What to look for when buying a '97 ZX6R?
Ghost
PostPosted: 09:59 - 15 Feb 2008    Post subject: What to look for when buying a '97 ZX6R? Reply with quote
Going to look at a P reg F3 (Thanks Beans) Ninja tomorrow and been doing a little research as to what I should be looking out for. Already found that the brakes are prone to repair and need regular rebuilds, discs can frequently warp, wheel bearings often need attention and the cam chain/tensioner can get a bit rattly on higher mileage engines, athough not a major problem. This example has covered approx 24k.
Was wondering if anyone here owns or used to own one and has got any idea if there's anything else specific to this bike I need to be aware of? Aside from the normal tyres/chain/sprocket and crash damage what else should I keep my eyes peeled for?
Thanks in advance Thumbs Up
https://i1.ebayimg.com/03/i/000/d8/d1/09e7_1.JPG
hmmmnz
PostPosted: 17:59 - 15 Feb 2008    Post subject: Reply with quote
oil leak from he sprocket cover (oil seal tends to go, but easy fix)
leak from sump plug. bastard if someone has over tightened and stuffed the thread.
the joins in the exhaust (original system) they rot badly, really they all should have been fitted with a stainless system.
head bearing (notchy steering) and electrics under tail.. they tend to get nice salty water spraying up from the rear wheel, and cause havoc to the cables.
they are good bikes. my old one served me well indeed Very Happy
the humans are dead
I kick arse for the lord
beans
PostPosted: 18:40 - 15 Feb 2008    Post subject: Reply with quote
Hi,
Thats an F3 or F2 ninja the G-models are near enough completly different bikes, 6 pot tokicos removeable subframe etc.
with the F- models look out for all of the above plus the oil cooler under the rad, they take a battering and often rot through. Valve clearances are every 7k so check the history for them being done. Rear shocks seize and are likely to be past its best at 24k.
picture of a G1 ninja
Yamaha FS1E- Suzuki RG 125 - Honda CB-1- Ducati Monster - Kawasaki ZX6-R F1- Kawasaki ZX6-R G1- 2003 Yamaha R6
Ghost
PostPosted: 22:08 - 15 Feb 2008    Post subject: Reply with quote
Okay, thank you both for your help, I must've got a bit confused with the different model terms. F being the first shape, G being more rounded at the front and J with the move to twin front headlights. I'll put some pictures up if I decide to go ahead and buy it. Out of interest how much do you think the above bike would be worth at that age and mileage? (1997 and 24k)
hmmmnz
PostPosted: 23:21 - 15 Feb 2008    Post subject: Reply with quote
at the very top 1200 quid i have seen them go for well under a grand
obviously its a buyers market, so if you can get extra tarty bits ect all the better Very Happy
the humans are dead
Ghost
PostPosted: 10:09 - 16 Feb 2008    Post subject: Reply with quote
Well this one's advertised at 950 but I'm hoping I can get him down some on that. Not much in the way of tarty bits except for new stainless brake lines, new chain, sprockets brake & fork seals. Going to look at it in an hour or two anyhow so we'll see.
spikenipple
PostPosted: 12:43 - 16 Feb 2008    Post subject: Reply with quote
How do you find them that cheap? All of the models on MCN/BikeTrader/eBay seem to be over £1200 as a general rule, even with a much higher mileage than this one you're looking at.
C50 > GN250 > XJ600 > SV650S K7 > 2001 RSV Mille R > MT-09, XR400R > 2005 Fireblade (trackbike) + 2022 MT-09 + ZXR400 race bike
konsoli
PostPosted: 13:37 - 16 Feb 2008    Post subject: Reply with quote
maybe it was in the local paper or something?
Ghost
PostPosted: 15:30 - 16 Feb 2008    Post subject: Reply with quote
Been to look at the bike and it's pretty clean and tidy, has a crack/hole in the front headlight that could do with replacing but otherwise in good nick. Engine starts and revs smoothly, no funny rattles or knocks, everythings clean with no corrosion or oil leaks and its got two brand new Pirelli Corsa tyres, Akrapovic can and Goodridge braided brake lines front and rear. Gonna test ride it tomorrow and if it all checks out it's mine Smile
And Spike, in my experience Autotrader and the likes are pretty overpriced, people set their asking prices with room for negotiation so you're unlikely to find anything <£1000. Parkers bike guide for this model lists the value as £975 - £1200 depending on condition, so I think this one's a pretty good deal.
Willenium
PostPosted: 13:02 - 18 Feb 2008    Post subject: Reply with quote
Look for the usual things like dead bearings and corrosion etc. Also look for a good garage to get your valve clearance inspections every 4k.
The last post was made 18 years, 42 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.56 - MySQL Queries: 13 - Page Size: 66.1 Kb
