Coolant into cylinder?
Thom
PostPosted: 09:30 - 24 Mar 2008    Post subject: Coolant into cylinder? Reply with quote
This to me sounds very strange... i mean, i didnt even think it was possible unless you poured it in directly!
Anyway i recently replaced the cylinder head gasket, replaced the coolant and set the carb to 2.5turns on the pilot screw and the idle screw 3.5turns out.
In theory this should be a very good setting to atleast test the bike runs and it does, the bike runs for the whole of 20seconds if i keep revving it gently and slowly.
Now i have had the oil tube off the carb, would this need bleeding to allow oil to pass through?
If not i think my problem could be coolant getting into the engine, i noticed a bit of coolant around my exhaust port...
How likely is it this has happened and is the reason for the stalling?
How, when refitting the gasket, do i make sure this doesnt happen again?
MaybeGuy
PostPosted: 09:47 - 24 Mar 2008    Post subject: Reply with quote
make sure all mating surfaces are clean, and that your head or cylinder block is not warped.
get an engineers square and some feeler gauges.
Thom
PostPosted: 09:50 - 24 Mar 2008    Post subject: Reply with quote
cool, what am i doing with the feeler guages though? obviously im checking the square is level but the feeler guages?
MaybeGuy
PostPosted: 10:40 - 24 Mar 2008    Post subject: Reply with quote
you put the square across the surface and try and slide feeler gauges underneath.
if you can fit more than a 0.025 gauge under it, chances are its a bit warped.
has the bike ever run without coolant or overheated?
why did the gasket need changing?
Phil_G
PostPosted: 11:12 - 24 Mar 2008    Post subject: Reply with quote
as above but also make sure when you replace the gasket that you torque the head down correctly (correct lb/ft rating and correct sequence) and follow any guidelines with regards to replacing nuts/bolts etc.
1997 Kawasaki ER 500 A1:- Once again, Its merely crap Smile
MaybeGuy
PostPosted: 11:54 - 24 Mar 2008    Post subject: Reply with quote
should be something like this...
https://aycu08.webshots.com/image/50527/2000823971657777633_rs.jpg
tighten them down in this order, but tighten them gently at first in order...
do the sequence about 4-5 times gradually tightening them all.
Finglonga
PostPosted: 14:38 - 24 Mar 2008    Post subject: Reply with quote
. . . . . Then re-check the torque after a few hundred miles.
Andy Sez....
F.Y.Y.F.F.
Thom
PostPosted: 16:33 - 24 Mar 2008    Post subject: Reply with quote
right everything was ok i had, 2 loose nuts Embarassed
But now that everythings working again and ive reset the carb the bikes running rather... fast!
I Replaced both the choke and throttle cables, the oil pump is adjusted so as to make the mix just a little rich.
Now when i start the bike up the revs sit at about 2k, but if i open the throttle up it bogs down then takes off upto 4-5k where it sits, even after releasing the grip the revs sit here, what could my problem be?
To drop the revs i have to forcefully twist the throttle back, its almost as if its sticking or theres slack in the cable, but i assure you theres not!
MaybeGuy
PostPosted: 16:39 - 24 Mar 2008    Post subject: Reply with quote
give it a good lube up, check a haynes manual how to... it involves some sort of funnel thing you can make.
if theres NO slack, that could be part of the problem. maybe the throttle is on slightly?
as far as the bogging down goes, sounds like your over fuelling it.
what bike is it? pics?
Thom
PostPosted: 16:46 - 24 Mar 2008    Post subject: Reply with quote
It's a honda nsr 125 from 1990, even though the engine is from a 99 foxeye, it was running fine until i took the carb out and cleaned it, adjusted the oil pump to be a little less rich, cleaned the spark plug up and changed the choke and throttle cables.
It's strange it's almost as if there is too much fuel suddenly being dumped into the engine.
On the throttle note, the carb doesnt stick and slides smoothly all the way through, so too does the oil pump, so in theory, this narrows it down to the actual throttle sticking somewhere, or the cable being too tight from throttle to carb/oil pump?
I just dont understand how i can be flooding the engine when before the carb was out i could throw the throttle all the way round without it bogging down.
The bike was cold but this wouldnt create the sticking revs problem...
MaybeGuy
PostPosted: 16:48 - 24 Mar 2008    Post subject: Reply with quote
you sure the choke is fully off?
throttle adjuster not too tight?
idle screw?
oil pump set properly?
Thom
PostPosted: 16:49 - 24 Mar 2008    Post subject: Reply with quote
oh by the way, i took the cylinder head off to chek the barrell for scoring and figured id replace the gasket while i was on as the other one was slightly bent and the paint was all flaky, just didnt look great!
I've also changed the engine oil and coolant, with the coolant still needing bleeding properly but due to the revving problem i cant!
Thom
PostPosted: 16:54 - 24 Mar 2008    Post subject: Reply with quote
As far as im aware, yes, hwoever, the chooke cable has an adjuster, which i havent played with since fitting, should i?
Im not entirely sure but if i back it off all the way theres slack and if i tighten it too far it increasing the oil flow+revs, as it should
idle screw?
it's been adjusted so the revs sit at 2k when the bikes fired up
just a smidgen over the required amount, but would this need bleeding if the cables been removed?
MaybeGuy
PostPosted: 16:56 - 24 Mar 2008    Post subject: Reply with quote
metalforever wrote:
mattsprattuk wrote:
you sure the choke is fully off? As far as im aware, yes, hwoever, the chooke cable has an adjuster, which i havent played with since fitting, should i?
throttle adjuster not too tight? Im not entirely sure but if i back it off all the way theres slack and if i tighten it too far it increasing the oil flow+revs, as it should
idle screw? it's been adjusted so the revs sit at 2k when the bikes fired up
oil pump set properly? just a smidgen over the required amount, but would this need bleeding if the cables been removed?
if its a smidgen over the required amount, thats over fuelled which means bogging down as the revs increase... is it really smokey? and revs better when cold than when hot?
the throttle should have about half a cm free play in it ideally.
if you're just taking the oil pipe from the carb, you wont need to bleed it. set it as required and try again.
you need to bleed the pump if you A: run out of 2t oil, B: remove the oil pump feed lines.
Thom
PostPosted: 17:01 - 24 Mar 2008    Post subject: Reply with quote
It's about 1mm over, the oil pump i mean, so no it's not kicking out much smoke
Im not entirely sure how much free play is in the throttle but theres not 1cm i dont think, but this would suggest when idling the cable should be a little slack?
And good about the bleeding of the oil pump, the only one i removed was the carbs pipe.
I might add all the advice is very much appreciated as id like this thing to go for sale shortly!
KArma your way Thumbs Up
MaybeGuy
PostPosted: 17:15 - 24 Mar 2008    Post subject: Reply with quote
1mm over as in the oil pump piston moves an extra 1mm??
thats quite a substantial amount.
i assume you have the haynes manual... i suggest you set it up to what it says in there. tinkering with 2 strokes unless youve changed something from stock can cause problems.
i was under the impression that oil pumps were set up using feeler gauges.
you dont have an aftermarket air filter on it by any chance do you?
Thom
PostPosted: 17:21 - 24 Mar 2008    Post subject: Reply with quote
oh no sorry i should have explained the oil pump works on the throttle, the throttle cable splits into two of which one pulls the oil pump drum and increasies the opil feed and the other goes to the carb for the throttle slide.
1mm over on the oil pump is a tiny amount, previously it was about 5mm over which caused alot of plug fouling.
no air filter on it but the bike has been derestricted. the hetting has been changed too to allow for this, but again by the previous owner, i ahvent changed anything massive like the jets...
Im gonna have a look at the choke adjustment on the carb and slacken it off all the way, see what this does, ill also slacken the throttle fully and tighten it up via the oil pump again to set it correctly but leave enough slack so as to have .5cm on the throttle.
for tomorrow though Thumbs Up
MaybeGuy
PostPosted: 17:24 - 24 Mar 2008    Post subject: Reply with quote
its the same type of pump on my girlfriends RXS100 then...
its adjusted using feeler gauges, but opens and closes with the throttle.
Thom
PostPosted: 21:07 - 24 Mar 2008    Post subject: Reply with quote
I can't see any need for feeler guages, basically you have two nuts you adjust up or down until the mark on the pump drum is aligned with a protrusion.
Thom
PostPosted: 21:08 - 24 Mar 2008    Post subject: Reply with quote
MaybeGuy
PostPosted: 23:16 - 24 Mar 2008    Post subject: Reply with quote
as the engine turns, it operates a worm drive which powers the oil pump.
the pump is set to pump a certain amount depending on how far open the throttle is.
the feeler gauges are needed to measure that initial pump at idle which has a knock on effect to the whole system regardless of RPM.
it may be different on an NSR to an RXS, but im sure the principles are the same.
The last post was made 17 years, 324 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 2.41 - MySQL Queries: 13 - Page Size: 117.65 Kb
