rs 125 help plzzzzzzzzzzzzzzzzz
jezrob81
PostPosted: 18:28 - 13 Feb 2008    Post subject: rs 125 help plzzzzzzzzzzzzzzzzz Reply with quote
hi there i have just purchesed a engine for my rs 125 fitted it all running except i have a rattle from the engine i think it may be coming from the top end but not sure any ideas anyone????
parkin
PostPosted: 18:43 - 13 Feb 2008    Post subject: Reply with quote
Ok rs125 rattle could be caused by a variety of things chances of it been top end are slight it could be a loose power valve cover, or the piston could be detonating Shocked , easiest way to check is to lift the cylinder head off and look at the crown of the piston and see if it looks like its been shot blasted around the edge, if so then its getting hot and your getting premature ignition. Mr. Green
does it start on start up and at tick over and stop when you raise the revs?
if so it could be the generator behind the right hand casing cover these are a a pig if they have been forced off as they use an interference fit to keep them steady and then lock on with a nut the woodruf key just helps line up the timing. check to see if it loose.
or if it doesnt rev and you get a really big vibration check the balance shaft timing gears behind the left hand casing these are only nylon/plastic and if one toothe is missing that will throw it out.
if niether of them post back and ill see if i can help any further
parkin
veze
PostPosted: 19:51 - 13 Feb 2008    Post subject: Reply with quote
where did u get the engine from? what condition? is it rotax 122 or 123?
tlm50,mt5,sr50. rs125 extrema, cbr 400rr nc29 suzuki gs500e.Honda cbx250 rs . FJ1200 .fz6,fjr1300
The last post was made 18 years, 150 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.89 - MySQL Queries: 13 - Page Size: 35.68 Kb
