Mito & RS service intervals.
MetalheadA7X
PostPosted: 11:45 - 26 Apr 2008    Post subject: Mito & RS service intervals. Reply with quote
Can someone give some idea of this.
I like the look of the mito or the RS but i have heard they need constant top end rebuilds and attention to keep running.
Thanks in advance!
Chris
Robby
Dirty Old Man
PostPosted: 15:41 - 26 Apr 2008    Post subject: Reply with quote
They make over 250bhp per litre. So they need some attention.
As long as you warm it up properly and use very expensive fully synthetic 2 stroke oil (the current favourite seems to be castrol TTS at about £12/litre) it will last fairly well. Keith on here knows his stuff, I think he checks the rings every 6k km and expects a rebuild every 2nd or 3rd ring check.
So looking after it, if it was your only form of transport, you would need to do a rebuild once a year. If its a toy, more like once every 5 or 6 years.
The only problem is that lots of them are owned and abuse by kids with no money to fix them. So you could buy one and find its got a poor quality and poorly installed piston or big bore kit, or its shattered a piston in the past and damaged the crank, or the bore is knackered...
Basically, I would only buy one if the seller obviously knew their stuff and had owned it for a while (through at least one rebuild) or if it was very cheap, so that I could budget for a rebuild.
Thom
PostPosted: 16:41 - 26 Apr 2008    Post subject: Reply with quote
Chris theres workshop manuals on here that should tell you the service intervals of both.
you know my fave, the NSR, but to be honest i reckon no matter which of the three you choose if you ride conservatively you should be ok Thumbs Up
PostPosted: 10:27 - 06 May 2008    Post subject: Reply with quote
On my RS I change the rings every 6000km. People seem to get away with doing it less frequently on the Mito. The NSR has a lot longer life expectancy for the rings but is also less powerful. Pays your money and takes your choice.
As Robby says they make a lot of power for their engine capacity, added to which unlike larger bikes they spend a lot more of their time being thrashed.
The last post was made 18 years, 127 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.14 Sec - Server Load: 0.41 - MySQL Queries: 13 - Page Size: 40.76 Kb
