Wahing wool
Ariel Badger
PostPosted: 11:37 - 23 Feb 2008    Post subject: Wahing wool Reply with quote
I need to wash two jumpers, they have oil, blood and general grime on them.
My washing machine has three wool settings
10. Delicate Wash 40
11. Main Wash 40
12. Mini Wash 30
There is also a cotton setting
5. Cold Wash
Any idea which I should use and should I use washing powder or washing up
liquid? I do know about not putting petrol in washing machines BTW.
W
Quote Me Happy
PostPosted: 11:48 - 23 Feb 2008    Post subject: Reply with quote
I hate wool jumpers, I had one once.
It just kept getting smaller and smaller, I thought I was just getting fatter and fatter.
Until one day I realised it would barely be big enough for a five year old child to wear.
Washing, women's stuff.
Ariel Badger
PostPosted: 11:54 - 23 Feb 2008    Post subject: Reply with quote
Well they are about £150s worth between them so I do not want to shag things up. I could go and ask Mrs P next door but she is Pakistani and Asians do not wear much wool.
My mate just called and said use the delicate setting and no washing up liquid, think that sounds good?
Cigaro
PostPosted: 12:05 - 23 Feb 2008    Post subject: Reply with quote
I just wash mine with all the other clothes on a normal wash, but then they may be partly synthetic.
EuropeanNC30R...
Gay Hairdresser
PostPosted: 12:10 - 23 Feb 2008    Post subject: Reply with quote
I'd be inclined to go for the 30 degree mini wash, it might not totally clean them but less chance of them shrinking to toddler size.
Ariel Badger
PostPosted: 12:11 - 23 Feb 2008    Post subject: Reply with quote
Fingers crossed, they are in the machine.
Ariel Badger
PostPosted: 12:19 - 23 Feb 2008    Post subject: Reply with quote
I am not 100% sure if the 40/30 is temperature or time.
lozzypop1
Certified MILF!
PostPosted: 12:23 - 23 Feb 2008    Post subject: Reply with quote
Laughing Boys......
What are you doing wearing £150 worth of jumpers when you're going to get blood/oil/grime on yourself??
:insert wagging finger smiley here:
It should be the temperature.
You should be ok Ariel... might be worth you getting some 'Vanish' or other stain removal stuff for the future.
Ariel Badger
PostPosted: 12:33 - 23 Feb 2008    Post subject: Reply with quote
Well each jumper is £75 so it is not as bad as it seems.
I was wearing the one jumper when I crashed and the other when I fixed the bike.
Dragonfly
PostPosted: 12:41 - 23 Feb 2008    Post subject: Reply with quote
Woollite, delicate wash no spin. NO tumble dryer!
All the breast.
Muzza on Binge:
Ariel Badger
PostPosted: 13:08 - 23 Feb 2008    Post subject: Reply with quote
Seems to have worked OK, they have not shrunk and the grime is gone Very Happy .
Is it OK to dry over a radiator hanging on a hanger?
hellkat
PostPosted: 13:22 - 23 Feb 2008    Post subject: Reply with quote
Better dried flat on a towel, matey.
Hanging it up will pull it out of shape with the weight of the water.
pyx_e
PostPosted: 13:35 - 23 Feb 2008    Post subject: Reply with quote
lozzypop1 wrote:
Laughing Boys......
every wants to insert fingers in you, what a guy
Shiney!
Kawasaki: ER5, Versys, VN900.
Walloper
PostPosted: 13:53 - 23 Feb 2008    Post subject: Reply with quote
Dragonfly hunny, will you marry me?
I love a woman who knows awe the secrets of a wool wash. Laughing
1930 Ariel,
You can wash wool by hand or delicate low temperature.
The problem with wool is that the fabric is fragile and can be damaged by too much agitation and heat.
Short low speed spin should be fine and hang to dry but make sure the garment is adequately supported. IE the sleeves are not dragging on the ground.....
Heat is not a good idea as this will cause shrinkage.
After its dry it is best to iron (at 'Wool' temp **) this allows the wool fibers to be re-aligned and the garment will resume it's best shape.
Balling can be removed by hand or using any one of several machines available on the market.
You may want to consider marrying a 'Good Woman' (Which these days is very hard to find.)
Or alternatively, buy a new wardrobe and go out for a run on the bike instead.
And be careful using detergents. These strip the oils from your skin which promotes dermatitis. After contact, wash thoroughly using a good quality hand soap, dry and moisturise.
And follow the garment 'Care Instruction' label or ask the retailer. Wink
hellkat
PostPosted: 13:57 - 23 Feb 2008    Post subject: Reply with quote
I have to admit, I wouldnt wash DECENT* wool things in the machine at all.
You're better off soaking them for half an hour in that flakey soap stuff and then hand washing them, rubbing the stain out.
Bit of an arse to rinse, but it is much better for them than being bashed about in a metal drum.
*e.g. PROPER cashmere and fine wool
hellkat
PostPosted: 13:59 - 23 Feb 2008    Post subject: Reply with quote
We are very few and far between.
BCF seems to have more than its fair share of them Laughing
Walloper
Put them in one of those bags you get from Betterware... Wink
All my bike gear and the rags I use to service the bike go in that and they com eout fine...
hellkat
PostPosted: 14:00 - 23 Feb 2008    Post subject: Reply with quote
And anyway ... wtf is WAHING wool?
I thought it was some exotic chinese blend, Tibetan sheeps-bollock wool or something.
Mr. Green
Walloper
PostPosted: 14:03 - 23 Feb 2008    Post subject: Reply with quote
Mr. Green
You were almost there hellkat.
Wahing:
Is woven from the detritus found only in the bunk beds of Tibetan Monks.
hellkat
PostPosted: 14:17 - 23 Feb 2008    Post subject: Reply with quote
I bet you say that to all the girls.
Walloper
PostPosted: 14:20 - 23 Feb 2008    Post subject: Reply with quote
No sweetness, if you are as ugly as me you can't afford to play 'ard to get'. Anything you receive you must be truly thankful for Embarassed
Dragonfly
PostPosted: 16:28 - 23 Feb 2008    Post subject: Reply with quote
[quote="Walloper"]Dragonfly hunny, will you marry me?
[/quoteI
I went through a lot of cloths to find this out! plus my mum is a laundry expert! She passed her skills to me. I also learned that also you should never Iron Nylon school skirts or satin when I was in school. Wink
Walloper I expect a big shiny Diamond in the post and half of what you own. Cool
All the breast.
Muzza on Binge:
lozzypop1
Certified MILF!
PostPosted: 16:38 - 23 Feb 2008    Post subject: Reply with quote
I shall be waiting for my cut of the proceeds....
...for when you texted me for advice on how to get your brother's sweat-stains out of his clothes. Laughing
Lozzypop1: Money-grabbing for her earlier kindnesses. That'll learn ya! Twisted Evil
hellkat
PostPosted: 17:26 - 23 Feb 2008    Post subject: Reply with quote
I do not charge my menfolk for domestic duties*.
I usually just relieve them of their sanity over a matter of years, as a sort of payment-in-kind instead.
Although its possible I could arrange for a french maid to do it, I suppose.
But I couldnt guarantee that the french maid wouldn't have a willy Mr. Green
*Come to think of it, I don't even charge for matrimonial ones, either; you'd think I would have got round to that by now, wouldn't ya?
Walloper
PostPosted: 18:34 - 23 Feb 2008    Post subject: Reply with quote
[quote="dragonfly"]
[/quoteI
Well if it's only a fiscal matter.....
What address should I use?
The last post was made 18 years, 20 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 129.48 Kb
