Advice for riding in crap weather
mrbluesbox
PostPosted: 10:31 - 24 Jan 2008    Post subject: Advice for riding in crap weather Reply with quote
Ello
As im pretty sure everyone over the last last week or so has noticed the weather has been absolute shite.
Lots of wind, rain and general nastiness - and this has started to affect my confidence a bit - especially cos ive only had my 600 for a month.
I had my first major skid (rear wheel lockup posted about on here) recently and since then have had a couple more (just little ones though - nowhere near as bad)- seems as though my rear brake it a bit keen so im now getting worried about using it in the rain. Does anyone else bother using their rear brakes or is there summot i can do to help stop it locking cos it really feels like i cant use it any more than literally resting my foot on the peg with no pressure?
Also im getting worried about wind and leaning the bike over in the wet. Had a few cases this morning where i had the bike lent over a little (seriously not a lot) and wind blast almost felt like it was gonna take the bike out from under me. hence i really didnt want to lean into corners / roundabouts at all and just ended up bimbling round them. Is there any way i can change my riding to help lessen this?
(p.s. ive slowed down quite a bit and am riding no where near as quickly as i would do in decent conditions)
All advice greatfully recieved.
Ta
Gaz.
I seem to have misplaced my pants...................
doggone
PostPosted: 10:59 - 24 Jan 2008    Post subject: Reply with quote
Well realistically some days it would be better not to use it.
One thing which sounds odd but works is to avoid tensing up and over reacting to every little movement.
Keep your grip on the bars relaxed and don't worry so much about brief loss of grip or wind pushing you.
Try to keep your road positioning such that a slight change in intended route doesn't matter.(!)
garth
PostPosted: 11:01 - 24 Jan 2008    Post subject: Reply with quote
Stay relaxed, be smooth, no sudden braking etc.
fourten
PostPosted: 11:15 - 24 Jan 2008    Post subject: Reply with quote
+1 to relaxing! When it's windy, the best thing to do is relax/ be loose. This allows for your body to better naturally adjust the steering, whereas if you are stiff and tense, the movements will be jolty and less controlled.
As for bends, I find slowing down completely especially when it's wet helps.
www.artridertraining.co.uk
Finglonga
PostPosted: 14:03 - 24 Jan 2008    Post subject: Reply with quote
As above and keep an eye on the road, avoid drains, white lines and overbanding. Carefull on roundabouts while keeping an eye out for deisel or oil going accross the carrageway.
Andy Sez....
F.Y.Y.F.F.
Itchy
PostPosted: 14:11 - 24 Jan 2008    Post subject: Re: Advice for riding in crap weather Reply with quote
Ta
Gaz.
erm you do realise that hanging off keeps the bike more upright and thus less likely to wash out? , but its a confidence issue ,
mrbluesbox
PostPosted: 14:11 - 24 Jan 2008    Post subject: Reply with quote
must admit probably was a bit tense this mornin, after i locked the rear wheel and then nearly got blown off so i can imagine that that didnt help and made eveything feel 10 x worse.
think im gonna try and play with my rear brake pedal to put it a bit lower so im not putting as much pressure on it and that might help stop the locking up thing.
unfortunately my bikes my only transport and i fecking hate pubic transport Smile so im gonna be on it unless it really is dangersous (ice, snow or gales n things).
ill guess ill get more confident eventually and just keep thing slower in the meantime Smile
i would kill for a dry road at the mo Smile
iooi
PostPosted: 14:23 - 24 Jan 2008    Post subject: Reply with quote
Look at it this way, rear lockups are recoverable. Smile
Unlike when the front locks up.
Personally the worse the weather the more uou need to use the rear brake.
Also think further ahead and let the engine do most of the braking for you.
Good idea to adjust the rear so its a bit lower and takes your foot that bit longer to get there.
As to wind, not a lot you can do, make sure you dont have stuff flapping around.
You think a 600 is bad try a smaller bike, my divvy seem well planted in cross winds and that with a top box as well, compared to the 250's i used to ride.
Method
PostPosted: 14:28 - 24 Jan 2008    Post subject: Reply with quote
There are a few threads on here that give a realy good insight into riding through the winter / pants weather, with advice on everything from kit through to riding techniques... Might pay to check them out.
Winter Riding - Method's Perspective: https://www.bikechatforums.com/viewtopic.php?t=96152&highlight=winter+riding
Killa's Guide for the Winter Ride : https://www.bikechatforums.com/viewtopic.php?t=61629&highlight=winter+ride
Both got good karma reviews and a pretty comprehensive - definately worth checking out.
CBT Aug '03 ... Gilera GSM 50 ... Honda NSR 125 Aug '04 ...
Full Test Dec 04... Suzuki GS500 Jan 05... Suzuki SV650 Mar 07... Gixxer 6 K5 May 08... Oh and my 'Rado Wink
My Bikepics.com - No Brakes, No Gears... No Fear.
doggone
PostPosted: 14:30 - 24 Jan 2008    Post subject: Reply with quote
Very true, my current bike's a Yamaha BT1100 and being unfaired and seriously heavy, even gale force cross winds over the moors don't bother it much.
Walloper
PostPosted: 14:48 - 24 Jan 2008    Post subject: Reply with quote
Most of all whats above ^
Just everything you do is less than when you're on dry roads.
Read the road ahead and behind you.
Be very attentive (As you always should be Embarassed ) you have 50% less vision. And other road users suffer the same. They canny see you either.
Stuff a microfiber cloth somewhere in the handle bars so you can give your visor a swift wipe every couple of minutes (try to look cool whilst you do it). Or get one of those useless wiper things you slide over your gloved finger.
I never use the rear brake unless helping the front, rarely. But if you are following the rule of 'take it easy' then you will not meet situations where you end up grabbing a handful of lever to stop.
No point in worrying about lean. Don't. Not worth it. Unless you are on a track and you over cook it you'll not meet your end horribly under a bus coming the other way.
Stop regularly for endless cups of tea or batter on till you get there.
Don't go too fast as you can't stop as quick on shitty road surfaces.
killa
Won't Shut Up
PostPosted: 14:52 - 24 Jan 2008    Post subject: Reply with quote
...while rubbing your tummy and patting your head Laughing Thumbs Up
The good thing is that the temperature has risen a little, tyres perform a lot better than you think around 10 degrees even when wet. Same applies to all weather and your bike, get them warmed up first, but after 5-10 minutes of solid riding you can surprise yourself cornering at angles.
It’s good to have your brakes responsive, I’ve got used to my new rear pads and braided lines, they are bloody strong. You’ll get used to the force needed, never stamp down on it. Wink
As you can see in my winter guide mentioned above, its all about progressive riding in these conditions. I approach a corner, asses the curvature and angle (looking for your point of direction) and think about how much I can go comfortably around it. Braking the bike sat upright is the safest and quickest way to slow down, don’t be caught short. Brake progressively towards the bend, change down if need be, take the bike into the lean calmly and let common sense dictate the rest.
I really want to do a Youtube series of this sort of thing. Wish I had the equipment. Sad
Edit:- (guide is in my sig) Thumbs Up
Kal
PostPosted: 15:03 - 24 Jan 2008    Post subject: Reply with quote
Haha! You've not lived until you'gve had the whole bike going sideways!!!!
and now I am done with macho bullshit for this thread
You are worrying too much
If the rear locks just lift your foot and then reapply the rear brake
Smoothness wins in winter. Smooth throttle on, cornering and braking will all contribute to keeping you upright.
Braking moves from a 70/30 front/rear split to a 50/50 front/rear split
Double your braking distances and likewise following distances.
On the ice double again at least...
Keep in mind things like cold tyres have less grip than you are used to, and as the weather gets worse they take longer to warm up.
Kal...
Barney
PostPosted: 19:43 - 24 Jan 2008    Post subject: Reply with quote
Keep your arms relaxed, drop your elbow below your hand and shift your body weight into the corner, this will keep the bike more upright.
Plan way ahead and brake lightly eariler than normal to give yourself more time to slow down. Keep your distance from the car infront.
I often do most of my commute lightly touching the rear brake now and again just from planning ahead. No need for heavy braking this time of year.
CG125|CB400SF|CBR600FX|Triumph Daytona T595|CBR929RR
Walloper
PostPosted: 21:57 - 24 Jan 2008    Post subject: Reply with quote
If I drop ma elbows below ma wrists like this?
Barney
PostPosted: 22:16 - 24 Jan 2008    Post subject: Reply with quote
Yeah, whilst leaning round a corner in the wet... easy Wink
mrbluesbox
PostPosted: 10:15 - 25 Jan 2008    Post subject: Reply with quote
THE ROADS WERE DRY THIS MORNING Mr. Green
and all i had to do was sell my soul lol
Louise
PostPosted: 10:50 - 25 Jan 2008    Post subject: Reply with quote
Past week or so ive had to come home in bad weather. Relaxing dose help, take time to slow down sooner - my rear brake locks easy so I use 50/50 in the rain.
Almost lost the bike on a wet drain on a corner.
Im used to it now, rain used to worrie me alot at first, now I take it as it comes.
As for wind, be extra carefull on flyovers - Once I have been pushed into the other lane when I first got a 600, then the other last week where I almost went into the barrier.
ken
PostPosted: 11:14 - 25 Jan 2008    Post subject: Reply with quote
Don't know if anyone else does this. I let my tyres down a couple of pounds in the winter months (although I don't ride much in winter) as It gets them warmer quicker and less liable to skid, wash out.
And the valid points about, relaxing whilst still keeping total concentration at all times.
latest bike 03 R1 in zee red and black
mrbluesbox
PostPosted: 11:28 - 25 Jan 2008    Post subject: Reply with quote
Cant believe i didnt think of that. not checked my trye pressure in a while and the last time i did they were over inflated cos i had the missus on the back.
ill be sorting that out at dinner cos that bound to have affected the bike - especially in the wet Thumbs Up
Walloper
PostPosted: 16:16 - 25 Jan 2008    Post subject: Reply with quote
Oh I'm sure she will be impressed if she knows how much you love her.
Is she a bit of a Heifer like? Shocked Wink
Low pressure will increase footprint slightly. But hardly worth the bother. Road tyre heat up normally pretty quickly anyway.
I ride all year round and never adjust pressure from std.
But if you want to.....
Kal
PostPosted: 16:34 - 25 Jan 2008    Post subject: Reply with quote
Dress warm
It dosn't make you a sissy or a girl - it's a safety issue.
If you are cold then you will be thinking about that instead of what is happeing around you, and if you get very cold your thinking processes (assuming you aren't a troll Smile) and reactions will slow.
Midway through my first winter I got my first cold weather gear and I was surprised at the difference it made to my riding.
Kal...
mrbluesbox
PostPosted: 16:37 - 25 Jan 2008    Post subject: Reply with quote
heheh not exactly - shes only 5 foot 4 and about 8.5 stone - shed kick my ass if she saw that though Smile
was just going off what they haynes manual sed - and pressure ent up 5psi at rear and 4 at the front.
is it not worth bothering in future if i carry a pillion?[/quote]
Walloper
PostPosted: 16:49 - 25 Jan 2008    Post subject: Reply with quote
[/quote]
I took a Triumph Sprint ST awe aroon the Scottish Highlands last summer (after the rain went off) with enough shite stowed on board to overload a 3 1/2 ton army truck. I never touched suspension or tyre pressures. I just made sure they were at the book spec. Maybe I'm a shite rider and never notice the subtle difference. Embarassed
A heated jacket is a very gay and superbly cosy companion to invest in (no pun). About 120 smackers. Gilia or Evo or somewhere. I use one. Better than sex it is.
Feasty
PostPosted: 16:56 - 25 Jan 2008    Post subject: Reply with quote
You wanna try riding my XR125 in this crap weather, especially last couple of days in the gales! Shocked Feels like I'm sailing rather than riding, and the cornering is sooo much slower - just in case that odd gust of wind decides to come and kick the bike out from underneath me as I'm leaning...
I've also gone through a few BIG puddles expecting the steering to be taken from my hands or something like in the car, didn't feel a thing though! Laughing (Apart from my bike boots that have now been smelly and damp for the past few days) Sick
Previous: Aprilia Habana Retro 50cc (beauty), Yamaha SR125 (fell apart), Honda XR125 (nippy little commuter), Honda SLR650 (Geewhizz), Yamaha Diversion 900S (Smoooooth) written off courtesy of a stupid escaped horse.
(7 year gap), BMW F650 (Relaxing ride). Aprilia Caponord ETV1000 (Big and bold). Yamaha FZS600 (got me in trouble too quick!).
Current: Yamaha TDM 900 (Comfy, light but big, power when needed).
The last post was made 18 years, 255 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.33 - MySQL Queries: 13 - Page Size: 139.69 Kb
