A mate of mine claims that:
5v3d3b0
PostPosted: 01:10 - 13 Feb 2008    Post subject: A mate of mine claims that: Reply with quote
Bikes that are carburated have more power with a full tank than with an almost empty tank because of the pressure applied by the petrol causing more to go in.
Sounds like a load of bollocks to me. Anyone agree with him or am I right?
funmonkee
PostPosted: 01:12 - 13 Feb 2008    Post subject: Reply with quote
carb icing Wink Laughing
...seems to be the answer to everything these days
**** Don't ride faster than your angel can fly Get this Free Space
The democratically elected Mod of the Scottish Section - The Peoples Choice[b]
MaybeGuy
PostPosted: 01:17 - 13 Feb 2008    Post subject: Reply with quote
its bollocks i reckon...
fuel starvation results in spluttering and misfire. do you get that when your low on fuel? no... only when your empty.
unless on his bike, the nitro powder settles to the bottom of the tank so he gets more power Wink
5v3d3b0
PostPosted: 01:19 - 13 Feb 2008    Post subject: Reply with quote
Well I guess he means it'd be running slightly richer...But that's impossible cause then how would you fine tune the carb accurately...
I think the reason it feels faster is cause it's brand new petrol which is colder than the one in the tank, hece more dense, more energy per cc...
MaybeGuy
PostPosted: 01:24 - 13 Feb 2008    Post subject: Reply with quote
where does he get this brand new petrol from? Very Happy
v8drover
PostPosted: 01:25 - 13 Feb 2008    Post subject: Reply with quote
Definatly a load of bollx. Big carb'd bikes have fuel pumps cause gravity/vacuum fed would cause fuel starvation.
wristjob
PostPosted: 01:26 - 13 Feb 2008    Post subject: Reply with quote
total balls.
a carb works by air sucking the fuel out of the jets,so as long as the float chamber is full the amount in the tank has nothing to do with it.
if fuel pressure is to high you will either get depending on the system)fuel returned to the tank,pissed out onto the road or just massive overfueling with the loss of power that goes with it.
gmanxiii
PostPosted: 01:27 - 13 Feb 2008    Post subject: Reply with quote
I think it would only start running rich or leaner if theres change in atmospheric pressure. Otherwise the pressure stays the same.
If you have two containers one big one small with exactly the same size put a hole in the bottom. Fill both with water, the flow rate would still be the same regardless of the volume of water.
I kills hondas
VFR400NC30 > ZZR600 > CBR600FX > CBR1000rr
5v3d3b0
It's a 125 we're talking about if it makes any difference. I think the petrol being cold does have some credibility though
ZRX61
Victor Meldrew
PostPosted: 01:28 - 13 Feb 2008    Post subject: Reply with quote
WTF? where the hell did you get that idea??? Rolling Eyes
MaybeGuy
this friend of yours... is it you?
you seem awefully defensive about the whole thing Very Happy
v8drover
PostPosted: 01:30 - 13 Feb 2008    Post subject: Reply with quote
More truth than idea, my 97 cbr6 has a fuel pump!
MaybeGuy
PostPosted: 01:33 - 13 Feb 2008    Post subject: Reply with quote
whereas an early GSXR1100 doesnt. if they want more fuel flow to the carbs, they just use fatter fuel pipes.
5v3d3b0
It's a friend who thinks the volume of petrol counts, and it's me who thinks the TEMPERATURE of the petrol counts.
I'm not like those gayboys who can't stand up for their own beliefs. If I would have thought of his idea I would have stated it
ZRX61
Victor Meldrew
PostPosted: 01:36 - 13 Feb 2008    Post subject: Reply with quote
Since when did a 600 become a "big" bike????
& the reason some carbed bikes have fuel pumps is usually because the bottom of the tank is lower than the float bowls...
v8drover
PostPosted: 01:37 - 13 Feb 2008    Post subject: Reply with quote
fair point.
v8drover
PostPosted: 01:40 - 13 Feb 2008    Post subject: Reply with quote
Think you may find that many people consider a 600 a big bike, manufacturers including. But the everything is comparative, mateys gixxer thou is a small bike compared to a Rocket III.
ZRX61
Victor Meldrew
PostPosted: 02:37 - 13 Feb 2008    Post subject: Reply with quote
That must be why they all list them as "middleweights" then? Wink
PostPosted: 10:13 - 13 Feb 2008    Post subject: Reply with quote
The whole point of a float chamber is to make sure that too much fuel doesn't get to the carbs.
The float chamber is basically a regulator which backs up the regulation which is provided by the jet.
So there is no way more fuel could get into the engine just due to gravity pressure. If that were the case, then the engine would run rich and make less power.
As previously said, the speed at which a liquid flows through a hole in a bowl of water doesn't change if the bowl is full or nearly empty anyway.
Jack_Cheese
PostPosted: 10:17 - 13 Feb 2008    Post subject: Reply with quote
Wrong. The deeper a body of fluid is, the higher the pressure at the bottom will be when compared to a shallower body of equal density fluid.
The ammount of fuel in the tank will impact on flow rate to the carb. If you have ever drained a tank, then you will know this. Any change will impact primarily on the float bowl. The float bowl will effectively regulate the fuel flow rate to the jets, provided the fuel flow rate to the bowl is equal to, or higher than, the flow rate from the carb to the engine at any given engine speed.
If the carb is tuned so that the optimum flow rate is achieved on a full tank, then there will be a difference in flow rate to the carb, and consequently the engine when the tank is low. If the carb is tuned so that optimum flow rate is achieved on a low tank (with consequently lower fuel pressure than a full tank) then optimum flow rate will be maintained by the float bowl when there is more fuel in the tank.
The depth of the tank also impacts on this. As stated above, the deeper a body of fluid is, the higher the pressure will be at the bottom. So a taller tank means higher pressure, and faster fuel flow. For the same reason, the height of the tank above the carb will also have an impact, as the fuel lines will also contain the fluid, meaning they should also be factored in when referring to the pressure exerted as a result of the depth.
The temperature will have very little impact on flow rate. If the temperature increases causing more fuel to evaporate, it will simply escape through the breather hole in the tank necessary to prevent a vacuum in the tank, and consequent fuel starvation. Temperature would only become a factor if it impacted the fuel's viscosity, and we're never going to experience temperatures that low. The one exception to this is carb icing. The carb ices up due to the low pressure in the venturi combined with low temperatures causing gaseous water to condense from the air and form ice in the carburettor, restricting air/fuel flow.
Jack
www.bikepics.com/members/jackcheese <--- NOW FOR SALE! 51 Plate Cagiva Planet 125
Quacker_boy: "Jack, you really are a dick!"
gmanxiii
PostPosted: 10:23 - 13 Feb 2008    Post subject: Reply with quote
Jack
I stand corrected
I kills hondas
PostPosted: 10:27 - 13 Feb 2008    Post subject: Reply with quote
Yes, temperature does make a difference to power, but not a great deal to the volume, hence charge coolers on some drag bikes.
Jack_Cheese
PostPosted: 10:30 - 13 Feb 2008    Post subject: Reply with quote
By the way, if the ammount of fuel in the tank is affecting his performance, then i suggest he sorts his carb out!
benvanwell
PostPosted: 11:58 - 13 Feb 2008    Post subject: Reply with quote
The temperature change will affect the density of fuel; lower temperature means more fuel per unit volume. For a fixed flow rate, and assuming all the fuel was burnt effectively then you could experience a slight power gain at lower temperatures.
The same reasoning applies to "justify" filling up at night. You pay for fuel by volume and when it's colder you get more bang for your buck.
Currently Riding: Triumph Sprint ST 1050
Previous: GSF600s, GS500, BMW F45, CG125
Walloper
PostPosted: 12:13 - 13 Feb 2008    Post subject: Reply with quote
wristjob wrote:
total balls.
Do not spread cream over the balls..
A carburettor works by creating a vacuum.
The fuel is PUSHED into that vacuum by atmospheric pressure and or assistance from a fuel pump.
The last post was made 18 years, 57 days ago. Instead of replying here, would creating a new thread be more useful?
Goto page 1, 2, 3, 4  Next
Page 1 of 4
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.18 - MySQL Queries: 13 - Page Size: 134.45 Kb
