| Thom |
 Thom World Chat Champion
| MaybeGuy |
 MaybeGuy Super Spammer
 Posted: 09:47 - 24 Mar 2008 Post subject: |
make sure all mating surfaces are clean, and that your head or cylinder block is not warped.
get an engineers square and some feeler gauges. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Thom |
| MaybeGuy |
 Posted: 10:40 - 24 Mar 2008 Post subject: |
you put the square across the surface and try and slide feeler gauges underneath.
if you can fit more than a 0.025 gauge under it, chances are its a bit warped.
has the bike ever run without coolant or overheated?
why did the gasket need changing? ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Phil_G |
 Phil_G Traffic Copper
 Posted: 11:12 - 24 Mar 2008 Post subject: |
as above but also make sure when you replace the gasket that you torque the head down correctly (correct lb/ft rating and correct sequence) and follow any guidelines with regards to replacing nuts/bolts etc. ____________________ 1997 Kawasaki ER 500 A1:- Once again, Its merely crap  |
| MaybeGuy |
 Posted: 11:54 - 24 Mar 2008 Post subject: |
should be something like this...
https://aycu08.webshots.com/image/50527/2000823971657777633_rs.jpg
tighten them down in this order, but tighten them gently at first in order...
do the sequence about 4-5 times gradually tightening them all. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Finglonga |
 Finglonga World Chat Champion
| Thom |
 Posted: 16:33 - 24 Mar 2008 Post subject: |
right everything was ok i had, 2 loose nuts
But now that everythings working again and ive reset the carb the bikes running rather... fast!
I Replaced both the choke and throttle cables, the oil pump is adjusted so as to make the mix just a little rich.
Now when i start the bike up the revs sit at about 2k, but if i open the throttle up it bogs down then takes off upto 4-5k where it sits, even after releasing the grip the revs sit here, what could my problem be?
To drop the revs i have to forcefully twist the throttle back, its almost as if its sticking or theres slack in the cable, but i assure you theres not! |
| MaybeGuy |
 Posted: 16:39 - 24 Mar 2008 Post subject: |
| metalforever wrote: | right everything was ok i had, 2 loose nuts
give it a good lube up, check a haynes manual how to... it involves some sort of funnel thing you can make.
if theres NO slack, that could be part of the problem. maybe the throttle is on slightly?
as far as the bogging down goes, sounds like your over fuelling it.
what bike is it? pics? ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Thom |
| MaybeGuy |
 Posted: 16:48 - 24 Mar 2008 Post subject: |
you sure the choke is fully off?
throttle adjuster not too tight?
idle screw?
oil pump set properly? ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Thom |
| Thom |
| MaybeGuy |
 Posted: 16:56 - 24 Mar 2008 Post subject: |
| metalforever wrote: | | mattsprattuk wrote: | you sure the choke is fully off? As far as im aware, yes, hwoever, the chooke cable has an adjuster, which i havent played with since fitting, should i?
throttle adjuster not too tight? Im not entirely sure but if i back it off all the way theres slack and if i tighten it too far it increasing the oil flow+revs, as it should
idle screw? it's been adjusted so the revs sit at 2k when the bikes fired up
oil pump set properly? just a smidgen over the required amount, but would this need bleeding if the cables been removed? |
if its a smidgen over the required amount, thats over fuelled which means bogging down as the revs increase... is it really smokey? and revs better when cold than when hot?
the throttle should have about half a cm free play in it ideally.
if you're just taking the oil pipe from the carb, you wont need to bleed it. set it as required and try again.
you need to bleed the pump if you A: run out of 2t oil, B: remove the oil pump feed lines. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Thom |
 Posted: 17:01 - 24 Mar 2008 Post subject: |
It's about 1mm over, the oil pump i mean, so no it's not kicking out much smoke
Im not entirely sure how much free play is in the throttle but theres not 1cm i dont think, but this would suggest when idling the cable should be a little slack?
And good about the bleeding of the oil pump, the only one i removed was the carbs pipe.
I might add all the advice is very much appreciated as id like this thing to go for sale shortly!
KArma your way  |
| MaybeGuy |
 Posted: 17:15 - 24 Mar 2008 Post subject: |
1mm over as in the oil pump piston moves an extra 1mm??
thats quite a substantial amount.
i assume you have the haynes manual... i suggest you set it up to what it says in there. tinkering with 2 strokes unless youve changed something from stock can cause problems.
i was under the impression that oil pumps were set up using feeler gauges.
you dont have an aftermarket air filter on it by any chance do you? ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Thom |
 Posted: 17:21 - 24 Mar 2008 Post subject: |
oh no sorry i should have explained the oil pump works on the throttle, the throttle cable splits into two of which one pulls the oil pump drum and increasies the opil feed and the other goes to the carb for the throttle slide.
1mm over on the oil pump is a tiny amount, previously it was about 5mm over which caused alot of plug fouling.
no air filter on it but the bike has been derestricted. the hetting has been changed too to allow for this, but again by the previous owner, i ahvent changed anything massive like the jets...
Im gonna have a look at the choke adjustment on the carb and slacken it off all the way, see what this does, ill also slacken the throttle fully and tighten it up via the oil pump again to set it correctly but leave enough slack so as to have .5cm on the throttle.
for tomorrow though  |
| MaybeGuy |
 Posted: 17:24 - 24 Mar 2008 Post subject: |
its the same type of pump on my girlfriends RXS100 then...
its adjusted using feeler gauges, but opens and closes with the throttle. ____________________ Blue_SV650S wrote: it was a sh1te wheelie, but it proves that he can get it up in 3rd and can do angles. In summery, mattsprattuk is a gobby little sh1tebag, dopehead tw4t, but sadly for all of us, he probably isn't THAT full of sh1te!!
| Thom |
| Thom |
| MaybeGuy |
The last post was made 17 years, 333 days ago. Instead of replying here, would creating a new thread be more useful? |
