Engine overheating
Arron947
PostPosted: 14:09 - 21 Jan 2008    Post subject: Engine overheating Reply with quote
hello i was wondering if anyone could help me solve my problem : Got my bike finally started 2002 gilera runner 2 stroke 50cc and when i ride for about a mile it will heat up beyond reckignition there is water in the coolant bottle but its not cooling the engine down
thanks
Trixie
PostPosted: 14:50 - 21 Jan 2008    Post subject: Reply with quote
Is there any coolant or are you just running it on water?
Dead nobodies in company cars...
Finglonga
PostPosted: 15:02 - 21 Jan 2008    Post subject: Reply with quote
Would make no difference it would still cool the engine.
Is the radiator getting hot? Check the pipes to see if they are heating up. The stat could be stuck closed or you could have an airlock.
Andy Sez....
F.Y.Y.F.F.
Arron947
PostPosted: 15:30 - 21 Jan 2008    Post subject: Reply with quote
no the radiator doesnt get hot and ive had the cap of the coolent bottle with the engine running and i have squeezed all the pipes to get the air out !
Finglonga
PostPosted: 16:39 - 21 Jan 2008    Post subject: Reply with quote
You need to check the thermostat then as it sounds like it isn't opening up when it gets hot. . . . Or drain and refill the cooling system to remove any airlocks.
Andy Sez....
F.Y.Y.F.F.
Arron947
PostPosted: 16:46 - 21 Jan 2008    Post subject: Reply with quote
any chance you could tell me were that is on my runner
panpan
PostPosted: 19:44 - 21 Jan 2008    Post subject: Reply with quote
Or, your engine could be running very lean. This causes high temperature in the engine. Quite dangerous for the engine as well. What colour is your spark plug tip?
Finglonga
PostPosted: 20:20 - 21 Jan 2008    Post subject: Reply with quote
The rad is staying cool so I would imagine/think/guess the mixture is ok.
Not a clue where the thermostat is on one of those engines either. Could also be the water pump has given up thinking about it. Confused
Andy Sez....
F.Y.Y.F.F.
PostPosted: 21:09 - 21 Jan 2008    Post subject: Reply with quote
Are you sure the engine is filled from the coolant bottle? Most are not, and the bottle could be full yet the engine is empty. Most are filled at te radiator filler cap.
cheekythomas
PostPosted: 21:10 - 21 Jan 2008    Post subject: Reply with quote
I would check the waterpump is working first of all.
Remove the drivebelt casing and make sure the small belt behind the variator is still there and in one piece...
...then remove the 2 main bolts holding the oil pump on and pull it off the gearcog, then remove the gear and make sure its all ok and it hasnt spun the middle out.
panpan
PostPosted: 23:36 - 21 Jan 2008    Post subject: Reply with quote
Good point.
PostPosted: 23:59 - 21 Jan 2008    Post subject: Reply with quote
Radiators aren't supposed to stay cool, they are supposed to get hot. If it's staying cool then either there's no coolant in it or the coolant isn't circulating.
Arron947
PostPosted: 13:52 - 22 Jan 2008    Post subject: Reply with quote
the spark plug is white
Noxious89123
PostPosted: 14:40 - 22 Jan 2008    Post subject: Reply with quote
He means what colour is the metal electrode tip, not the insulating part of the plug Laughing
Arron947
PostPosted: 18:23 - 22 Jan 2008    Post subject: Reply with quote
Yes when i took it out it had a white powder on it !
PostPosted: 18:28 - 22 Jan 2008    Post subject: Reply with quote
Probably melted piston-crown from running very lean/hot
Arron947
PostPosted: 19:16 - 22 Jan 2008    Post subject: Reply with quote
My bike starts first time but would that be the problem for its over heating ? Also i took the belt drive off today and had a look at the water pump and when i turn the cog water pisses out from the could that be and mean i need a new water pump ?
Runner07
PostPosted: 21:43 - 22 Jan 2008    Post subject: Reply with quote
Had and basically still have the same problem with my Gilera Runner 2 Stroke 2002 model.
However it MUST be a Gauge mis-calculation because ive been driving it for 5 months solid with the Guage reading H for HOT.
Does it actually overheat? Or isit just saying its HOT? It could be just like mine and nothing to worry about.
But yeah, it could be a block, trapped air. Take it to your nearest workshop and have them look at it for you.
Can you confrim that it does Over-heat ?
Arron947
PostPosted: 13:59 - 23 Jan 2008    Post subject: Reply with quote
Yes i can comfirm because when i drive about a mile my engine will cut out and wont start untill it has cooled a little ! also when i put my hand near the cylinder head you can feel the heat !
I think the water pump has gone because i took the belt drive of and when i spin the water pump cog the water just pisses out from there
panpan
PostPosted: 19:05 - 23 Jan 2008    Post subject: Reply with quote
You are running very lean. This could cause the engine to overheat after a while and cause the piston to expand so much that it semi-seizes. Richen your mixture and see if it still happens.
aran2806
PostPosted: 00:53 - 24 Jan 2008    Post subject: Reply with quote
Check there is no water in the oil. Had a similar problem with my aerox.
The last post was made 18 years, 149 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.32 - MySQL Queries: 13 - Page Size: 111.15 Kb
