Front paddock stands - I think im being stupid
faddius
PostPosted: 18:40 - 13 Feb 2008    Post subject: Front paddock stands - I think im being stupid Reply with quote
How is a front paddock stand meant to sit underneath the front forks?
Everytime I try raising the bike with the stand in the right place (according to my mind) it keeps coming close to sliding off the prong that sits under the fork, just keeps sliding forwards.
Im really confused, if anyone could tell me where the prongs are meant to sit on the fork or show me a diagram id greatly appreciate it.
Thanks.
Heres an image of a similar paddock stand
https://www.fastbikebits.com/acatalog/paddock_stand_front.jpg
Children in the back of cars cause accidents : Accidents in the back of cars cause children
Riding since OCT '05 - Sym Jet 50cc, Honda Varadero 125cc, Suzuki GS500, Honda VFR750, SV650s current & in posession of Aprilia RS125, Honda NS125R
cheekythomas
PostPosted: 18:49 - 13 Feb 2008    Post subject: Reply with quote
On that style of stand, one prong should go under the fork bottom, the other behind it....
Like this very dodgy picture ive done Laughing
https://img172.imageshack.us/img172/6351/roughpic1nk3.jpg
You can also get ones with prongs to locate into the holes in the bottom of some forks, or those that fix to the steering tube and allow the forks to be removed completely.
Personally i use a Abba stand which lifts the bike from the engine mountings in the frame as its the most stable solution and a doddle to do by yourself.
faddius
PostPosted: 18:55 - 13 Feb 2008    Post subject: Reply with quote
Thats how I keep trying to lift the front wheel but the stand keeps turning allowing the forks to slide till the bottum prong is about to slide off the back of the fork, which would cause the bike to fall.
Thats why I thought I must be doing something wrong.
NSR Mick
PostPosted: 19:00 - 13 Feb 2008    Post subject: Reply with quote
Are the pronged parts sided. You may have them on the wrong sides.
cheekythomas
PostPosted: 19:01 - 13 Feb 2008    Post subject: Reply with quote
I assume its on a rear stand as well as thats common sense...
It takes time and practice and thats all..
faddius
PostPosted: 19:16 - 13 Feb 2008    Post subject: Reply with quote
Thats an idea ill try swapping round the prongs tomorrow and try them on the opposite sides, see if that makes a difference.
Yes it is on a rear stand Thumbs Up
Thanks for the help so far all.
Walloper
PostPosted: 19:59 - 13 Feb 2008    Post subject: Reply with quote
We need a section on here just for folk who canny live with the fancy Kit they buy.... Razz
Be careful. If it falls on you and you lose a finger it will Chafe.
But worse if it marks the paint on the tank.
faddius
PostPosted: 20:48 - 13 Feb 2008    Post subject: Reply with quote
Its not fancy kit, its complicated high tech kit that I fail to understand or comprehend in all of its complicatedness.
I only just mastered bricks under the forks Confused
Walloper
PostPosted: 21:18 - 13 Feb 2008    Post subject: Reply with quote
House brick?
Common or facing?
Engineering is actually the best. Mr. Green
But I am with you on the complexity thing. Even bliddy bricks have three height adjustments. Shocked Wink
faddius
PostPosted: 13:52 - 14 Feb 2008    Post subject: Reply with quote
House brick?
Common or facing?
Three height adjustments?!?!?!?! Common?!?! Facing?!?!?! Crap I havent even mastered the brick Shocked
crasher76
PostPosted: 19:43 - 16 Feb 2008    Post subject: Reply with quote
https://www.brspecialtuning.co.uk/Pit%20&%20Paddock.htm#Bike%20front%20paddock%20stand
note the front spigot is higher then the back one in this picture. They are bit of a bugger to operate and never feel 100% secure. get a couple of mates to hold a handlebar each if you feel uncertain the first time.
Valentino Mossy
PostPosted: 20:58 - 16 Feb 2008    Post subject: Reply with quote
This is what happened to my nc30 when mine "fell off ". Confused
Two of us to lift it up and one to put the stand back under..... Aint using the front stand on the gsxr, i rather buy an abba stand instead .... not taking the risk again !
Before :
https://i127.photobucket.com/albums/p138/lilldic_mossy/DSCF0782.jpg
After..... DOH ! (also after tarting it up a bit aswell !)
https://i127.photobucket.com/albums/p138/lilldic_mossy/DSC00022.jpg
PostPosted: 21:57 - 16 Feb 2008    Post subject: Reply with quote
I cut the prong things off mine and welded a socket on each side that was the right size to plug into my front spindle. Never liked the idea of them prongs.
The last post was made 18 years, 53 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.43 - MySQL Queries: 13 - Page Size: 80.72 Kb
