Nsr 125 1994
myyyh
PostPosted: 20:23 - 06 Apr 2008    Post subject: Nsr 125 1994 Reply with quote
hi. i have a 1994mod nsr 125ccm with Fp cdi unit and gianelli exaust.
original sprokets.
it make about 140 km/h and i wounder if someone know what i can do to make it go faster=)
djrichieb
PostPosted: 08:07 - 07 Apr 2008    Post subject: Reply with quote
Have a look at your powervalve control unit it should read TV-78 if its unrestricted and TV-124 if its restricted. Its near the battery under the tank hinge roughly.
Rides: Honda CB400 SF (ART can) - Citroen Saxo 1.1i SX
myyyh
PostPosted: 09:47 - 07 Apr 2008    Post subject: Reply with quote
i have TV-78.
kaup This post is not being displayed because it has a low rating (Abusive). Unhide this post / all posts.
djrichieb
PostPosted: 12:28 - 07 Apr 2008    Post subject: Reply with quote
If the powervalve says TV-78 and the CDI has CI626 on it then its not restricted. Has the intake plate been restricted?
Does the powervalve move at different rev's?
If not i'll check the compression etc.
myyyh
PostPosted: 08:57 - 11 Apr 2008    Post subject: Reply with quote
the bike has no restriction, how much should it about make?
alains
PostPosted: 08:25 - 12 Apr 2008    Post subject: Reply with quote
depense on your sprockets , with 14x36 you should reach 160 km/h at 11000 rpm (with a 17" rear wheel)
myyyh
PostPosted: 09:24 - 14 Apr 2008    Post subject: Reply with quote
i got 14x36 sprokets and 17" rear wheel, but when i go from about 11000rpm in 5th and shifts to 6th gear it goes down to about 8000rpm. have any thougts about why?
hmmmnz
PostPosted: 10:09 - 14 Apr 2008    Post subject: Reply with quote
when was the last time it had a rebuild??
it might just be getting close, im not too sure if the nsr's are susceptible to carbon build up in the exhaust like other 2 strokes, but that quite often slows them down quite a bit
the humans are dead
I kick arse for the lord
alains
upjet your carb as 138,42,65 https://www.dellorto.co.uk mail to Mattew cooper [email protected] (~£12)
fit carbon reeds https://cgi.ebay.fr/Carbon-Membrane-Tuning-Honda-NSR125-NSR-125-CRM-CR-036_W0QQitemZ120173390573QQihZ002QQcategoryZ25632QQcmdZViewItemQQ_trksidZp1742.m153.l1262
use BR9EIX plug https://www.sparkplugs.co.uk (~£8)
myyyh
PostPosted: 11:34 - 14 Apr 2008    Post subject: Reply with quote
will i get more speed if i use a re-destricted exaust (the original)? instead of gianelli?
do i get much effect of the reeds and the sparkplug?
myyyh
PostPosted: 11:37 - 14 Apr 2008    Post subject: Reply with quote
What do u mean when you say rebuild?
i`ve heard something about re-destricted sylinders?
i use a engine from an nsr 2000 mod.
myyyh
PostPosted: 11:39 - 14 Apr 2008    Post subject: Reply with quote
what should it be written on the Cdi unit if it not are restricted?
alains
PostPosted: 11:54 - 14 Apr 2008    Post subject: Reply with quote
KBS which denotes a foxeye model
CI626 (not CI626A) the other writing has no matter
about the RC/valves control unit unrestricted is KBS (as above) TV78 the other writing has no matter
note : if some of you buy one on EBAY , item from earlier model will not fit and they are marked KY4 TV78
hmmmnz
PostPosted: 18:13 - 14 Apr 2008    Post subject: Reply with quote
like all 2strokes, they wear out, and require rebuilds, not model specific, Very Happy
the humans are dead
alains
PostPosted: 18:38 - 14 Apr 2008    Post subject: Reply with quote
they require de-coke and at least rings change every 7500 miles , more than that is at your own risks and you may have your power going down
myyyh
PostPosted: 21:44 - 14 Apr 2008    Post subject: Reply with quote
the engine have only went about 10000km
myyyh
PostPosted: 11:47 - 15 Apr 2008    Post subject: Reply with quote
What does De-coke mean?
something like clean the sylinder top?
alains
PostPosted: 12:43 - 15 Apr 2008    Post subject: Reply with quote
yes , cleaning all carbon from , top piston,cylinder head,exhaust port and RC/valves . carbon deposit will make your engine weaker & hoter . the rings must be changed because the barrel is coated with nikasil which is a carbide far much harder than the rings and consequently the rings wear out much faster than the barrel
myyyh
PostPosted: 16:46 - 15 Apr 2008    Post subject: Reply with quote
my cdi unit is KY4 ci572, is this re-destricted?
alains
PostPosted: 18:03 - 15 Apr 2008    Post subject: Reply with quote
no ! is your bike a JC20 (1989-1992) ? otherwise you have the wrong CDI
myyyh
PostPosted: 18:15 - 15 Apr 2008    Post subject: Reply with quote
i have a honda nsr 1994 with a nsr 2000 engine.
is this bad?
kaup
PostPosted: 18:25 - 15 Apr 2008    Post subject: Reply with quote
it`s realy bad, your engine will blow up in few miles Laughing
alains
i doubt your bike is from 1994 , look your serial number it should start like ZDCJC228....... otherwise i am right , especially if it starts HDJC20.......
CI572 is fitted on JC20 , UK models (in france it's CI589C) a green/white wire (security stand) is missing on these CDI
mister kaup it's better you go away with this stupid answer . did you try to afraid or was it a joke ? in both case it shows a short brain
myyyh
PostPosted: 18:30 - 15 Apr 2008    Post subject: Reply with quote
zdcjc229001000070.
but the engine and the wiring are from a 2000mod Nsr.
the Cdi unit is KY4 ci572
The last post was made 18 years, 214 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: biskey (www) - Page Generation Time: 0.06 Sec - Server Load: 0.95 - MySQL Queries: 13 - Page Size: 122.07 Kb
