If your EN2 swinger can take the 3TJ rim then bang it on, you sure it can? is there 170mm width between each swing arm leg? if so just get a 3TJ rim or FZR600 17 inch rim, i think alot of them came in 4.50 aswell.
Haz ER-5, innit!
hmmmnz
PostPosted: 20:40 - 15 Jan 2008    Post subject: Reply with quote
thats exactly gs500 size, only a 3.5 inch rim though
the humans are dead
I kick arse for the lord
hmmmnz
PostPosted: 20:42 - 15 Jan 2008    Post subject: Reply with quote
actually thats the outside to the outside,
you could get a bandi6 6 wheel with a gs500 sprocket carrier,
the humans are dead
TUG
PostPosted: 20:44 - 15 Jan 2008    Post subject: Reply with quote
Just been on ebay, and looked at a 2TK rim, and 2 FZR 600 rims and asked for sizes for you feef. Let you know when they get back to me and give you the links etc.
Haz ER-5, innit!
feef
Energiser Bunny
PostPosted: 21:51 - 15 Jan 2008    Post subject: Reply with quote
Cheers all...
a
kitty kat
PostPosted: 23:36 - 15 Jan 2008    Post subject: Reply with quote
A Fazer 600 is 200mm, so that is no good to you, but at least I measured it Very Happy
Do I get any Brownie points now? Laughing
feef
Energiser Bunny
PostPosted: 23:48 - 15 Jan 2008    Post subject: Reply with quote
All i got to give is karma Very Happy
thanks
a
Gazdaman
I did a trackday!!!
PostPosted: 11:03 - 16 Jan 2008    Post subject: Reply with quote
Try a TZR250 wheel. Or even a TZR125, or an SZR660 (same wheel). The latter two get snapped up by MZ racers before you'll probably get a look in.
TZR250 takes a 140section standard I think. Mine had a 150 shoehorned in.
Consider an RS125 rear aswell, although they're probably too wide.
Gaz
Azonicben
PostPosted: 16:13 - 16 Jan 2008    Post subject: Reply with quote
just nipped out with my tape 175mm centre/centre disc/sprocket on a hyosung gt125r Thumbs Up
feef
Energiser Bunny
PostPosted: 16:22 - 16 Jan 2008    Post subject: Reply with quote
175mm? that's an interesting one Smile
hmm I wonder!
cheers
a
TUG
PostPosted: 16:24 - 16 Jan 2008    Post subject: Reply with quote
2TK rim is a 18" and the blokes with the FZR6 rims on ebay one hasnt contacted me yet and the other says he doesnt have one... But its for sale... Confused
Sorry.
Still think that you should find a 3TJ rim from a breakers or a bike being broken.
EDIT:Fox eye rim is 5"
Haz ER-5, innit!
TUG
PostPosted: 16:27 - 16 Jan 2008    Post subject: Reply with quote
Found this...
Haz ER-5, innit!
feef
Energiser Bunny
PostPosted: 16:31 - 16 Jan 2008    Post subject: Reply with quote
XlonewolfX wrote:
I fucking love you man (in a manly, macho platonic way of course Wink )
a
TUG
PostPosted: 16:39 - 16 Jan 2008    Post subject: Reply with quote
feef wrote:
a
No problem feef, hope it all works out for you and you have a good season on the track. Thumbs Up
Haz ER-5, innit!
feef
Energiser Bunny
PostPosted: 16:42 - 16 Jan 2008    Post subject: Reply with quote
me too.. even better,.. that dude's in Bedford.. only 20 mins from the house Smile
You'll get a mention on the fairing Wink
Everyone that offers me some proper help, either suggestions, finding bits, or even just buying me a beer in the name of racing is going to get a mention on the bike Smile
a
TUG
PostPosted: 16:47 - 16 Jan 2008    Post subject: Reply with quote
Thanks Very Happy and your so close too! SCORE! why not get the front rim as a spare while your there? You never know.
How come you didnt do the R6 race fairing like madsi did over in OZ? Alot of track based FZR's get this done to them, just a thought but if you already have 3TJ track fairing am sure they will fit with a bit of modification just fine.
Haz ER-5, innit!
The last post was made 18 years, 280 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 136.49 Kb
