Nsr 125 2000
kaup
PostPosted: 10:57 - 16 Apr 2008    Post subject: Nsr 125 2000 Reply with quote
Hello.
I have a nsr 125 with malossi 180 cylinder, re-destricted exhaus, 13x36 sprocket and CI626. I have cut the rpm wire who stop at 10500. And I only get 150 km/t on flat road Confused
This is slow, what is wrong ? Sad
PostPosted: 11:17 - 16 Apr 2008    Post subject: Re: Nsr 125 2000 Reply with quote
kaup wrote:
Hello.
I have malossi 180 cylinder, re-destricted exhaus, 13x36 sprocket and CI626. I have cut the rpm wire who stop at 10500. And I only get 150 km/t on flat road Confused
A Re destricted exhaust eh? No wonder...
to be honest mate 95mph ish is probably all you're going to get, even with all that tuning.
kaup
PostPosted: 11:24 - 16 Apr 2008    Post subject: Re: Nsr 125 2000 Reply with quote
MarJay wrote:
kaup wrote:
Hello.
The exhaus is Un-Restricted. I think I could drive faster with 14 sprocket, people in Norway talk about 170-180 km/t with 14 sprocket. I woundred if that true or not.
95mph - 153 km/t
alains
PostPosted: 13:53 - 16 Apr 2008    Post subject: Reply with quote
with the huge torque on the malossi a 14 teeth front sprocket is the minimum , i think you can fit a 15 teeth
so actually you have a final transmission of 2,77 fitting a 14 in the front will give you 2,57 and 160 km/h , fitting a 15 give you 170 km/h
kaup
PostPosted: 15:10 - 16 Apr 2008    Post subject: Reply with quote
Then i buy 15 front and 36 back? With 15 sprocket will I have max speed or acceleration? Is it bad acceleration with 15 sprocket ? Rolling Eyes
Will the engine be damage if I drive in 170 km/t ?
alains
PostPosted: 15:51 - 16 Apr 2008    Post subject: Reply with quote
you said i am on 13x36 , so for few quids buy 14 & 15 front sprockets . first fit the 14 , see what you get and if you feel it's still nervous , fit the 15 .
https://www.jtsprockets.com/52.0.html?&L=1&sel_uid=151&p=
kaup
PostPosted: 16:24 - 16 Apr 2008    Post subject: Reply with quote
Okei, I will buy 15 sprockets when I order. Is there somthing else I can do to drive faster? Have the engine good to be drive so hard?
alains
PostPosted: 19:00 - 16 Apr 2008    Post subject: Reply with quote
i warn you about big bore , if you dont drive smoothly , your crank (and your kit) will worn in little time . tune your oil pump 2-3 mm before lining the notches . what carb you have and which jetting ?
kaup
PostPosted: 19:40 - 16 Apr 2008    Post subject: Reply with quote
"big bore" - 180 cylinder ?
I have drive 3000km without tuned the oil pump, I have drive 3-4km in 130km/h. So I think I could drive like this.. Or ?
28mm carb, 140 mainjet
alains
PostPosted: 20:02 - 16 Apr 2008    Post subject: Reply with quote
every kit over 125cc is a big bore
better carb tunning : main jet 145-148 , idle jet 45 , power jet 70-75
kaup
PostPosted: 20:13 - 16 Apr 2008    Post subject: Reply with quote
I have drive with 150, it`s to big.. I know a guy who drive with 138 main jet, that worked.
What happen if I switch to 70-75 power jet insteed the orginal ? Will I get better gasrespons ?
alains
PostPosted: 20:28 - 16 Apr 2008    Post subject: Reply with quote
it will ease high revs (and protect against seizure)
kaup
PostPosted: 21:25 - 16 Apr 2008    Post subject: Reply with quote
I can have 11000rpm in 5th and 11000rpm in 6th, it`s easy. So do you mean I have to buy power jet? No one I know have change power jet in their carb, and they could drive. One guy have drive 8000km before hi sold his bike, and the bike still run Very Happy
alains
PostPosted: 21:45 - 16 Apr 2008    Post subject: Reply with quote
it's more secure
The last post was made 18 years, 192 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.49 - MySQL Queries: 13 - Page Size: 80.96 Kb
