bandit 33bhp washer dimensions
yankeedoodle
PostPosted: 11:42 - 25 Mar 2008    Post subject: bandit 33bhp washer dimensions Reply with quote
can anyone tell me the dimensions for the carb washers for a bandit 33bhp restriction kit.I want to make my own if possible.
Any help is much appreciated
SM.Morgan
PostPosted: 12:01 - 25 Mar 2008    Post subject: Reply with quote
willl get my mate to measure his tonight and will post the dimensions up later. Thumbs Up
Harley XR1200
PostPosted: 12:25 - 25 Mar 2008    Post subject: Reply with quote
Order them from FI, make replicas and then send them back asking for a refund.
yankeedoodle
PostPosted: 13:46 - 25 Mar 2008    Post subject: Reply with quote
thanks alot sm morgan. much appreciated.
I might order them and then send them back if I have to, but I'd rather avoid that route if poss
iooi
PostPosted: 13:47 - 25 Mar 2008    Post subject: Reply with quote
I'm sure someone posted them the other day somewhere on this site... Try looking/searching in the workshop section. Thumbs Up
yankeedoodle
PostPosted: 13:48 - 25 Mar 2008    Post subject: Reply with quote
karma given if you can find that thread Smile Thumbs Up
iooi
PostPosted: 13:52 - 25 Mar 2008    Post subject: Reply with quote
Assuming this is a bandit...
if anyone else is after restricting a SRAD6, its 40mm with 13mm internal diameter to get 33bhp
Thanks to matspratuk..... Its the greman thread in the workshop section Thumbs Up
yankeedoodle
PostPosted: 13:57 - 25 Mar 2008    Post subject: Reply with quote
thanks for that.not sure the srad will be the same as the bandit but ill speak to him.
cheers
SM.Morgan
PostPosted: 14:44 - 25 Mar 2008    Post subject: Reply with quote
The SRAD won't be the same as it needs more restricting than the bandit.
Harley XR1200
banditboy123
PostPosted: 14:58 - 25 Mar 2008    Post subject: Reply with quote
hi m8 i have got the FI kit on my 2003 bandit 600 and on the paper work it says
outer diameter=38mm
inner diameter =15.5 mm
hope this helps
iooi
PostPosted: 15:14 - 25 Mar 2008    Post subject: Reply with quote
cheers
No worries, can't keep up with all the diffrent names for bikes Crying or Very sad
yankeedoodle
PostPosted: 15:59 - 25 Mar 2008    Post subject: bandit washers Reply with quote
hi. you say your mate has the bandit washers.if so would you be able to do me a huge favour please? Would you be able 2 trace round the washers on to a piece of paper, scan the drawing in and send it to em please? IF you could do this i would be eternally greatful
Matt
St0rmer66
PostPosted: 18:50 - 25 Mar 2008    Post subject: Reply with quote
iooi wrote:
cheers
SRAD's first came out in 1996! Shocked . How behind are you? Laughing
:: Honda XR 125 L ('53) => Kawasaki GPZ 500S ('02) => Suzuki SV650S ('00) => Aprilia RSV-R ('51) ::
Richard_Schmid
PostPosted: 19:23 - 25 Mar 2008    Post subject: Reply with quote
Sorry for the crap photos.
Charlie
PostPosted: 19:27 - 25 Mar 2008    Post subject: Reply with quote
Mr Doodle I think you should read all the posts...
outer diameter=38mm
hope this helps
Bardeey
PostPosted: 20:14 - 25 Mar 2008    Post subject: Reply with quote
Doubt this is helpful at all but I thought id link it anyways... Don't make the same foolish mistake I did haha Very Happy
https://www.bikechatforums.com/viewtopic.php?t=117303&highlight=restriction
:: P Speedfight 49cc => Gilera DNA 124cc => Suzuki Bandit GSF V 400cc ::
:: CBT=Passed 07/08/05 :: Theory=Passed 31/05/07 :: Practical= Passed 02/08/07::
alun111
PostPosted: 20:23 - 25 Mar 2008    Post subject: Reply with quote
Seeing as nobody's asked - What CC is the bike? The picture Richard_Schmid posted don't look anything like the restrictors for the bandit 400, so it proves that they ARE different.
yankeedoodle
PostPosted: 20:24 - 25 Mar 2008    Post subject: Reply with quote
600
Skudd
PostPosted: 20:36 - 25 Mar 2008    Post subject: Reply with quote
I always thought it was the registration of the bike to the restrictor kit with certificate that was the most important bit. My nephew had to buy two kits for his two Africa Twins as the were not transferable between one bike to another.
yankeedoodle
PostPosted: 20:38 - 25 Mar 2008    Post subject: Reply with quote
common misconception. if you buy the kits from FI International then you are paying for the paperwork as the washers are worth pennies. You arent', however, required by law to have a certificate. As long as your bike is restricted to 33bhp for the 2 years on an A2 license, then you're well within the law.
djr
PostPosted: 20:45 - 25 Mar 2008    Post subject: Reply with quote
AFAIK that won't work as FI will only send to registered dealers and therefore you'd have to get the dealer to fit it, and therefore they ain't gonna send them back for you either....
I dunno tho as my bandit spent the two years unrestricted Wink.
J.K.R
PostPosted: 21:18 - 25 Mar 2008    Post subject: Reply with quote
Shocked Couldve buggered that up there Neutral
Reason the dealers would have said it goes in between the carbs and rubbers as thats usually where, When its the washer type goes.
Only seen three types from FI, Throttle stops (On the external side of the carb(s)), Slide stops and Washers (Some with normal holes, Some with a 'pilot' hole and some with an oval hole)
If anyone needs dimensions for a 1991 GSXR slingshot (M) give me a PM Thumbs Up
www.oldskoolsuzuki.info
Bardeey
PostPosted: 23:00 - 25 Mar 2008    Post subject: Reply with quote
Are you sure about that? If the police pull you over they will ask for the certificate, they aint gonna strip your bike down and look for themselves there and then.. They will ask for you to produce the documents. Pretty sure of it, if that wasnt the case what's the point in wasting the trees!!!?
J.K.R
PostPosted: 23:46 - 25 Mar 2008    Post subject: Reply with quote
'Tis true.
FI just make out that they're the only legal way to do it. Tossers.
yankeedoodle
PostPosted: 23:51 - 25 Mar 2008    Post subject: Reply with quote
if you do a search on this forum there are hundreds of posts and debates about the whole restriction law. but it basically boils down to...the law requires you to be restricted to 33bhp.thats it.it's handy to have the certificate if you're pulled over because it gets the police off your case, but if they dyno your bike themselves and find that it is 33bhp, theres nothing they can do.
plus, just cos you have the certificate, who's to say you havent taken the washers out again afterwards?
The last post was made 18 years, 195 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.79 - MySQL Queries: 13 - Page Size: 128.19 Kb
