project 'too skint to buy a scottoiler'
virus
PostPosted: 15:12 - 29 Mar 2008    Post subject: project 'too skint to buy a scottoiler' Reply with quote
after seeing mr.z's hamster water bottle design, i decided to have a go myself, seen as my sister used to have a lot of tropical fish theres a lot of airline and various other gubbins floating around, so after a bit of bodgery we get this.
https://i251.photobucket.com/albums/gg307/virusjohn/evolution%20of%20cg/73a8abb9.jpg
gubbins put together, using one of the hobs on the cooker to melt the cap/tube joint so it doesnt leak. all the rest just pushes on as it was designed for that airline.
https://i251.photobucket.com/albums/gg307/virusjohn/evolution%20of%20cg/185a237f.jpg
the washing up liquid bottle (held on with a shoelace and a dodgy bit of coathanger wire)
https://i251.photobucket.com/albums/gg307/virusjohn/evolution%20of%20cg/01dfb28c.jpg
the tap thingy, and a one way valve on the end to act as an aiming doober
https://i251.photobucket.com/albums/gg307/virusjohn/evolution%20of%20cg/a4dfd4d5.jpg
John
own: 81 xs1100g...
Itchy
PostPosted: 15:31 - 29 Mar 2008    Post subject: Reply with quote
Erm don't you need a valve or hole or something to let air into the bottle to replace the oil that seeps out?.
virus
PostPosted: 15:40 - 29 Mar 2008    Post subject: Reply with quote
probably... Laughing
i havent tested it yet, so i shall carry a stanley knife with me when i do
John
own: 81 xs1100g...
neatbik
PostPosted: 17:20 - 29 Mar 2008    Post subject: Reply with quote
Mate, thats even more pikey than the hamster watery type thing one! Laughing
Well done Cool Thumbs Up
LeeR
PostPosted: 18:00 - 29 Mar 2008    Post subject: Reply with quote
Impressive mate, but is that really a chain only it looks shit brown, do they go that colour eventually? Wink
see I said don't give up the rattin'
My claim to fame: Austin Vince nicked my pen...
virus
PostPosted: 18:30 - 29 Mar 2008    Post subject: Reply with quote
aye it is a chain mate. Laughing
they go rusty pretty quickly when you go trail riding and completely ignore it, that thing hasn't been cleaned in over 6 months Laughing
getting a new chain soon because that one is f*cked
John
own: 81 xs1100g...
binge
Emo Kiddy
PostPosted: 20:09 - 29 Mar 2008    Post subject: Reply with quote
I thought Scott oilers ran off the Carb vacuum or something? Confused
Once you get a vacuum in that bottle, No oil will come out.
And if you do pop a hole in the bottle. Oil will dribble out 24/7 and you will end up with an empty bottle after a few days and a massive oil patch where you park the bike.
neatbik
PostPosted: 20:23 - 29 Mar 2008    Post subject: Reply with quote
i think youve got a point there binge..
John, what about using one of those little oil cans with the handle you pump? You could just give it a pump before and after a ride to lube the chain without it constantly dribbling
virus
PostPosted: 20:43 - 29 Mar 2008    Post subject: Reply with quote
oil wont be able to get out if i put a hole in the bottle, il tighten up the screw halfway down the line, this will stop oil flowing.
as ive said its not tested yet so some modifications may need to be done.
John
own: 81 xs1100g...
alun111
PostPosted: 21:10 - 29 Mar 2008    Post subject: Reply with quote
Have a look at [url=www.atct.co.uk/guyoiler.doc ]this[/url]
It's called the guyoiler and works off a fuel injector.
Scouse
PostPosted: 11:50 - 30 Mar 2008    Post subject: Reply with quote
He might as well just squeeze the bottle that he's got fitted now.
Virus why didn't you just use the same method as MR Z's bottle?
Damon
PostPosted: 12:13 - 30 Mar 2008    Post subject: Reply with quote
As said before you need a hole in the bottle and a tap that you can turn on and off when you are not using it.
and by the way, thats seriously pikey Thumbs Up
virus
PostPosted: 12:40 - 30 Mar 2008    Post subject: Reply with quote
didnt have a hamster water bottle floating around the house Laughing
own: 81 xs1100g...
Scouse
PostPosted: 12:47 - 30 Mar 2008    Post subject: Reply with quote
Fair enough Laughing
tutton
PostPosted: 22:00 - 02 Apr 2008    Post subject: Reply with quote
Just do like sprayguns do,
have a hole right at the top,
or get a popper and bond it in but thats harder and even more pikey than that already islmao!
colin1
Captain Safety
PostPosted: 22:45 - 02 Apr 2008    Post subject: Reply with quote
dont put a hole in the bottle
use it like a loobman
with that, you just give the bottle a squeeze to fill the pipe and squirt a bit on your chain after or before each ride
https://www.chainoiler.co.uk/
TUG
PostPosted: 22:57 - 02 Apr 2008    Post subject: Reply with quote
scotoilers hook upto the carbs or throttle bodies and operate a little diaphragm and the dial lets the diaphragm open so much.
you'd have to leave a breather in yours at the top somewhere then open the one way valve so much to let it drip so often like once every 5 mins? maybe a bit more or come up with your own little mechanism like the scotoiler. It works like a pump you see. Thumbs Up Smile
Haz ER-5, innit!
map
Mr Calendar
PostPosted: 23:10 - 02 Apr 2008    Post subject: Re: project 'too skint to buy a scottoiler' Reply with quote
Your Heath Robinson approach is to be commended.
However, spotting the missing lower chain guard if you replace this then the chain will effectively be running in its own oil bath Very Happy
colin1
Captain Safety
PostPosted: 23:16 - 02 Apr 2008    Post subject: Reply with quote
i reckon it would be better to imitate a loobman than a scottoiler, as it will be easier to control the flow of oil
the automatic process done by the scottoiler is only necessary on long trips where you wdnt want to be squeezing a bottle every few hundred miles, but even then, if you put it at the front of the bike it wouldnt be too bad.
if you let it flow out undergravity by putting a hole in the bottle, you will need a way of precisely controlling the flow rate which will be tricky. you could easily have either an oil slick or nothing coming out
if you work out a way to vary the flow rate then the hole method may be ok, but i reckon a closed system that you squeeze from time is gonna be a better bet
TUG
PostPosted: 23:27 - 02 Apr 2008    Post subject: Reply with quote
Like the little valve he has half way down? Where he can undo and tighten the little plastic screw? Rolling Eyes
Haz ER-5, innit!
virus
PostPosted: 12:24 - 04 Apr 2008    Post subject: Re: project 'too skint to buy a scottoiler' Reply with quote
true, but it gets battered too much on the trails, and i have given it away.
solution:
iris o ring chain and a loobman my mate gave me, job done Laughing
own: 81 xs1100g...
The last post was made 18 years, 111 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.67 - MySQL Queries: 13 - Page Size: 115.72 Kb
