What is the difference between...
thegubner
PostPosted: 10:05 - 13 Mar 2008    Post subject: What is the difference between... Reply with quote
An RVF and a VFR 400?
garth
PostPosted: 11:15 - 13 Mar 2008    Post subject: Reply with quote
If you're dyslexic, not alot.
NSR Mick
PostPosted: 11:45 - 13 Mar 2008    Post subject: Reply with quote
RVF is just pretty much a newer version of the VFR.
Fahd
PostPosted: 11:50 - 13 Mar 2008    Post subject: Reply with quote
N30 and below = VFR
NC35 = RVF
I Ride: Honda CBR 400RR.
I Drive: Audi S3.
mistergixer
PostPosted: 12:06 - 13 Mar 2008    Post subject: Reply with quote
RVF has USD forks, different (smaller & flatsided) carbs, air intake changes, engine internal changes, a 17inch front wheel, revised geometry and chassis.
Loads of other changes too numerous to list (and many of them too technical for me to understand the benefits of), it's not just a dressed up NC30.
Space Monkey #7
thegubner
PostPosted: 13:02 - 13 Mar 2008    Post subject: Reply with quote
So the RVF is a better bike than the VFR then?
PostPosted: 13:21 - 13 Mar 2008    Post subject: Reply with quote
Looks nicer and if you're racing you'd probably notice the changes. If you're not racing I doubt you would.
Extra tart value of USD forks though. The rear on the RVF is 17 inch down from 18 on the VFR so you have a greater selection of tyres.
Dom_
Points Mean Prizes
Fahd wrote:
N30 and below = VFR
NC35 = RVF
What about NC23 and NC29's?
I thought it was just the rear wheel that was 17 inch, front on vfr and rvf has always been 17 hanst it?
Rvf has different carbs which apparently give more mid range.
I personally think it's an over priced, over rated, dressed up NC30, and the benefits of the changes certainly don't justify the cost difference imo.
NSR Mick
PostPosted: 13:41 - 13 Mar 2008    Post subject: Reply with quote
CBR's. Thumbs Up Laughing
PostPosted: 13:49 - 13 Mar 2008    Post subject: Reply with quote
The front has always been 17 inch yes.
The RVF also different shaped exhaust ports to help flow more gas and boost mid-range.
As mrgixxer says there are many small diffrences, but unless you're racing you may well not notice them.
DavyB16
PostPosted: 13:50 - 13 Mar 2008    Post subject: Reply with quote
Presumably your talking about the nc30 & 35 (as the other VFRs - nc21/24 are totally different).
As already said the biggest differences are, the RVF has usd forks (internals unchanged), 17" REAR wheel, styling based on the rc45 (as opposed to the rc30) hence the different tank and air intake/fake ram air etc, smaller carbs, different gearing, new frame spars (similar to rc45), the riding position is slightly different, and some changes to the engine internals.
IMO as to which is better is as much down to your own personal preference as anything as overall they are very similar bikes just the RVF is newer (and I wish I had another 1 Rolling Eyes ).
CBR600RR3, KR-1S, Pre97 #16
the grim reaper
PostPosted: 14:17 - 13 Mar 2008    Post subject: Reply with quote
Ironically, the VFR is slightly lighter and more powerful than the RVF but the RVF is a much nicer looking bike, IMO.
Grim
Dom_
Points Mean Prizes
PostPosted: 14:22 - 13 Mar 2008    Post subject: Reply with quote
I knew that. Very Happy Was pointing out that anything below a NC30 wasnt just vfrs. Thumbs Up
Grim
VFR more poweful? hmm, I know officially that may be the case, but that's because Japan introduced a power cap at 55bhp at some point, so all bikes were listed as this even if they put out more.
the grim reaper
PostPosted: 14:28 - 13 Mar 2008    Post subject: Reply with quote
Grim
It's only marginal but having seen loads dyno'ed it's pretty much across the board. Mind you, a shagged chain and binding brakes will take off more than the difference between them. So maybe all RVFs are worse maintained Mr. Green
Grim
PostPosted: 14:30 - 13 Mar 2008    Post subject: Reply with quote
Fair enough.
mistergixer
PostPosted: 14:54 - 13 Mar 2008    Post subject: Reply with quote
My bad - i was perving at a bird at work who has lovely, massive (yet pert) tits but a horrible arse, hence getting the front and rear ends confused.
Embarassed
Space Monkey #7
Blackwolf
Burgerfist
PostPosted: 16:15 - 13 Mar 2008    Post subject: Reply with quote
so the fact on my bike engine its stamped NC23(Insert engine numbers) means its got an NC23 engine? where as the frame is stamped with NC31?
The bike is an CB400 Super Four.
Blackwolf
Burgerfist
So the fact on my bike engine its stamped NC23(Insert engine numbers) means its got an NC23 engine? where as the frame is stamped with NC31?
DavyB16
PostPosted: 16:28 - 13 Mar 2008    Post subject: Reply with quote
the cb400 superfour (non vtec) is the NC31 (vtec is NC39 iirc) the reason the engine is stamped NC23 is because the cb400 uses the engine from the nc23 cbr 400 with a few different engine internals like a heavier flywheel etc.
Dom_
Points Mean Prizes
PostPosted: 18:03 - 13 Mar 2008    Post subject: Reply with quote
All cbr400 engines begin the code with nc23, even the 29's which are a completely different engine.
NSR Mick
PostPosted: 18:15 - 13 Mar 2008    Post subject: Reply with quote
Same with NSR's that all start MC16.
The last post was made 18 years, 188 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 2.03 - MySQL Queries: 13 - Page Size: 119.14 Kb
