Err What was that ?? Feel a bit stupid !
bigjim
PostPosted: 10:50 - 04 Apr 2008    Post subject: Err What was that ?? Feel a bit stupid ! Reply with quote
Pulled off from a set of lights this morning on the R6 and a 4x4 Merc next to me decided I was going to have it, so to ensure I was safely in front of him and out of his way I gave it a lot of berry’s Twisted Evil
The handle bars started shaking quite a bit, I dipped the clutch and it stopped and went up a gear and hard on it again no problems.
After discussing said incident with a mate he thinks I just had the front wheel up a bit, I assumed it was a mini tank slapper of some sort. Feel a bit: oops: as I have never had the front wheel up before!!
Is this going to be a common occurrence and should I be thinking about a steering damper? Or is it just a knee jerk reaction like the first time the back end stepped out on me Laughing
Jim
'97 - Thundercat - Sold
'08 - R6 - The Pocket Rocket - Sold
'09 - Street Triple R - The Monster
Ariel Badger
PostPosted: 11:01 - 04 Apr 2008    Post subject: Reply with quote
Sound like your front wheel may be a touch out of ballance. jack the front end up and test it by spinning, if it always stops at the same point it is in need of balancing.
Edit.... How are your tyre pressures, are your wheels in line?
bigjim
PostPosted: 11:08 - 04 Apr 2008    Post subject: Reply with quote
Pressures are spot on and the bike has only done 680 miles, hope yamaha didnt cock something up on the first service. Ill have to have a look.
Jim
Quote Me Happy
PostPosted: 11:11 - 04 Apr 2008    Post subject: Reply with quote
Probably the front coming up a bit and the wheel coming down a touch crossed up causing a wobble. If it was a tank slapper you'd know about it.
Forget the steering damper and get the suspension set up properly.
Kris
PostPosted: 11:13 - 04 Apr 2008    Post subject: Reply with quote
Your front wheel was possibly 'skimming' over the road surface as the front went light. When this happens the imperfections in the road surface cause the bars to oscillate, or slightly twitch. Nothing to worry about and stops as soon as the front wheel takes the bike's weight again.
www.prisonplanet.com
hairychipstic...
PostPosted: 11:14 - 04 Apr 2008    Post subject: Reply with quote
front just crested, slightly off the ground. it will happen, no biggie
you will notice it more if you go hammering along a non smooth road or hit random bumps while nailing it
damper's are good tho Thumbs Up but this wouldnt be cause for one
bigjim
PostPosted: 11:19 - 04 Apr 2008    Post subject: Reply with quote
Its already booked in for a setup with Kais performance, earliest I could get was three weeks Sad Must be good thou if their that busy !! Laughing
Cheers guys !!
PostPosted: 11:27 - 04 Apr 2008    Post subject: Reply with quote
Cheers guys !!
If it didn't spit you off, then it wasn't a tankslapper, it was just a headshake and they are 'supposed' to be fun! Laughing
Hetzer
PostPosted: 11:28 - 04 Apr 2008    Post subject: Reply with quote
What they said above.
But I'd advise you to get a damper ASAP, unless you're never going to give it the berries again. You WILL eventually come out of a corner hard, cranked over, and hit an irregularity while on the gas with the front a bit light, and then it'll be too late.
It's around £250 vs life & limb. A no-brainer really.
bigjim
PostPosted: 11:44 - 04 Apr 2008    Post subject: Reply with quote
Any recommendations ? any reviews anywhere worth looking at ?
Jim
boredatwork
PostPosted: 12:07 - 04 Apr 2008    Post subject: Reply with quote
hi
um i feel like im on a different planet
tank slapper, berries!?
help, what are you talking about
(as a cg125 rider, you understand there is nothing fruity about my bike)
DAS/Test: Passed March 08!
Bikes: CG 125 and k4 750 gsx-r
bigjim
PostPosted: 12:12 - 04 Apr 2008    Post subject: Reply with quote
boredatwork wrote:
hi
"giving it some berries" is just slang for opening the throttle as far as possible to go as quick as possible Very Happy
Check this page out and watch the video for a famous tank slapper, it explains it better than I ever could Wink
https://www.msgroup.org/tip.aspx?num=190
Jim[/u]
D O G
PostPosted: 12:45 - 04 Apr 2008    Post subject: Reply with quote
I'm surprised you have never had headshake out of your thundercat.
I generally feel that a steering damper is unneccesary for most situations - you are dulling feedback from your bike.
Just beacuse this is the first time it happened to you, which made you feel anxious, you are considering something to try and prevent it happening again. My view is that a small amount of headshake is not a problem, and gives you important information about how your bike is coping with situations.
The more you experience it, the more comfortable you will become with it, and indeed expect to get a bit of movement. It's nothing to worry about.
I think the general accepted opinion is that a steering damper will never prevent a proper tankslapper, but just dulls these small shakes. I'd rather have the shake (which I used to get regularly on the SRAD), and know what the bike is up to.
Waste of money in my view.
boredatwork
PostPosted: 13:08 - 04 Apr 2008    Post subject: Reply with quote
Jim[/u]
owwwwwww! that doesnt look funny at all.
thanks jim..
J.K.R
PostPosted: 14:29 - 04 Apr 2008    Post subject: Reply with quote
I'm sure (99%) that your R6 came with a steering damper Thinking
www.oldskoolsuzuki.info
veeeffarr
PostPosted: 14:37 - 04 Apr 2008    Post subject: Reply with quote
I get this all the time on the VFR, 10k+ in first and second are no go areas if I want to avoid headshake.
T
trevoriv
PostPosted: 14:45 - 04 Apr 2008    Post subject: Reply with quote
Dampers and suspension set up meh!
Just sounds like the front got light and left the ground a bit, to be expected when you give 115bhp to your rear wheel from a standing start Laughing
Scares the shizzle out of you if you dont expect it but you'll get used to it Mr. Green
bigjim
PostPosted: 14:54 - 04 Apr 2008    Post subject: Reply with quote
I was about 15k when it started Laughing
D O G
PostPosted: 15:07 - 04 Apr 2008    Post subject: Reply with quote
Only a couple of thousand left to go then! Should have just held it on then knocked it up the box Thumbs Up
Do it again next time you go out, you'll be ready for the movement this time. Keep loose on the bars and let them shake it out.
sickpup
Old Timer
PostPosted: 22:58 - 04 Apr 2008    Post subject: Reply with quote
Jim
Or learn to wheelie while cranked over.
Oh yes I am serious. Twisted Evil
The last post was made 18 years, 134 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.16 Sec - Server Load: 0.66 - MySQL Queries: 13 - Page Size: 114.64 Kb
