Zx6r pinking in low revs
Elz
PostPosted: 11:34 - 15 Apr 2008    Post subject: Zx6r pinking in low revs Reply with quote
When i let the throttle off and the revs drop the bike is fine untill it idles in 2nd and 1st gear...it then starts to pink....when i wind the throttle back on, the bike pinks untill the revs are up above 4000. If i lift the revs up to 4000 by using the clutch then letting the clutch out, the bike is fine.
The bike is idling at 1300 revs which is spot on.
The bike is a ninja zx6r year 2001 and has only covered 4500 miles
Please help
"Burn rubber not your soul"
Barry_M2
PostPosted: 12:18 - 15 Apr 2008    Post subject: Reply with quote
Its not pinking, it wont do it at such low revs then clear out at higher revs.
What makes you think you getting detonation?
ZXR750R (M2) - For the road.
CBR1000 RR4 - For the track.
Elz
PostPosted: 12:30 - 15 Apr 2008    Post subject: Reply with quote
Example. I am coming up to a round about i let the throttle off because the car in front has slowed down.....the revs drop to it idling in 2nd gear....the car moves...i put some revs on to go around the round about and BLUR>>>BLUR BLUR>>>BLUR BLUR BLUR then 4000 revs and its then nice and the acceleration becomes nice and smooth
Barry_M2
PostPosted: 14:32 - 15 Apr 2008    Post subject: Reply with quote
Thats not pinking.
I 'think' a 2001 ZX6 is carb'd isn't it? If so, it sounds more like your pilot jets are blocked, which would explain why it clears around 4k, as that'll be rougly when the mains come into play.
Elz
PostPosted: 14:49 - 15 Apr 2008    Post subject: Reply with quote
That sounds expensive?
Barry_M2
PostPosted: 14:57 - 15 Apr 2008    Post subject: Reply with quote
Well, if you do it yourself it wont cost you a penny.
You just need to get the carbs off and clean out the pilot jets. Hopefully thats all the problem is, sounds like it to me.
Elz
PostPosted: 11:19 - 16 Apr 2008    Post subject: Reply with quote
I wouldnt know where to start.
I have also been told it could be the spark plugs?
bugsy46
Village Idiot
PostPosted: 12:00 - 16 Apr 2008    Post subject: Reply with quote
If the pilot jets were blocked it wouldnt idle properly
Laura - "And where did looks come into this and bugsy leave steven alone. You are not gods gift to women you may think you are but you're not."
Keith - "All the best"
Barry_M2
PostPosted: 12:05 - 16 Apr 2008    Post subject: Reply with quote
That depends how blocked they were. Completely then no, it wont, but if its a slight block of just 1 or 2 of the jets then it would idle (may sound a little lumpy) and then stutter as mentioned above.
bugsy46
Village Idiot
PostPosted: 12:57 - 16 Apr 2008    Post subject: Reply with quote
Yeah
Id be looking elsewhere though. The transition of jets is done by throttle position not revs. If your idle is set up by carb balance and air screw and is still erratic then yes I would imagine jets. But if it is idling well like you say I would imagine it would be something else. I would expect a bike in neutral to show up pilot jet problems just by increasing the revs with no engine load at all which ive seen lots of times. Just have a look at your idle speed when warm and look for it dropping on and off
Elz
PostPosted: 14:18 - 16 Apr 2008    Post subject: Reply with quote
Idle is 100% ok.
Going to change the spark plugs and see how i get on from there
hmmmnz
PostPosted: 00:57 - 17 Apr 2008    Post subject: Reply with quote
my money is on valve clearances Thumbs Up
i bet though if you change plugs ect.. it'll clear up for a time... but i bet it'll be back Very Happy
the humans are dead
I kick arse for the lord
The last post was made 18 years, 200 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.09 Sec - Server Load: 2.61 - MySQL Queries: 13 - Page Size: 73.66 Kb
