Getting dents out of exhaust?
Reppyboyo
PostPosted: 17:11 - 22 Jan 2008    Post subject: Getting dents out of exhaust? Reply with quote
Hi,
Is it possible to get dents of of an exhaust?
My old one was damaged when it fell over in the van (doh!) creating two indents on the can.
They are both quite smooth, not a sharp indent.
Is there anyway to pull them out at all?
I tried to take pics of them but they didnt come out so well on the camera phone (normal camera is recharging).
https://img223.imageshack.us/img223/6870/dsc00057ah5.th.jpg
https://img223.imageshack.us/img223/3415/dsc00059ut5.th.jpg
aero
PostPosted: 19:33 - 22 Jan 2008    Post subject: Reply with quote
you're right you can't see propely!
Most dents can be pushed out, but usually from the inside. You may be able to attatch a slide hammer, but you'll be looking at welding doing things like that.
70's & 80's 4 stoke Yamaha Guru and professional workshop dweller.
Ichy
PostPosted: 21:00 - 22 Jan 2008    Post subject: Reply with quote
The hard bit will be matching the finish of the repaired area to the rest of the can.
If its riveted then it may be better to disassemble the can to give better access.
*Might* be better to fit a new sleeve to the can if its round.
tutton
PostPosted: 21:12 - 22 Jan 2008    Post subject: Reply with quote
Get a body spoon
that would pop out easy
or
Get a body pin put in and pull out with the pin
but thats a bit harder.
Ichy
PostPosted: 22:03 - 22 Jan 2008    Post subject: Reply with quote
Rolling Eyes fecking engineers Rolling Eyes
It looks aluminium, it won't 'pop' out if it is.
deanoet
PostPosted: 23:28 - 23 Jan 2008    Post subject: Reply with quote
If it is a very slight dent you may be able to coax it out using a strong magnet
Assuming the material is magnetic, if it is alluminium you arent using a magnet. Smile
Body repair shops use vaccum sucktion cups to pull dents out of car doors, a smaller sucktion cup would work, but without a vacuum the pressure needed to pull the dent out would be more than what was needed to make it worse, so you would end up with a bigger dent pushing the sucktion cup on. Smile
if u took it off and took it into a body repair shop they may do it for nowt for ya there and then if it is a 30 second job, especially if u happened to roll up on your dinner, if not they would give you an idea on cost. Thumbs Up
Had a few come round when i was tool making, sat around on dinner as a guy wandered up asking how much it would cost for a drill to be sharpened. Someone would jump up and do it there and then for them for nowt. Same with something that needed just rough machining or a quick 2 min job
Works best in summer when they are sat outside though Thumbs Up
if u dont ask, u dont get, cant hurt for asking. Smile
PostPosted: 00:06 - 24 Jan 2008    Post subject: Reply with quote
I could see someone pulling a large-area depression out of a thin large panel with a magnet if the metal isn't stretched, but there's no way in hell you are going to pull a dent out of a cylinder with a magnet.
ZRX61
Victor Meldrew
PostPosted: 02:00 - 24 Jan 2008    Post subject: Reply with quote
Sure it will. I've popped loads of dents out of aircraft.
PostPosted: 18:46 - 24 Jan 2008    Post subject: Reply with quote
How do you then get the magnet off the exhaust?
Jockey
PostPosted: 19:42 - 24 Jan 2008    Post subject: Magnets. Reply with quote
Maybe he`s using an electromagnet, switch it on and then switch it off, simple as that.-Jockey.
PostPosted: 20:20 - 24 Jan 2008    Post subject: Re: Magnets. Reply with quote
I did think of that before I posted, honestly Embarassed
tutton
PostPosted: 20:36 - 24 Jan 2008    Post subject: Reply with quote
haha
feckin engineers is it pahah
Basically the pdr is the best way
using a long thin piece of metal
https://www.i-car.com/graphics/about_icar/current_events/advantage/2004/advantage_online_0719/full_size/fig_02.JPG
and you massage the dent out, not hit it gently massage around it,
any thing of that sort should work i think
Ichy
PostPosted: 23:22 - 24 Jan 2008    Post subject: Reply with quote
Wooden or plastic sticks work well.
You should heat up the damaged area to make sure the work hardened bit isn't going to cause the surrounding area to deform. Sharp damage is very hard to work due to stretching and aluminium doesn't have a memory like steel so it takes a bit more work to get the shape right.
The last post was made 18 years, 281 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 78.64 Kb
