very urgent!!, Got a Leak, only transport i have
5NSR
PostPosted: 16:13 - 13 Feb 2008    Post subject: very urgent!!, Got a Leak, only transport i have Reply with quote
i have sprung a leak Rolling Eyes
where the fuel line attaches to the petrol switch, everything looks in order but as soon as i turn the petrol on it pours out, the clip seems tight enough. and this has only just happened over night so i have no idea what the problem could be. i have just fitted the hootaz twin horn system under the petrol tank, but i have checked the fuel line and there are no cracks and no pinches through the line to cause it to come back up. very very urgent, its my only form of transport. please help
My Bike: NSR125 1998, 1up+1down performance sprocket set, Heavy Duty Japanese Chain, k&n air filter, Full arrow race exhaust system, fully de-restricted.
thegubner
PostPosted: 16:20 - 13 Feb 2008    Post subject: Reply with quote
Is it sealed correctly where it joins either end?
You could have pulled it loose when fiddling about.
5NSR
PostPosted: 16:36 - 13 Feb 2008    Post subject: Reply with quote
yes, its attached firmly at each end, i have pinched the clips with pliers at each end of the hose without blocking the flow, but it is still leaking. its as if the petrol is going into the hose, but not going anywhere and backing up. i think it could be a pinch or something but as i say i have checked the full length of the hose and it all seems fine. its really confusing me.
iooi
PostPosted: 17:07 - 13 Feb 2008    Post subject: Reply with quote
Switch the tap off, pull pipe off and have a look at the ends, good chance its just split. Leaves you with 2 choices. EIther snip the end off if its long enough or nip to local parts shop and get some new pipe. Best stuff is the clear reinforced tubing, you can see the petrol in it then.
thegubner
PostPosted: 18:09 - 13 Feb 2008    Post subject: Reply with quote
Backing up? Is there a blockage?
Ichy
PostPosted: 20:16 - 13 Feb 2008    Post subject: Reply with quote
Yes, its called a needle valve. Its supposed to do that.
Just fit a new pipe.
The last post was made 18 years, 254 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 1.32 - MySQL Queries: 13 - Page Size: 47.65 Kb
