ARGH! what has gone wrong with my rs125?
superslick
PostPosted: 17:04 - 13 Apr 2008    Post subject: ARGH! what has gone wrong with my rs125? Reply with quote
Hi guys
Right, last Monday i bought an aprilia rs125 gp-1 2004 from my local dealer and iv warmed it up every single day and have finally had time to get out on it today, so..
i warmed it up to around 60', set off slowly, went down a steep hill keeping in a high gear, came to the bottom of the hill and started driving up another steep hill, changed down a gear and was on my way up the hill when the bike cut out, cut in, then died. i pulled over and tried numerous times to start it again on the electric start and no luck, on about the 3rd attempt it backfired. I let it sit for about 3 mins then pushed it down the hill and tried to bump it and it seemed to be compressing properly but it just wouldn't start at all.
So, pushed it home, took the spark plug out and it was wet so i dried it off, checked for spark (strong spark) put it back in and tried to start it but after numerous attempts it would not start and now has a flat battery.
I though it could have blown a hole in the piston but it does sound to be compressing and there is no blowing when trying to start it, and it only backfired the once.
Does anyone know what might be wrong with it?? it had an engine rebuild around 320 miles ago and has always started up fine. Its not the end of the world as i have another bike to get around and the RS is still covered under the used bikes warranty but its so damn annoying!
And yes i have checked the fuel is switched on etc! lol
Thanks, Jon
aprillia rs125 gp-1 2004
benjami
PostPosted: 17:13 - 13 Apr 2008    Post subject: Reply with quote
Is there enough fuel in the tank to be getting through on 'on'?
Also, are you running it in still?
Carb ok?
5v3d3b0
PostPosted: 17:14 - 13 Apr 2008    Post subject: Reply with quote
Wet sparkplug doesn't sound right...
https://www.dansmc.com/Spark_Plugs/Spark_Plugs_catalog.html
superslick
PostPosted: 17:18 - 13 Apr 2008    Post subject: Reply with quote
Nearly a full tank of fuel in. Done approx 320 miles since the rebuild and as the dealers mechanic told me, it is run in.
benjami
PostPosted: 17:57 - 13 Apr 2008    Post subject: Reply with quote
Confused Mechanic is talking out of his arse so it seems.
According to my manual - 500 miles of below 6,000 rpm riding.
Followed by a further 200 miles of under 9,000 rpm riding.
5v3d3b0
PostPosted: 18:02 - 13 Apr 2008    Post subject: Reply with quote
If it had a bottom end rebuild the running in is up to 1000 miles under 9000 RPM...
I believe it is :Vary throttle for 100 miles. Then under 6000 RPM for 500 miles, varying throttle. Then under 9000 RPM until 1000 miles, and from there on never exceed 11000 RPM
Tonight when I get home I can give the exact quote from my Haynes manual
superslick
PostPosted: 18:25 - 13 Apr 2008    Post subject: Reply with quote
Right, typed below is the full list of parts on the receipt for the work done.
CHECK - START PISTON SOUNDS NOISY, BATTERY FLAT. CHECK KILL SWITCH + GET RUNNING
APRILIA OIL SEAL
APRILIA OIL SEAL
NSK BEARING 6005
NSK BEARING 6302
OIL SEAL 22 X 12 X 7
APRILIA NUT RS125
APRILIA RS125 GASKET 122 ENGINE
NSK BEARING 6206
APRILIA 125 P/KIT
CON ROD KIT RS125 ROTAX BIG END KIT
APRILIA RS125 GASKET-CLUTCH
APRILIA RX/RS 125 PLATE - CLUTCH
APRILIA RX/RS 125 SCREW, ADJU
NUT (1KT) APRILIA 8120531
PARTS - £232.37
LABOUR - £150
carried out at raceways in Fleetwood.
Timmeh
PostPosted: 20:26 - 13 Apr 2008    Post subject: Reply with quote
What colour is the sparkplug?
superslick
PostPosted: 20:34 - 13 Apr 2008    Post subject: Reply with quote
dark brown
Timmeh
PostPosted: 20:52 - 13 Apr 2008    Post subject: Reply with quote
hmm. dark brown is an ok colour. Had it been white or glazed I'd have gone for a fuelling problem.
Another compression check and then a top-end inspection is on the cards.
superslick
PostPosted: 20:57 - 13 Apr 2008    Post subject: Reply with quote
Going to send it back to the dealer this week to get it fixed under warranty.
Hopefully get them to pick it up tomorrow, or sometime soon.
Although, if it had a hole in the piston or really bad compression would it not backfire every time the piston got to top dead center on the first stroke?
stirlinggaz
PostPosted: 23:47 - 13 Apr 2008    Post subject: Reply with quote
Hi,
dont want to sound stoopid,
but have you tried a new plug?
i know you said you were getting a good spark, but i had this same problem, with a NGKbr10 plug.
plug was wet.
held it against frame & was getting a blue spark.
but when i cleaned it up & put it back in, bike wouldnt start.
bought a couple of new plugs, br8,br9 & br10.
tried the br9 first, bike started first time.
so i kept it in, till i changed the carb.
now using br10 iridium & never had a problem since.
i now treat plugs as disposable items!
cheers,
GAZ
superslick
PostPosted: 20:50 - 14 Apr 2008    Post subject: Reply with quote
i took the br9es out the dirt bike and tried that but had no luck.
superslick
PostPosted: 20:52 - 14 Apr 2008    Post subject: Reply with quote
a friend of mine has an rs125 and exactly the same happened to his (bogged down, cut out, backfired, wouldnt start) and changing the plug fixed his but iv tried it with mine and bumped it down the road numerous times but to no success
stirlinggaz
PostPosted: 22:28 - 14 Apr 2008    Post subject: Reply with quote
hi,
when mine wont start, here the routine i follow :
makes sures thers plenty of petrol in,
battery FULLY charged,anything under 12v & i charge it up.(doesnt like getting bumped, or im not doing it right?)
stick tap on reserve, (common problem for filter to block in on position)
fit new plug,
give it a couple of presses on starter,
if it doesnt start after 3 or 4 attempts,
use the choke for a few seconds, but always starts before i get to use choke, unless its really cold outside.
if youve done all that, & it wont start, id be taking it to the bike doctor,
cheers,
GAZ
L3G3ND_MTX
PostPosted: 00:13 - 15 Apr 2008    Post subject: Reply with quote
To be honest with you, if you have taken a spark plug out of your dirt bike they might be completely diffrent plugs to your RS they all have diffrent temp 2 run at etc. (correct me if im wrong) thats why you have to have the exact plug for your bike maby this is an issue?
Just a thaught.
tutton
PostPosted: 16:58 - 15 Apr 2008    Post subject: Reply with quote
Thats a good question ^^ he poses.
why do you have br9 plugs for a rs125 engine on your dirtbike?
unless you have a rs lump on it?
superslick
PostPosted: 17:36 - 15 Apr 2008    Post subject: Reply with quote
well, the dirt bike iv got is a 2006 aprilia rx50r. Uses the exact same spark plug (br9..) as my friend used to get his rs125 working.
Anyhow the bike was collected by the dealer today from my house and hopefully should be diagnosed. up and running before long.
liam7388
PostPosted: 11:47 - 10 May 2008    Post subject: HELP Reply with quote
stirlinggaz wrote:
hi,
fit new plug,
cheers,
GAZ
If the problem is that its the fuel filter, can it still be road round on the reserve or will it not last very long (Might sound stupid don't know if the reserve is a seperate tank. lol)
I'm gettin the same problem with my 03 model but if i put it on reserve its seems to be ok up to yet. I've check the CDI and the bridge has been cut so I know the emission restrictor has been done, but I've also noticed few wires twisted together in a black cable, which don't don't appear to go to anything? Pic can be took if needed.
Any help appreciated, not really had chance to ride it since ave bought it.
liam7388
PostPosted: 11:49 - 10 May 2008    Post subject: Reply with quote
Also won't go above 6000 rpm unless I keep bliping the clutch, was in power band its ok. Any help plz
Damon
PostPosted: 11:56 - 10 May 2008    Post subject: Reply with quote
What colour powerband does it have?
liam7388
PostPosted: 13:09 - 10 May 2008    Post subject: Reply with quote
What you onna bout? What colour is it?
tutton
PostPosted: 15:56 - 10 May 2008    Post subject: Reply with quote
Lol hes fucking with you,
veeeffarr
PostPosted: 08:49 - 16 May 2008    Post subject: Re: ARGH! what has gone wrong with my rs125? Reply with quote
Er? What?
Keir
PostPosted: 12:19 - 16 May 2008    Post subject: Re: ARGH! what has gone wrong with my rs125? Reply with quote
Er? What?
I think what he means is:
It was rebuilt 320 miles ago. he has started it every evening, revved the arsehole out of it and turned it off. then when he got round to riding it he wondered why its popped.
I think i know why.... Rolling Eyes
Current : '08 Yamaha FZ1s
The last post was made 18 years, 169 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.82 - MySQL Queries: 13 - Page Size: 129.34 Kb
