| 5v3d3b0 |
 5v3d3b0 World Chat Champion
| funmonkee |
 funmonkee Super Spammer
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 01:17 - 13 Feb 2008 Post subject: |
its bollocks i reckon...
fuel starvation results in spluttering and misfire. do you get that when your low on fuel? no... only when your empty.
unless on his bike, the nitro powder settles to the bottom of the tank so he gets more power  ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| 5v3d3b0 |
| MaybeGuy |
 Posted: 01:24 - 13 Feb 2008 Post subject: |
where does he get this brand new petrol from?  ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| v8drover |
 v8drover Derestricted Danger
| wristjob |
 wristjob World Chat Champion
| gmanxiii |
 gmanxiii World Chat Champion
| 5v3d3b0 |
| ZRX61 |
 ZRX61 Victor Meldrew
| MaybeGuy |
| v8drover |
| MaybeGuy |
| 5v3d3b0 |
| ZRX61 |
| v8drover |
| v8drover |
| ZRX61 |
| MarJay |
 MarJay But it's British!
| Jack_Cheese |
 Jack_Cheese World Chat Champion
 Posted: 10:17 - 13 Feb 2008 Post subject: |
| Gmanxiii wrote: | If you have two containers one big one small with exactly the same size put a hole in the bottom. Fill both with water, the flow rate would still be the same regardless of the volume of water. |
Wrong. The deeper a body of fluid is, the higher the pressure at the bottom will be when compared to a shallower body of equal density fluid.
The ammount of fuel in the tank will impact on flow rate to the carb. If you have ever drained a tank, then you will know this. Any change will impact primarily on the float bowl. The float bowl will effectively regulate the fuel flow rate to the jets, provided the fuel flow rate to the bowl is equal to, or higher than, the flow rate from the carb to the engine at any given engine speed.
If the carb is tuned so that the optimum flow rate is achieved on a full tank, then there will be a difference in flow rate to the carb, and consequently the engine when the tank is low. If the carb is tuned so that optimum flow rate is achieved on a low tank (with consequently lower fuel pressure than a full tank) then optimum flow rate will be maintained by the float bowl when there is more fuel in the tank.
The depth of the tank also impacts on this. As stated above, the deeper a body of fluid is, the higher the pressure will be at the bottom. So a taller tank means higher pressure, and faster fuel flow. For the same reason, the height of the tank above the carb will also have an impact, as the fuel lines will also contain the fluid, meaning they should also be factored in when referring to the pressure exerted as a result of the depth.
The temperature will have very little impact on flow rate. If the temperature increases causing more fuel to evaporate, it will simply escape through the breather hole in the tank necessary to prevent a vacuum in the tank, and consequent fuel starvation. Temperature would only become a factor if it impacted the fuel's viscosity, and we're never going to experience temperatures that low. The one exception to this is carb icing. The carb ices up due to the low pressure in the venturi combined with low temperatures causing gaseous water to condense from the air and form ice in the carburettor, restricting air/fuel flow.
Jack ____________________ www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!" |
| gmanxiii |
 Posted: 10:23 - 13 Feb 2008 Post subject: |
| Jack_Cheese wrote: | | Gmanxiii wrote: | If you have two containers one big one small with exactly the same size put a hole in the bottom. Fill both with water, the flow rate would still be the same regardless of the volume of water. |
Jack |
I stand corrected ____________________ I kills hondas
VFR400NC30 > ZZR600 > CBR600FX > CBR1000rr |
| Wafer_Thin_Ham |
 Wafer_Thin_Ham Super Spammer
| Jack_Cheese |
 Posted: 10:30 - 13 Feb 2008 Post subject: |
By the way, if the ammount of fuel in the tank is affecting his performance, then i suggest he sorts his carb out! ____________________ www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
| benvanwell |
 benvanwell Nitrous Nuisance
| Walloper |
 Walloper Super Spammer
The last post was made 18 years, 58 days ago. Instead of replying here, would creating a new thread be more useful? |
