possibly flashed by camera
Deano
PostPosted: 12:44 - 18 Apr 2008    Post subject: possibly flashed by camera Reply with quote
I was going through a 40mph road yesterday and was doing nearly 50mph before the camera. I slowed myself with the back brake just before (back brake light is not working at the moment) going through the camera and looked down and found I was doing just over 40 mph halfway through the camera lines. i glanced into my mirror and THINK i may of been flashed as it was sunny yesterday so my view was not the best.
my question is if I have been flashed when would I expect to see something in the post? if I do get somethign I rekon it would be something like 43mph in a 40 zone. what would I be expecting to get points wise.
I might be paranoid but rather be prepared for the worst rather than just shruggin it off.
m0l0t0v
PostPosted: 12:51 - 18 Apr 2008    Post subject: Reply with quote
The lowest they can do you for is around 46 as I got through on my NIP. They give a 10% give and add 2mph on top. 35 in a 30, 46 in a 40, etc
If you have been flashed you might get an NIP within 2 weeks.
Could have been a dummy one.
Don't you have a blue Hornet? Thinking
If so you should've pinned it as you would've been too fast for the camera to see Thumbs Up Cool Thumbs Up
map
Mr Calendar
PostPosted: 12:57 - 18 Apr 2008    Post subject: Reply with quote
m0l0t0v wrote:
T...They give a 10% give and add 2mph on top. 35 in a 30, 46 in a 40, etc....
You'd think that wouldn't you. However, there was a camera in Telford a bit back that was run by the council and so didn't have to follow ACPO guidelines.
Given speedos usually read a bit over you may be ok if the needle was hovering in the mid 40s.
As said the +10%+2mph 'rule' gives the minimum speed for prosecution, not the maximum speed you can travel without prosecution (as most people tend to think).
HTH Thumbs Up
Adam80UK
PostPosted: 13:22 - 18 Apr 2008    Post subject: Reply with quote
Isn't that the same thing?
As for recieving anything in the post, if you don't recieve an NIP within 14 days, you're off the hook even if it arrives after. There are exceptions however, i.e. if the bike isn't registered to you.
Current: '07 Suzuki SV1000 & '07 Honda SH300i (again).
Previously owned: '08 Yamaha R1, '10 Kawasaki Z1000, '07 Honda SH300i, '04 Suzuki SV1000S, '11 Honda CB1000R, '09 Kawasaki ZX-10R, '08 Aprilia Tuono 1000R, '07 Triumph Daytona 675, '95 Honda CBR600F.
map
Mr Calendar
PostPosted: 13:26 - 18 Apr 2008    Post subject: Reply with quote
Coxy_UK wrote:
Isn't that the same thing?...
Err, NO.
You can travel at 45mph in a 40 zone and not be prosecuted. Travel at 46mph in the 40 zone and you can be prosecuted.
Hope that clarifies Thumbs Up
Bandito
PostPosted: 13:43 - 18 Apr 2008    Post subject: Reply with quote
14 working days, but have to allow 3 days after that for the post to deliver it, as they have 14 days for it to leave their office, not 14 days for it to land on your doormat
Deano
PostPosted: 13:57 - 18 Apr 2008    Post subject: Reply with quote
Ok, cool , my fingers are crossed
leatherpatche...
PostPosted: 14:09 - 18 Apr 2008    Post subject: Reply with quote
map wrote:
Err, NO.
Not correct either. You can be prosecuted for travelling even 41mph in a 40mph zone. However, most guidelines advise setting the cameras higher than this. It's not called a 40mph speed limit for nothing. If you could not be prosecuted under 46mph then it would be a 45mph speed limit. The law says you're not allowed to go over the upper limit at all.
Finglonga
PostPosted: 15:09 - 18 Apr 2008    Post subject: Reply with quote
As above the 10%+2mph is just a guideline nothing more the speed can be set at 31,41 etc.
Speedo's over read anyway so if your speedo says 40mph chances are your doing about 38-39 anyway and safe from being flashed.
Andy Sez....
F.Y.Y.F.F.
MrRoper
PostPosted: 16:13 - 18 Apr 2008    Post subject: Reply with quote
I believe it has to be on your doormat within 14 days, as it has to be "served" within 14 days. thats what pepipoo says anyhow Smile
CBR600F
"Good people do not need laws to tell them to act responsibly, while bad people will find a way around the laws." - Plato
Kal
PostPosted: 16:21 - 18 Apr 2008    Post subject: Reply with quote
There was one in Orton Goldhay, Peterborough that was notoriously sensitive.
Kal...
Finglonga
PostPosted: 20:44 - 18 Apr 2008    Post subject: Reply with quote
Can be on your doormat in 20/30/40 days as long as it was posted in the first 14 days it doesn't matter.
Andy Sez....
F.Y.Y.F.F.
PostPosted: 20:51 - 18 Apr 2008    Post subject: Reply with quote
Speedos aren't supposed to be allowed to under-read at all, though I suspect mine does by a few mph.
Adam80UK
PostPosted: 04:08 - 19 Apr 2008    Post subject: Reply with quote
Nope, must recieve it within 14 days of the commission of the offence. See section 1 of the Road Traffic Offenders Act 1988.
The last post was made 18 years, 191 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.78 - MySQL Queries: 13 - Page Size: 87.46 Kb
