NC29 unused for a month ? should I run it once a week ?
blownygti
PostPosted: 12:13 - 21 Jan 2008    Post subject: NC29 unused for a month ? should I run it once a week ? Reply with quote
got my NC29 on 9th dec but my test isn`t untl mid feb, my bikes well covered up outside and it gets well washed once a week, I also remove the cover whenever its dry so it gets a chance to breath and dry out properly, but should I start it and let it idle upto temp once a week or will this do more harm than good as I obviously can`t take it out yet Sad
MaybeGuy
PostPosted: 12:43 - 21 Jan 2008    Post subject: Reply with quote
take it for a blast every week at least,
my SRAD battery went flat after not using it for a month or 2 (i had a cast... couldnt be helped).
was a bastard to start after that, then again, the battery on it is a bit fuckered.
i think its the original one
PostPosted: 12:48 - 21 Jan 2008    Post subject: Reply with quote
I wouldn't start it regularly. It is only a couple of months, but for real long term storage there are a load of things worth doing.
Starting it up just generates a load of steam in the exhaust, to nicely get corrosion going from the inside.
Take the battery off and keep it somewhere warmer, and charge it occasionally.
Barker-CBR 600
PostPosted: 13:25 - 21 Jan 2008    Post subject: Reply with quote
You can get Optimates etc that have programs for leaving the battery plugged in and it keeps it charged, although not sure on whether people reccommend them??
Previous - Gilera DNA50 / XVS125 Dragstar/Honda CBR 600F/GSF 650 Bandit
Current - 2013 Suzuki VZ800 Intruder
'Is this a rhetorical question?'
Kal
PostPosted: 13:40 - 21 Jan 2008    Post subject: Reply with quote
Know lots of people using Optimates and generally they are recommended, however in this case he'll be better served gettign the battery out of the cold before it is completely killed
Kal...
The last post was made 18 years, 285 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 44.68 Kb
