| chunkielad |
 chunkielad Nearly there...
| Valentino Mossy |
 Valentino Mossy World Chat Champion
 Posted: 00:14 - 15 Feb 2004 Post subject: |
Thats a bugger !
They nice as pie when they want to sell you something,and dont want to know when something goes wrong !
Are you changing the cambelt as well ?
Maybe it would be cheaper for you to buy the parts of the net and get the local garage to do it for you ?
I did that with my mx5, Mazda wanted £450 for the cam belt change, the local garage did it for £120 and the parts i got was £60.
But you dont get the stamp in the book though is the thing  ____________________ Ducati 916,white framed corse replica https://www.bikechatforums.com/viewtopic.php?t=239309
https://blauschatfroums.freeforums.net/ |
| Fuddymumpster |
 Fuddymumpster Two Stroke Sniffer
 Posted: 00:31 - 15 Feb 2004 Post subject: |
How old is your car? How many miles has it done?
From memory it is a 2L 16V TS engine. The early ones of those had a known problem with the cam belt tensioner. They often failed early, taking the cam belt out and resulting in the valves and pistons meeting. If the tensioner has failed without the belt jumping then you are very lucky.
However any of these early tensioners should really have been changed by now. On these engines never change the belt without changing the tensioner (although the same applies to many modern engines).
Warrenties are a waste of time as they have so many exclusions. Worst of it is that a full service history really does not mean that much anymore. For example on our Clio the cam belt is due to be changed at 70000 miles, but the dealers will only do this if they are instructed to. Most of the servicing is done for leasing companies, and they play a numbers game. A load of cam belt changes skipped will pay for the odd car which fails (the rest will fail after they sell the car on, so they don't care).
By the way the Alfa 16V TS engine is not an easy one to change the belt on properly. The correct way of doing it is using a replacement tempory camshaft cam to locate the cams correctly.
| chunkielad |
The last post was made 22 years, 137 days ago. Instead of replying here, would creating a new thread be more useful? |
