Rough running?
R1stu
Shrek!
PostPosted: 22:50 - 12 Feb 2004    Post subject: Rough running? Reply with quote
Well the R6 seems to be getting a hammering at the moment in terms of running problems, with cougs and that.
I think mine is also a bit out, I think it might be carbs after have the bike laid down a few times.
When i'm cruising along at a steady rpm, the bike seems to be "gurgley" the only way else I can describe it is like when the engine is being run in and feels tight. It just feels sluggish and wants to splutter but dosent.
What you guys think? Every since I had the casings smashed I can swear I hear "Noises" but don't we all after we brake our bikes? Rolling Eyes
Carbon closet tart! https://www.bikepics.com/members/r6stuk/02r6/
Stolen bike. 2000 R1: https://www.bikepics.com/members/r6stuk/00r1/
Current bike 1991 Honda ST1100 Pan European, 1986 Honda cb350sg (Finished)
mattd
PostPosted: 22:57 - 12 Feb 2004    Post subject: Reply with quote
Have you tried a carb balance mate?
Carbs can be knocked out of sync on a drop.....
Checked the plugs? One or more could be fouled...
Hex
Party Boy
Has it had a good service lately?
Maybe just try flushing the oil out, run for a few mins - with new oil, drain and fill with new oil again.
This should take a lot of any bits that "may" be in there mate.
When were the carbs last balanced?
But as you say it could just be the paranoia we all suffer - I hear noises from my bike that I'm sure shouldn't be there but Keith said it sounded fine so it must be fine. Very Happy (Guess I'm just used to car engines that rev out when my bike is starting to make its power. Laughing )
The BCF's very own Party boy! Though he's getting old and feeling it!
Monkey hanger, Born and bred
My little photo portfolio
R1stu
Shrek!
PostPosted: 23:00 - 12 Feb 2004    Post subject: Reply with quote
It has not been serviced since new. I have done 6.5k now as well. I got to have some warranty work done soon so was going to look at a service at the same time, for a mere £200. Shocked My Karma is worse than a yo-yo at the moment!
Hex
Party Boy
PostPosted: 23:02 - 12 Feb 2004    Post subject: Reply with quote
Mate, it's over due a good service then.
Do it yourself not that hard to be honest - oil, plugs, filters and then get the carbs balanced if you cant borrow a set of gauges yourself!
R1stu
Shrek!
PostPosted: 23:06 - 12 Feb 2004    Post subject: Reply with quote
Rather let the boys do it! I know its done right then and keeps the warranty intact plus needs some other bits doing!
PostPosted: 23:29 - 12 Feb 2004    Post subject: Reply with quote
By leaving it 6,500 miles from new to get it serviced has fucked your warrenty anyway.
mattd
PostPosted: 23:31 - 12 Feb 2004    Post subject: Reply with quote
I'm not too far mate if you need a hand, I have a Morgan Carbtune II if you would like to borrow it.
I'm pretty sure that changing the oil and servicing it yourself doesn't void the warranty
R1stu
Shrek!
PostPosted: 23:32 - 12 Feb 2004    Post subject: Reply with quote
Not really as the service mannual states that the 2nd service is due at 6k and Im only over by 500 miles so its not that bad.
ZaphodBeeble
PostPosted: 23:51 - 12 Feb 2004    Post subject: Reply with quote
I always do it myself to make sure its done right. Don't take my car or bikes to anyone to get fixed. Seriously it's better to do it yourself, you get to know your bike on a more personal level and you know when its done right Very Happy
Current bike: VTR1000F Firestorm. Previous: Firestorm (written off) - XJ600 Divvy - NSR125 - DT125 and a load of offroaders.
R1stu
Shrek!
PostPosted: 00:14 - 13 Feb 2004    Post subject: Reply with quote
I tend to make things worse when I try to fix them, well my bikes anyway. I still haven't managed to tighting the head bearing even after doing it twice, (1st time I made it worse).
changed the oil, couldn't get the sump off! Managed to lose loads of screws and forgot to put a screw back in the engine, so I left it out! Bike still seems ok! Razz
lost a part of the gearbox into the engine when I tried to rebuild my KE100 and stuff like that.
Managed to change the subframe and stuff, but I wont touch carbs and balancing them. Plus I cant get the plugs out!
mattd
PostPosted: 00:17 - 13 Feb 2004    Post subject: Reply with quote
Oh dear lol
So, you've had those plugs for over 6000miles now?
As for balancing carbs, I'm not too fond of it, especially the screw-in adaptor type a la R6 Shocked
R1stu
Shrek!
PostPosted: 00:26 - 13 Feb 2004    Post subject: Reply with quote
6k yes! is that bad then?
ZaphodBeeble
PostPosted: 00:32 - 13 Feb 2004    Post subject: Reply with quote
Yeah thats quite high mileage for a sparker. Get a new set and you'll notice the difference straight away. Also, you should check your air filters as they tend to drain power from your bike as they get blocked up. They are easy to check/change, even a complete idiot could do it Razz
mattd
PostPosted: 00:33 - 13 Feb 2004    Post subject: Reply with quote
Well, it's down to how well you look after your bike, I usually change plugs every 5k or so (or whenever they need changing when I get roudn to checking them Razz ), but the way you say your bike is running sounds like a duff plug causing one of the cylinders to misfire....hence the gurgling (unburnt petrol) and sluggishness (the misfiring piston slowing the others down)
Have you *really* tried to get the plugs out?
ZaphodBeeble
PostPosted: 00:38 - 13 Feb 2004    Post subject: Reply with quote
I should imagine that taking off the tank and the seat would make it easier to take the spark plugs out. Just make sure you remember to switch the petrol valve off before removing the pipe!
Good luck whatever you do... Thumbs Up
Sparks!
Sir Tart-a-lot
PostPosted: 00:53 - 13 Feb 2004    Post subject: Reply with quote
You'll 100% notice difference by a service.
Do plugs, air filter, oil, oil filter etc.
If you can polish rims and do nice tarty stuff, you must be able to do the general service things?
Hex
Party Boy
PostPosted: 09:29 - 13 Feb 2004    Post subject: Reply with quote
I'm sure a spark plug will last longer than 6000 miles (in a 4 stroke), infact I'm sure the 6000 miles is just inspect and gap the spark plugs and change if necessary.
I think on the CBR its 8000 or 12000 mile service that actually changes the plugs.
either way, get the service done - if you must take it to the garage mate take it (least your happy that its been done right then opposed to you ham fisting it up).
Though you will save a good bit of money doing it yourself (hardest part will be balancing the carbs), in your tool kit for the bike (if you have one) you should have a tool to remove the spark plugs.
PostPosted: 10:18 - 13 Feb 2004    Post subject: Reply with quote
500 miles is enough for Yamaha to turn around and say that you have invalidated your warranty. The number of miles or time limit to the next service is supposed to be an absolute maximum AFAIK, and I usally get my bikes done a bit early if possible.
Although, I can't see them *actually*holding you to it, because you could conceivably been on a 3000 mile touring holiday in the alps! Smile
R1stu
Shrek!
PostPosted: 10:35 - 13 Feb 2004    Post subject: Reply with quote
If I really wanted I could do it myself just don't have the time. I work to 8pm most days and I don't have a garage to work in so when It rains it will cause havoc.
Carbs could prob do, just don't want to chance it plus I don't have all the right tools.
I have an haynes manual but don't fancy taking off the tank and stuff as keep losing bits.
Rather do it right 1st time, then bodge it and have to take it somewhere to get them to look at it.
Hex
Party Boy
PostPosted: 11:01 - 13 Feb 2004    Post subject: Reply with quote
Fair enough - get it to a garage and get it serviced then mate. Hopefully will feel a lot better afterwards. Very Happy
Kris
PostPosted: 11:09 - 13 Feb 2004    Post subject: Reply with quote
Nothing more embarassing than having to admit to a dealer that you 'bodged it and it broke' Confused I think that's the recognised cue to begin rip-off proceedings tbh...
Anyway, Stu give your bike a good dealer service and I bet she'll be fine Thumbs Up
www.prisonplanet.com
mattd
PostPosted: 11:22 - 13 Feb 2004    Post subject: Reply with quote
I'm not sure about the Yamaha dealer in Soton, but the Kawasaki Dealer in Portswood I always goto, best service and a very honest...I have the feeling that I'm not going to be ripped off when I go there (unlike other places in Portswood Evil or Very Mad )
ZaphodBeeble
PostPosted: 12:04 - 13 Feb 2004    Post subject: Reply with quote
Yeah but saying that he still has problems and it's worth doing the easiest thing to see if it works. Sparkers are the first things I change when the bike feels grotty.
R1stu
Shrek!
PostPosted: 22:04 - 13 Feb 2004    Post subject: Reply with quote
Parkrd powerbikes is not too bad tbh. I brought the bike new there and they kept it until I paid for it in full (couldn't get credit so they kept until payment finished) and the bike I got is the sons best mates old bike, so I don't think it be butchered.
The last post was made 22 years, 141 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 1.31 - MySQL Queries: 13 - Page Size: 134.06 Kb
