Dodgy Handling
numark1
Scared of girls
PostPosted: 00:04 - 25 Jan 2008    Post subject: Dodgy Handling Reply with quote
Recently i have noticed when leaning my bike after a certain degree of lean the rear tyre feels like it has let go (ie is flat) and the rear end feels really soft and squidgy like its about to fall over.
Any ideas?? Pressure is ok, doesn't feel squared off. Maybe rear shock?? Bearings??
Walloper
PostPosted: 00:23 - 25 Jan 2008    Post subject: Reply with quote
Alignment OK?
Tyre damaged?
Shock is easy to check by bouncing the back end down. If gubbed it will jiggle up and down on the spring.
No more help. I did have my 10 shillings on not enough air in the tyre till you fuked that one up for me. Sad
SoND
PostPosted: 00:26 - 25 Jan 2008    Post subject: Reply with quote
Hold the bike still and start pulling and twisting at the wheel checking for play. You'll be able to see if the wheel bearings have went or the bushings in the swingarm.
You sure the tyre isn't squared? When you say 'feel' do you mean when you felt it by hand or by feel when you're riding it?
alun111
I'd check your rear shock for oil leaks and get the bike on it's center stand/paddock stand and give the wheel a spin and tug at the swing arm from side to side - there should be no movement.
You should be able to tell if the back tyre's squared off, by looking at it. Link
brianmcewan.co.uk
PostPosted: 00:34 - 25 Jan 2008    Post subject: Reply with quote
Did you kill that kitten?!
Kawasaki Z1000 '05
Honda Fireblade 954 '03
numark1
Scared of girls
PostPosted: 00:35 - 25 Jan 2008    Post subject: Reply with quote
Well they tyre itself doesn't feel squared and i have had square tyres before and normally it feels quite stiff to steer then when its past the squared edge dips in. However the steering feels fine up to a point until suddenly the tyre feels flat and like its about to cave in. Confused
Walloper
PostPosted: 00:42 - 25 Jan 2008    Post subject: Reply with quote
You are hiding something from us.
What have you been tamperfering with before the simptimz developed?
Come on, you can tell us.... Laughing
numark1
Scared of girls
PostPosted: 01:21 - 25 Jan 2008    Post subject: Reply with quote
Tyre was punctured ages ago and used that spray stuff to seal it. Had been fine for ages - thats about it. Jacked up the rear end quite a bit even longer ago, just seems quite recent. Confused
Could it be shite from the road out the outskirts causing it to become slippy??? might give the tyres a wash tomorrow see if that helps Confused
Walloper
PostPosted: 10:11 - 25 Jan 2008    Post subject: Reply with quote
Salt on the road?
I give in now. Crying or Very sad Smile
numark1
Scared of girls
PostPosted: 11:41 - 26 Jan 2008    Post subject: Reply with quote
Cleaned up the back tyre and that seems to have sorted it. Must have had something dodgy on it Confused
Walloper
PostPosted: 13:17 - 26 Jan 2008    Post subject: Reply with quote
Fuck did you not try-
[email protected]
The last post was made 18 years, 275 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 1.52 - MySQL Queries: 13 - Page Size: 70.16 Kb
