my poor little CG
kingsknight
PostPosted: 11:04 - 09 Apr 2008    Post subject: my poor little CG Reply with quote
Im not very happy, my CG has a rattle in its engine in the high revs Sad
so much for the CG lasting forever! I have changed the oil when i was ment to as well....
oh well a new engine it is for me then! anyone got one going cheap?
TS50 (sold) NS125F (sold) NSR125R-K (write off after 2 crashes) CG125 (nicked) XR125L-3 (Sold )-: ) DR125SM '11 (sold yay) XL125V '12 (In love with this bike) XT600E '04 (fun on the dirt)
TUG
PostPosted: 11:13 - 09 Apr 2008    Post subject: Re: my poor little CG Reply with quote
You done the valve clearance to the manual in the right section? (theres 2 one for the brazils and one for the early japanese models in the early manual, such a date to '95.)
EDIT: just read its a 2000 model, get a manual and set your valves to the manual and see how it goes, if its still making the noise set your carb up correctly and see if its still there, wrong mixture might be the cause. Thumbs Up
Haz ER-5, innit!
mr.z
PostPosted: 14:12 - 09 Apr 2008    Post subject: Reply with quote
If you have kept up with oil changes and not let it run low then its probably valves as lonewolf says, they get pretty loud when they loosen off, because there's not much stopping the noise. Most cgs with a few miles on are quite noisy this way because most haven't had them done for a long time or ever.
Even if it were terminal you can swap even majorish engine bits without much trouble in a day. Theres not many simpler 4stroke engines out there.
Failing that it'll get very loud before it finally went ping. which you might as well do if it was major.
kingsknight
PostPosted: 14:45 - 09 Apr 2008    Post subject: Reply with quote
I havent done the valve clearance so I took it to a shop near me to get them done and they said it sounds more like the big end bearings but it really does sound like the noise is coming from the top of the engine if you ask me!
I could even do the valve clearance wouldnt know where to start! Id wish to just pay someone to do it :-p
mr.z
PostPosted: 14:50 - 09 Apr 2008    Post subject: Reply with quote
I'd try elsewhere, and somewhere that don't sell bikes.. theres some right crooks out there.
"oh your bikes broken, never mind we'll take that one off your hands and sell you a new one"
/cynical
TUG
PostPosted: 14:51 - 09 Apr 2008    Post subject: Reply with quote
Big end? I'd do the valves first, what kind of garage did you take it to?
Haz ER-5, innit!
Cigaro
PostPosted: 15:37 - 09 Apr 2008    Post subject: Reply with quote
Sure it's not a loose camchain?
19van71
PostPosted: 16:06 - 09 Apr 2008    Post subject: Reply with quote
Don't have them do they??
Isn't it 'pushrod'? Confused
Living the dream....on my little 'ol CG125 Very Happy
Cigaro
PostPosted: 16:16 - 09 Apr 2008    Post subject: Reply with quote
Ah right, didn't know that - when I had my C90 that had a little rattle which I quietened down by adjusting the camchain, but obviously it's a different engine.
virus
PostPosted: 16:28 - 09 Apr 2008    Post subject: Reply with quote
its a pushrod engine,
i did a top end job on mine in under 2 hours, without taking the engine out.
check the valve clearances, change the oil, check the plug athigh revs.
if these are all ok, then id ignore it.. its a cg its designed to be abused, and trust me it can take it. Thumbs Up
John
own: 81 xs1100g...
kingsknight
PostPosted: 20:13 - 09 Apr 2008    Post subject: Reply with quote
it only happens in the high mid revs, if your in the high or low revs its fine!
i dont really understand the problem. you mainly hear it when your drop down a gear or slow down!
TUG
John
Take it? They just dont take it, they laugh at you, then spit in your face and call you a pussy. Thats what CG's do.
Haz ER-5, innit!
TUG
PostPosted: 20:18 - 09 Apr 2008    Post subject: Reply with quote
Is your brake lever touching your exhaust?
Haz ER-5, innit!
kingsknight
PostPosted: 21:58 - 09 Apr 2008    Post subject: Reply with quote
it could be, ill have a little ride and find! it does sound like a loud tapping. I havent even looked if it could be that!
Thanks for the advice, it makes a lot of sence if it was something like that because its only really loud when im riding the bike not when its at stand still.
TUG
PostPosted: 23:29 - 09 Apr 2008    Post subject: Reply with quote
Well just test it by pressing it down when riding, you'll soon find out, obviously not too much.
Haz ER-5, innit!
virus
PostPosted: 07:43 - 10 Apr 2008    Post subject: Reply with quote
is it stumbling at any revs? engine running through the rev range without holding back/bogging down?
if its at 3/4 then it could be a needle height problem on the carb causing it to bog down and clatter like hell.
if the performance has dropped them id also check your points, you dont need the flywheel off to do this, just the left hand case, then rotate the flywheel so the F mark is going past the mark on the engine, if the points (seen through the hole in the flywheel) are opening and closing then your ok. mine welded themself together and really messed it up, it would clatter like hell at 3/4 and on full it would take an age to get there.
John
own: 81 xs1100g...
kingsknight
PostPosted: 10:23 - 10 Apr 2008    Post subject: Reply with quote
it does have a very slight flat spot in the low revs were it does slow for just a sec, its not a points system its the CDI version!
I havent noticed any drop in speed! it still rides the same just doesnt sound right in the mid high rev range
its not the brake lever too Sad
kingsknight
PostPosted: 17:11 - 10 Apr 2008    Post subject: Reply with quote
finding an engine for my kickstart CDI 2000 model CG is harder then i thought.
the cheapest iv found is like £270 and that had 6k on it. im looking to pay about £150 when it needs replacing
Endless Nameless
PostPosted: 17:28 - 10 Apr 2008    Post subject: Reply with quote
Who says it'll need replacing Confused
If everyone replaced an engine every time they heard a funny noise then no-one would ever get anything done (and no-one would ride old bikes!)
A2 passed 22/07/08; restriction up 22/07/10 (just so I don't forget)
'79 Suzuki GS550E. Yes, that's a GS550, not a GS500.
Supersports "In a video editing competition I'd kick your sorry ass"
kingsknight
PostPosted: 17:50 - 10 Apr 2008    Post subject: Reply with quote
well i dont want it failing me on my way to work, its the only thing iv got to get me around
Endless Nameless
PostPosted: 18:03 - 10 Apr 2008    Post subject: Reply with quote
you even checked the valves lol? Even if it is the big end bearings, which I very much doubt, thats cheaper than a new engine and not terribly difficult. But it's probably the top end, and a rattle is unlikely to mean it's on death's door anyway! Seems totally daft to blow £200 + on a "new" engine, which tbh probably wont be much better and is an unknown quantity, throwing away your (probably) perfectly good engine in the process, when you could just sort out what you've already got.
Just my Penny Coin Penny Coin , t'aint my bike after all. But you do seem to be making a mountain out of a molehill!
Anyway, £270 for an engine? £30 more got me an MOT'd bike!
kingsknight
PostPosted: 18:19 - 10 Apr 2008    Post subject: Reply with quote
your just trying to save me money and for that i thank you, i just have never had a 4 stroke before all my bikes have been the simpler 2 stroke engine!
Noxious89123
PostPosted: 21:52 - 10 Apr 2008    Post subject: Reply with quote
Get some speed and then close the throttle and pull in th clutch.
Does the noise go away? If not, it's likely your drive chain. Caused a rattl on my cbr125 when it got rather slack + unoiled.
Kal
PostPosted: 23:55 - 11 Apr 2008    Post subject: Reply with quote
Ah that explains your nerves.
It's a CG - the only one I've ever seen killed was done by the owner running it without any oil in it which did lead the engine eating itself.
Relax. Oh and if you did have to buy a replacement engine for some bizarre reason then you should be looking at £60-£75
Kal...
kingsknight
PostPosted: 15:35 - 12 Apr 2008    Post subject: Reply with quote
it just sounds like the engine is going to fall apart when im in that rev range but as soon as im passed it, it sounds fine
The last post was made 18 years, 218 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 1.35 - MySQL Queries: 13 - Page Size: 130.94 Kb
