Honda Nsr 125 restriction
Bike Chat Forums Index -> The Workshop Goto page 1, 2, 3, 4, 5  Next
sc3m
PostPosted: 09:35 - 22 Mar 2008    Post subject: Honda Nsr 125 restriction Reply with quote
Hello.
Iam new in this forum and i just brought an nsr 125.
It has 8 Kw i want to ask if i de-restrict it it would become 11 kw?
Has honda nsr 125 11 kw restrictors?
If i de-restrict my honda nsr 8 kw it wont be weaker than 11 kw ?
Sorry for bad english .
alains
PostPosted: 20:02 - 22 Mar 2008    Post subject: Reply with quote
a fully derestricted is about 20KW , i would like to know your serial number and in which country you live
fishbowl
PostPosted: 10:29 - 23 Mar 2008    Post subject: Reply with quote
Why would you want to know that?!?!?! I mean I'm new in this forum but still....
alains
PostPosted: 10:54 - 23 Mar 2008    Post subject: Reply with quote
year & country
specs are different with the country
this has been the subject of several posts here , search button can be usefull , it's up to you
sc3m
PostPosted: 13:35 - 23 Mar 2008    Post subject: Reply with quote
YEar 2001-08.
Country Sweden
alains
PostPosted: 13:41 - 23 Mar 2008    Post subject: Reply with quote
impossible , your serial begins by ZDCJC22 then a letter , then 01 (if you're right) then F and your frame number (6 digits)
so i need the letter and to know if 01 is correct
sc3m
PostPosted: 15:43 - 24 Mar 2008    Post subject: Reply with quote
Yes the falowing leters, nubers is e01
alains
PostPosted: 16:08 - 24 Mar 2008    Post subject: Reply with quote
so your bike is a swiss import from 2001 restricted at 75mph
if it hasnt been done , the restriction is a non moving servo-motor , valves are on low and stay on low even at 8000 rpm
sc3m
PostPosted: 16:33 - 24 Mar 2008    Post subject: Reply with quote
So how can i remove this restrictor ?
alains
PostPosted: 16:45 - 24 Mar 2008    Post subject: Reply with quote
it's a shunt in the loom somewhere in the cubic box on the left side of the carb (it's part of the plastic tray)
bring off all the connectors and take a picture , then i will tell you
sc3m
PostPosted: 17:06 - 24 Mar 2008    Post subject: Reply with quote
Something like this intake restrictor?
https://www.nsr125.com/derestrict.htm
And What's Cubic Box?(sorry if sound stupid but iam not wery strong in English)
alains
PostPosted: 17:29 - 24 Mar 2008    Post subject: Reply with quote
this site was good for 1989-1993 bikes but the NSRs have change a bit
look the picture
sc3m
PostPosted: 16:41 - 25 Mar 2008    Post subject: Reply with quote
But where is the restrictor somewhere in carb or somewhere in intake ?
And which parts picture should i take ?
(I didi'nt undrestod from the last post's )
alains
PostPosted: 17:06 - 25 Mar 2008    Post subject: Reply with quote
i was not talking about mechanical restrictions which are :
- a plate reducing the gaz entry between the intake pipe and the block reed
- a restrictor in the pipe (on french model , i dont know for the others)
- a carb underjetted
i was talking about electronic or electric restrictions
the exhaust port has 2 flaps (called RC/valves) which is controlled by a control unit . the ignition is make by a CDI unit which control the advance in the timing , this CDI can be restricted
these units are marked TV124 (restricted) or TV78 (unrestricted) for the control unit . CI639 (restricted) or CI626 (unrestricted) for the CDI
the SWISS import are not restricted on the electronics but by a shunt fitted somewhere , this what you have to look for
download my file https://www.geneva-racing.com/~alains/NSRtips.doc
on page 17 you have exponations about how work the electronics , this shunt is just fit over the potentiometer and will avoid the servo to move and consequently your valves stay closed and you cannot overpass 8000 rpm
sc3m
PostPosted: 17:33 - 25 Mar 2008    Post subject: Reply with quote
But i can pass the 8000 RMP , but acceleration is low...
The acceleration is good till 8000 RMP.
After 8000 RMP the acceleration doesn't chage a bit....
In secound Gear 8000 RMP speed is about 57 KpH and max speed of the secound gear is 60- 62. My friend's NSR max on secound gear is 70~kph.
And mine max speed is 120~kph (75mph) as you said...
Iam confuesed i dont know where to search that shunt ....
Could it be near the valves? There are something on the valves.
I will try to make a foto ....
alains
PostPosted: 19:59 - 25 Mar 2008    Post subject: Reply with quote
no , i told you : on the left of the carb look for a small cubic plastic box (it's part of the tray as show the picture) open that box and pull all connectors out then inspect
this pict will show you all the connectors
obviously before doing that , check if the servo pulley moves as described in my file
nsr12508
PostPosted: 23:04 - 26 Mar 2008    Post subject: restricting a nsr 125 Reply with quote
Hi am seventeen and have got a nsr 125 derestricted but this means that the insurance is invalid because i only have a provisional license. SO WHAT I AM ASKING IS HOW TO RESTRICT MY NSR IT IS A NSRR 2000 MODEL. Laughing
alains
PostPosted: 12:09 - 27 Mar 2008    Post subject: Reply with quote
send me a pm with your serial number (between the yokes)
ukaszs2
PostPosted: 10:42 - 18 Jul 2008    Post subject: Reply with quote
Hi, my friend want to buy NSR (ZDJC22E) but this model is restricted, i found on wikipedia this: "
This has a load of restrictions and is nearly impossible to derestrict and cannot even rev past 7500 rpm"
I read this topic and i see that is only one restrict on rc valve, iit is true? It is possible that in this nsr is diffrent cylinder with smaller ports?
alains
PostPosted: 11:13 - 18 Jul 2008    Post subject: Reply with quote
the ports are very slightly smaller but they are sited a bit higher this gives a faster bike in the range 2000-6500 but limit the top at about 11200 rpm . the main restrictions are :
- a shunt (on 3) onto the servo-motor potentiometer which cancel the return voltage to the control unit and consequently lock the servo-motor whith the valves closed . this is easy to remove (see pict)
- a bad CDI unit marked CI626A instead of CI626 as UK bikes have
obviously on all bikes the improvements are :
- a race pipe (+2-3 Bhp) £150-250
- carbon petals on the block reed £25-40
- irridium plug £6-9
as soon as you derestrict the bike , you need to upjet your carb in order to protect your engine , 2ST do not like lean mixture , upjet as main 138, slow (idle) 42 , power 65 . cost £12ish
ukaszs2
PostPosted: 11:44 - 18 Jul 2008    Post subject: Reply with quote
Thank you for reply, you have great knowledge about NSR. What is diffrent betwen CDI unit CI 639 and CI626A?
I hava your nsrtips.doc and there i foud this "The Case to be gone up is TV-78 the U.K. & IT , no modifications to do, dismounts the TV-124 and replace by the TV-78 . This case allows an opening of the valves 90-95% however the TV-124 plus the FREDO plate produced the same effect" Can you tell me about this FREDO plate? What i must do to modify TV-124 to work propertly. It is possible to modify restricted CDI unit to unrestricted?
alains
PostPosted: 12:00 - 18 Jul 2008    Post subject: Reply with quote
unfortunatly , it's in french
https://www.geneva-racing.ch/~davnav/circuit_v2.pdf
ukaszs2
PostPosted: 12:14 - 18 Jul 2008    Post subject: Reply with quote
I don't understand french, but i think i must do this box on page 13 and connect this like on the pictures?
alains
PostPosted: 12:22 - 18 Jul 2008    Post subject: Reply with quote
yes , sorry it will be a bit too hard for me translating this . but you can buy some TV78 for JC22 on ebay here
https://cgi.ebay.co.uk/Honda-NSR125-JC22-Foxeye-Powervalve-CDI-NSR-125_W0QQitemZ290246136134QQcmdZViewItem?hash=item290246136134&_trksid=p3286.m14.l1318
ukaszs2
PostPosted: 12:42 - 18 Jul 2008    Post subject: Reply with quote
I can buy CDI module CI626 and RC valve module TV78 for about 85 pounds from guy who have 2 nsr for parts. I'm pole and i could have problem to buy somethink from your ebay. I looking for unrestricted modules to CRM 125. I want to apply NSR unrestricted modules to CRM but i dont know if they work propertly.
The last post was made 18 years, 56 days ago. Instead of replying here, would creating a new thread be more useful?
Page 1 of 5
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.18 Sec - Server Load: 0.46 - MySQL Queries: 13 - Page Size: 121.95 Kb
