High fuel consumption?
tutton
PostPosted: 17:33 - 14 Feb 2008    Post subject: High fuel consumption? Reply with quote
Well right
my bikes only a 50cc.
I fill up with around 9 pounds of fuel on a tuesday
and it will use the whole tanks worth by thurs/friday
Im only doing about 30 miles... in that space of time
Ive taken my air filter off and cleaned the foam filters and resoaked with 2 stroke and put them back in,
Checked the plug and it was very clean, been in about 5 weeks, so its burning it all, but surely a 50cc shouldnt be drinking this much fuel?
Cheers alot
PostPosted: 17:50 - 14 Feb 2008    Post subject: Reply with quote
Yeah i think it should be better than that.
Maybe try looking for a leak.And check the overflow pipe from the carb.Might be that it's only leaking when it's running?
At the moment im riding a mallagutti phantom 100cc and i get about 70 miles from £5 quid.
Dave
DRZ-400sm
tutton
PostPosted: 17:52 - 14 Feb 2008    Post subject: Reply with quote
No leaks ive checked all the lines, and the carb when running and standing now.
Ye, i have mates with similar bikes and they get so many more miles.
I was thinking something carb related like mixture or jets or something?
PostPosted: 18:00 - 14 Feb 2008    Post subject: Reply with quote
I would have thought for the consumption to be that bad,the settings would have to be really far out.
Would probably be running like a bag of schite?
Sorry im not much help Very Happy
DRZ-400sm
tutton
PostPosted: 18:03 - 14 Feb 2008    Post subject: Reply with quote
I would of thought that to,
Its running good, but the amount of fuel its using is worrying for a small bike.
Getting 55 out of it at a push.
Which is making me think its jets, as its running perfect top end, just a bit slow on low end, like the powerband is late in the gears.
iooi
PostPosted: 19:38 - 14 Feb 2008    Post subject: Reply with quote
So approx 17 mpg.... Shocked
I would guess at you got a leak either in the tank or the pipe.
If it was the jets i would expect to see it choke itself.
deanoet
PostPosted: 21:36 - 14 Feb 2008    Post subject: Reply with quote
Only just got it havent you?
Not got any sort of warrenty on it?
That is the easy method. Thumbs Up
Pie-Roe
PostPosted: 22:25 - 14 Feb 2008    Post subject: Reply with quote
Got a prime setting on the fuel tap? That will lead to very high fuel consumption very quickly.
Pyro
tutton
PostPosted: 23:55 - 14 Feb 2008    Post subject: Reply with quote
Still under warrenty, but unless i get the bike up country about 300 miles i cant use the warrenty?
so its going to cost me more to get up there than get it fixed down here.
Uhhm there isnt a tap on these bikes surprisingly.
manual says some models do some dont, ive checked the fuel lines and there isnt one,
Any other ideas?
TUG
PostPosted: 00:24 - 15 Feb 2008    Post subject: Reply with quote
Any other ideas?
Where did you buy the bike from? are they not part of a big dealership ring as if you buy a yam, have a problem and is still in warrenty you can get it checked at any yamaha dealer ship not just the one you bought it from.
Is your float level not set up correctly? this will cause high fuel consumption as will a high idle mixture and incorrect needle posistion.
Haz ER-5, innit!
Grav
PostPosted: 00:26 - 15 Feb 2008    Post subject: Reply with quote
Either you have a seriously noticeable leak or someone is syphoning your tank.
Dark Lord Of Custard
snigger..... Very Happy
iooi
PostPosted: 07:22 - 15 Feb 2008    Post subject: Reply with quote
Pyro
Unless the floats are stuck and allowing fuel to leak away, prime should make no difference.
All prime does is bypass the vacuum part which keeps the tap closed. But if the floats are doing their job fuel will go no further.
Thom
PostPosted: 09:36 - 15 Feb 2008    Post subject: Reply with quote
I'm having a similar problem on my nsr, but im not sure why, i filled up with a tenner not too long back and yesterday when i was stripping the bike down the tanks only half full (at most!)
I feel as if its evaporating off because it's not leaking from anywhere.
but the bike has been standing with the fuel 'on' so mayeb thats it?
.Chris.
PostPosted: 14:29 - 15 Feb 2008    Post subject: Reply with quote
I'm pretty sure the air filter shouldn't be soaked in any oil, let alone 2-stroke. This will most likely have blocked up the filter and made the mixture incredibly rich.
Foam type ones normally have to be washed with petrol, left to dry and then have oil carefully applied and then squeezed out.
Chris
1985 Kawasaki Z550F
Pie-Roe
PostPosted: 18:30 - 15 Feb 2008    Post subject: Reply with quote
iooi wrote:
Pyro
Oh, I see. I was led to believe that leaving it on prime would use a lot of fuel. Oops Embarassed
Pyro
tutton
PostPosted: 20:19 - 15 Feb 2008    Post subject: Reply with quote
Wish mine would run on 50ps worth of fuel haha
The siphoning could be a issue, but i see it as unlikely, as its in a college carpark where people are out and in regularlly?
No leaks ive checked all the pipes, from the vaccume etc all fine.
Recently the carb went in a shop for a decoke/clean as the needle was stuck and making all the fuel come out, no noticeable fuel coming out now, but is it possible the needle or float or whatever it is that controls the fueling is in the wrong position?
tutton
PostPosted: 20:48 - 15 Feb 2008    Post subject: Reply with quote
https://www.beedspeed.com/images/thumbnails/150_images_petrol-tap-auto-0020.jpg
Mine looks like that, although its not a tap
there is no settings for primed, reserve etc.
always on.. thats like poking from the bottom of the tank..
the manual says some bikes have them some dont, and as far as the lines show i dont have one...
its running good but i guess thats because its running so rich?
tutton
PostPosted: 20:51 - 15 Feb 2008    Post subject: Reply with quote
Plugs clean, looked at that.
so clean when i took it out, i didnt need to clean it off haha =]
5 weeks old, and still giving good spark
Everything is pointing to needle or mixture?
The last post was made 18 years, 52 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.08 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 130 Kb
