so i took my exhausts off...
c_dug
PostPosted: 22:03 - 11 Feb 2008    Post subject: so i took my exhausts off... Reply with quote
turned them upside down and out came about half a litre of petrol and oil, from each one! that'l explain why it wouldnt start, feck knows how it got there though!
any ideas?
c_dug
craigs23
Mr Muscle
PostPosted: 22:22 - 11 Feb 2008    Post subject: Reply with quote
What do the plugs look like?
CaNsA
PostPosted: 22:24 - 11 Feb 2008    Post subject: Reply with quote
The one legged space pigeons put it there.
Cheers for finding it though matey, u have thwarted their plan of world domination
Thumbs Up Thumbs Up Thumbs Up Thumbs Up Thumbs Up
c_dug
PostPosted: 22:32 - 11 Feb 2008    Post subject: Reply with quote
wtf?????
and the plugs were oily but i think that is from repetitivley being kicked over but not having the back pressure to fire, it was effectivly fluid locking the engine in the end!
I got fed up and decided to move onto fixing the small hole in the exhause and out gushes alot of petrol and oil so i took off the 2nd one and more comes out of that Confused it was running fine a few days before so i dont know how it got in there and especialy how that much got in there!
c_dug
Scouse
PostPosted: 22:44 - 11 Feb 2008    Post subject: Reply with quote
Bet you'd of appreciated a reply like that in one of your many question/I'm getting threads. Razz
Ariel Badger
Float leaking, do you leave it with the tap on?
PostPosted: 22:46 - 11 Feb 2008    Post subject: Reply with quote
Usually, it happens where a fuel tap is left on and a float valve leaks in the carbs. Fuel over-flow in the carb and fills up in the crank case then gets pumped into the exhaust when you crank the engine.
Ariel Badger
PostPosted: 22:49 - 11 Feb 2008    Post subject: Reply with quote
If you have fuel in the cases the oil will be as thin and as much use as a lubricant as piss. You need to drain it all off.
PostPosted: 22:57 - 11 Feb 2008    Post subject: Reply with quote
Both his bikes listed in his sig are 2-strokes Wal.
Ariel Badger
PostPosted: 23:03 - 11 Feb 2008    Post subject: Reply with quote
My mistake.
Finglonga
PostPosted: 23:06 - 11 Feb 2008    Post subject: Reply with quote
It also says the TDR250 now works? Confused Wink
Sump could still be full of fuel . . . undiluted fuel . . . . BOOM!
Andy Sez....
F.Y.Y.F.F.
c_dug
PostPosted: 00:52 - 12 Feb 2008    Post subject: Reply with quote
well it did work before Laughing the float bowl might be stuck, the carb was overflowing but it seemed to stop, i guess it may have stuck again Confused
The tap doesnt have an off setting just on/reserve/the other one that i dont remember the name of for putting fluel strait into the float bowls.
I dont think its the float anyway because both exhausts were full but only one float was stuck, im off college tomorrow so ill get the pipes sorted in the morning and then get them back on in the evening and see if she runs, then ill leave it over night and check the pipes in the morning and see whats happened, fingers crosses they're both empty.
cheers for the help so far Thumbs Up
c_dug
mattish
PostPosted: 02:33 - 12 Feb 2008    Post subject: Reply with quote
exactly the same happened to my rd before it got stolen, happened after i fould the plugs and couldnt start it but kept trying Laughing
left a nasty smelly stain on my jeans Embarassed
c_dug
PostPosted: 03:34 - 12 Feb 2008    Post subject: Reply with quote
Snap on the situation, that must be it then, i left it on tickover for about 20mins and it coughed and sputtered and stopped and it wouldnt go again no matter how many times i tried, must have been slowly filling up the pipes! glad to hear it doesnt sound more serious.
c_dug
dont know why i didnt put this is the workshop section Laughing
Kiss_My_Rs
PostPosted: 05:19 - 12 Feb 2008    Post subject: Reply with quote
c_dug
Prime postion?
Take it its a vacuum tap. So very doubtfull that this is the problem as it wont leak unless its in the Prime Postion.
Http://www.manchesterbikers.net
dougon2wheels
PostPosted: 10:24 - 12 Feb 2008    Post subject: Reply with quote
c_dug
quality bike there,right colour aswell Thumbs Up ,most likley culprit is worn float needle seals/and /or leaking O rings on the float needle seats.the fuel taps are vacuum operated but once the seals get old they tend to weep fuel,after that your relying on the float needles to stop the fuel filling the engine.
i'm sure i have a set of the float needle seat O rings around somewhere(you can only get the matched full set from yam),shout if you need them.
c_dug
PostPosted: 13:56 - 12 Feb 2008    Post subject: Reply with quote
yep Thumbs Up everybody knows the black ones are quickest Laughing
im about to head out to the bike now and sort the holes in the exahaust's, the stuff im using takes at least 8 hours to set so ill have stick the pipes back on tonight and see what the results are tomorrow Thumbs Up if i do need the o rings ill PM you, thanks for the offer Thumbs Up
c_dug
The last post was made 18 years, 265 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.56 - MySQL Queries: 13 - Page Size: 101.55 Kb
