My new 89' TDR250: Goes like Stink!
twotakt
PostPosted: 21:43 - 18 Mar 2008    Post subject: My new 89' TDR250: Goes like Stink! Reply with quote
Brought this for £600 today, heres the specs and some pics
1989
Black/Yellow
11,000 miles
New Pirelli's
Braided lines (all round)
Aftermarket rear shock (not sure which)
Powder coated frame and rear wheel, all yellow (not front wheel?)
Powder coated rear luggage rack
Stan Stephens Stage 2 tuned (receipts to prove)
Aftermarket screen
Aftermarket calipers (I think, not sure which though)
Datatagged
It also comes with all the original stock parts
Comes with original workshop manual, every MOT slip and all receipts of the various work that has been done on it.
Bike hasn't been run for 7 years, when it did get taken off the road it was emptied of its fuel and the carbs were taken apart and cleaned.
Bad points
Rear side panel has small crack
Rear fender small chip
Only one wheel powder coated? (rear).
Other than that the bike is 100% original and is in very good condition.
P.s. What sort of difference does a stage 2 tune make to performance i.e. throttle response, torque, top end, low end, mid range, bhp etc?
https://aycu39.webshots.com/image/49478/2002194591166268356_rs.jpg
https://aycu39.webshots.com/image/47918/2002151895360018505_rs.jpg
https://aycu22.webshots.com/image/49741/2002163848923744115_rs.jpg
https://aycu32.webshots.com/image/47151/2005489132982757218_rs.jpg
https://aycu11.webshots.com/image/46330/2005437851343367557_rs.jpg
https://aycu16.webshots.com/image/47375/2005414616946394659_rs.jpg
R.I.P. Tareree Shiimi, 1985-2008
PostPosted: 22:35 - 18 Mar 2008    Post subject: Reply with quote
That is too nice for £600. Can we have a video when you get it started up?
I'll be the first to ask. When can I have a go? Mr. Green
colin1
Captain Safety
PostPosted: 23:47 - 18 Mar 2008    Post subject: Reply with quote
only thing is, those anodised aluminium braided lines can break
steel fittings are better, those red and blue bits are bad, and potentially dangerous
i dont know the circumstances in which they do, but kickstart does as he has pics to prove it
nice bike though
J.K.R
PostPosted: 00:16 - 19 Mar 2008    Post subject: Reply with quote
They are weaker than steel and stainless steel, Though you can buy the banjo bolts and fittings and swap them over Thumbs Up
Looks like a good buy for £600 Smile
www.oldskoolsuzuki.info
twotakt
PostPosted: 08:01 - 19 Mar 2008    Post subject: Reply with quote
Thanks for the nice comments everyone.
Where can I get these banjo fittings?
Also, apparently it would cost me around £80 to get my wheel respoked. Is that about right?
Eddie Hitler
PostPosted: 09:19 - 19 Mar 2008    Post subject: Reply with quote
You've done well to get that for 600 quid, thats a well sought after bike! Thumbs Up
garth
PostPosted: 09:29 - 19 Mar 2008    Post subject: Reply with quote
You need a ride it like you stole it sticker. Thumbs Up
J.K.R
PostPosted: 21:08 - 19 Mar 2008    Post subject: Reply with quote
Could try eBay, Anyone with a Hi-Level account should get you sorted with them.
I think Sickpup off here deals with them, Might be worth a PM Thumbs Up Remember the olives too Smile
Is that including new spokes? If so, Good price i'd say.
twotakt
PostPosted: 00:15 - 20 Mar 2008    Post subject: Reply with quote
First off,
Thanks for taking your time to read and reply to the posts, its sincerely appreciated.
I'm not 100% whether that includes spokes to be honest, I'll have to double check.
Here's a run down of the work this afternoon
The brakes were sticking, so i split the calipers and removed the pistons to give them a clean. I understand that I need to replace the seals, but the only place as so far that I can find selling them is wemoto. They want £7 each for the front and £8 each for the rear, which ends up costing me £44!! (4 for the front, 2 for the rear) Just for some tiny bits of rubber.
Any other options? Places to buy them? Anyone got a spare set (obv new) lying around for sale? I know its essential to replace the dust seal but is it also necessary to replace the piston seal?
Once the brakes are done I'll fit the new battery, fill with it with fuel. Kick it over a few times with the ignition off. Then fire it up!
Anything else I need to be aware of before starting the bike up? (never re-started a bike thats been laid up for so long).
Thanks for your time,
Jack
Shaane
PostPosted: 00:20 - 20 Mar 2008    Post subject: Reply with quote
Nice Buy mate. Looks a nice bike. As for the parts your after have you tried searching via Google or another Search engine?
Shane
Previous: 1992 DT125R
Current: ~ 2005 ZX6R C1H
PostPosted: 00:35 - 20 Mar 2008    Post subject: Reply with quote
Maybe make sure that the 2t oil pump works by making a premix in the tank for the start up. Take the 2t oil pipe off the carb and put it in some sort of jar or container (so you don't get oil everywhere), start the engine up and if the oil is flowing it's all good. Run the engine until the premix has run out or drain the premix from the tank. Then fill it up back up with fuel.
Make sure there is oil in the tank when you do this or nothing will flow out Smile
Don't forget to connect the 2t oil pipe back up to the carb when you are done testing.
Also check that there is coolant in the radiator and that the gearbox is topped up with oil.
Wouldn't want you to break the lovely bike.
twotakt
PostPosted: 01:24 - 20 Mar 2008    Post subject: Reply with quote
Cheers MS and Shaane, Ill have to get the camera sorted for when I first start it up and then post it up here.
I've been informed via www.tdr250.co.uk forum members a pre 2004 R1/R6 front caliper will be a straight swap for my OE front caliper. There is no need to replace the master cylinder, its just bolt on and go. It should perform alot better, and the pistons won't corrode as they are made of alloy unlike the OE pistons. It also *hopefully* Laughing should work out as a cheaper option than replacing all of the seals.
So my next question is........has anyone got one of these to sell me? If so, the following requirements must be met:
Front calipers only
Good working order (ready to use)
Also these are perferences but not essential
Gold spot (but would happily buy other colours)
A single R/H caliper (but would also buy a set if unwilling to split a pair)
Good condition brake pads
veeeffarr
PostPosted: 02:16 - 20 Mar 2008    Post subject: Reply with quote
HEL make coloured stainless brake hose fittings, coloured doesn't always mean anodised crap.
twotakt
PostPosted: 12:03 - 20 Mar 2008    Post subject: Reply with quote
Just brought myself a Gold spot R1/R6 caliper, worked out at £39 as I used the £5 ebay coupon. It came with near new brake pads and is 100% good working order.
Happy days Very Happy
My new caliper
https://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=160192476492&ssPageName=ADME:X:RTQ:GB:1123
twotakt
PostPosted: 13:55 - 20 Mar 2008    Post subject: Reply with quote
Now I need a new rear caliper, one of the pistons is stuck so hard in the caliper. I've tried pumping the brakes, air compressor and pulling it whilst applying lubricant (not all at the same time though). It hasn't moved!
In order to save me alot of stress, bleeding knuckles and swearing I think I'll just buy another rear caliper. What are my options? Are there any other calipers from modern sports bikes that will just bolt on? Has anyone got an OE rear caliper to sell me?
Also has any one got any/links to brake line banjos for sale, I want to replace the blue andodised ones on there at the moment cos they look shit.
Thanks again,
Jack
P.s. Is there any variance between gold spot and blue spot calipers (apart from their colour of course)
Jockey
PostPosted: 14:02 - 20 Mar 2008    Post subject: Reply with quote
Liked the picture with the kickstart, it actually tells you just what that lump of metal is, first class, the Japs think of everything. It does look quite nice, as you say the spokes are a bit of a mess and need replacing with stainless items.-Jockey. Laughing Laughing Thumbs Up
chrisstone
PostPosted: 14:50 - 20 Mar 2008    Post subject: Reply with quote
that s looks very good for £600 you will have loads of fun on that
i love mine to bits they handle and the power band is sweet
just be careful about bike they have nasty rep for blowing up i blew mine up many xmas ago pump went starved engine and game over nice push home
Madmanx
PostPosted: 14:56 - 20 Mar 2008    Post subject: Reply with quote
Oh I want one soooo bad.
It's lovely. Thumbs Up Sick Thumbs Up
Here's my screensaver.
https://i284.photobucket.com/albums/ll9/manxhornet/Hornet001.jpg
twotakt
PostPosted: 15:07 - 20 Mar 2008    Post subject: Reply with quote
Thats a beauty eh Manxscot, best of luck in getting your own one.
I couldn't believe that I got it for £600, the guy fully didn't know what it was worth.
I remember when my DT125 blew up, I had to push it home 2-3miles home in full motorcycle gear flippin' sweating buckets. But I got a rebore and oversize pistons, rebuilt the top end and I'm back on the road!
I think the TDR should be just as reliable/liable as the DT, as the DT is kind of a single cylinder version of the TDR engine (half a TDR, lol). It'll just be ring changes every 4000-5000 miles and new piston kits every 10000miles.
I can't wait to ride it next week, power wheelies galore hahahahahahaha Laughing
twotakt
PostPosted: 09:53 - 21 Mar 2008    Post subject: Reply with quote
Hello there,
I need a replacement rear brake caliper for my TDR250, but any of the following will also fit. So if you have any of these that you want to sell then let me know.
However these calipers must be in good working order and ready to use. Ideally they'd also have brake pads in good condition however this is not essential.
THE FITTING IS 83mm (so if have anything with that caliper bolt spacing to sell then let me know).
Rear calipers
TZR250
TDR250
RD350 F2
Front Calipers (which are useable as rear calipers on the TDR).
TZR250
FZR400
This list is inexhaustable
Apparently these fittings were quite common on late 80s and early 90s yamaha's. So if you have anything similiar then also post me the caliper spacer bolts measurement and I'll see if it'll fit.
Jack
TUG
PostPosted: 19:30 - 21 Mar 2008    Post subject: Reply with quote
PM sent mate. Thumbs Up
Haz ER-5, innit!
twotakt
PostPosted: 10:38 - 25 Mar 2008    Post subject: Reply with quote
My R1 caliper arrived this morning! Happy days, but it has no dust cover. Is this required for a MOT? Could it fail due to a lack of a dust cover?
Thanks again,
Jack
Matty21
PostPosted: 12:20 - 25 Mar 2008    Post subject: Reply with quote
Nice Tdr man Smile
250 stroker's for the win Smile
Cant wait to get on my KR1 (1989)
Let me know how she rides man.
He who does not dare,does not succeed!
Trackdays half the season, second half racing.
twotakt
PostPosted: 18:17 - 25 Mar 2008    Post subject: Reply with quote
Cheers Matty, will let you know how it rides tomorrow. Sorted the brakes today and got the MOT booked in for tomorrow at 4.30. That R1 caliper is the mutts, so solid. Whats your KR-1 like? I always fancied one of those.
Cheers again,
Jack
Matty21
PostPosted: 19:32 - 25 Mar 2008    Post subject: Reply with quote
Thanks Smile
Well i bought it as a project so i can race it when i turn 16 in may Smile
Then engine is sweet as, wheels very tidy, i repaired all the bodywork myself and made a single seat unit Smile
its all in white, i havent got race fairing yet , might race it naked Smile
I find out how it rides in may so Smile
But your tdr is lovely .
thanks
The last post was made 18 years, 5 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 1.02 - MySQL Queries: 13 - Page Size: 132.63 Kb
