Electric start only starts after a Bump start!
saikouslx
PostPosted: 15:23 - 13 Apr 2008    Post subject: Electric start only starts after a Bump start! Reply with quote
I have a 1999 Derbi GPR50. I got a new battery for it the other day and the electric start worked. However now i have to bump start it, then once the engine is warmed up i can use the electric start. Btw the old battery was dead hence replacement. Whats causing this? Cause i dont wanna have to bump start my bike every morning :/.
CaNsA
PostPosted: 15:29 - 13 Apr 2008    Post subject: Reply with quote
What terminal did u connect 1st? the plus or the minus?
saikouslx
PostPosted: 15:34 - 13 Apr 2008    Post subject: Reply with quote
positive (i think) , it worked fine the first couple of times.... Then i was riding my bike stalled it, and then i guess never the same.
CaNsA
PostPosted: 15:36 - 13 Apr 2008    Post subject: Reply with quote
Im cant remember correctly but, if you connect one of the terminals first then u risk of shorting ur electrics out.
Shocked Shocked Shocked
saikouslx
PostPosted: 15:44 - 13 Apr 2008    Post subject: Reply with quote
nah my electrics are fine. It the elctric start button works, just that the engine wont start! Of i bump start it, ride it for a bit, turn off igntion, turn it back on and press the button and rev, it works!
superslick
PostPosted: 20:10 - 13 Apr 2008    Post subject: Reply with quote
Probably because its not fueling right on choke and the starter isn't powerful enough to get the engine going when its cold. Try pissing around with the idle screw and move it half a turn to try and get it going.
aprillia rs125 gp-1 2004
superslick
PostPosted: 19:53 - 14 Apr 2008    Post subject: Reply with quote
any luck?
nightshaddow
PostPosted: 19:59 - 14 Apr 2008    Post subject: Reply with quote
check that they havent come loose slightly if not sounds life the batterie fluid level may be low so not getting a propper output
saikouslx
PostPosted: 21:18 - 14 Apr 2008    Post subject: Reply with quote
well i played with the screw thingy abit. It seems more wanting to start. Also i think my choke might be screwed. How do i know for shure, any other suggestions?
The last post was made 18 years, 216 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.04 Sec - Server Load: 0.83 - MySQL Queries: 13 - Page Size: 59.21 Kb
