Stiff Gear pedal problems
Irdawood the 2nd
PostPosted: 23:21 - 19 Feb 2004    Post subject: Stiff Gear pedal problems Reply with quote
hey guys just having a few probs with the bike, hopefully someone will know whats up with it. It seems everytime/very often when i change gear the dam pedal is soo stiff as in its hard for me to change gear the pedal just wont move however sometimes its sweet but mostly its not it actually takes a lot of effort to change gear... this problem has only started happening ever since that dam snow where i accidently left the bike outside
im not sure but i think when im at higher speeds as in 40-50+ gear changing is easier but at low speeds its stiff.....also to get it into neutral is such a massive pain only way i can do it sometimes is by switching engine off then putting it into neutral or.. I can put it into neutral when im going slow as in <10mph if im at standstill and the engine is running it is near impossible
sprockets and chain a brand new changed them at X-mas
EuropeanNC30R...
Gay Hairdresser
PostPosted: 23:27 - 19 Feb 2004    Post subject: Reply with quote
When's the last time you changed the gearbox oil?
Mr C
PostPosted: 23:28 - 19 Feb 2004    Post subject: Reply with quote
is the chain too tight when you are sitting on the bike ?
187.3bhp = 201mph
Irdawood the 2nd
PostPosted: 23:31 - 19 Feb 2004    Post subject: Reply with quote
No mate chain is not tight. only just adjusted that as it was soo slack. Last time i changed gear oil was like early November time i think.
EuropeanNC30R...
Gay Hairdresser
PostPosted: 23:57 - 19 Feb 2004    Post subject: Reply with quote
You might aswell start by changing the gear oil again for what it'll cost you, won't hurt either. My RGV needed the oil changing every couple k miles to keep the gearchange sweet.
Irdawood the 2nd
PostPosted: 00:06 - 20 Feb 2004    Post subject: Reply with quote
I have put some WD40 around the pedal also on the break pedal, as that is stuck if i push the lever on that it remains down i have to physically pull the pedal back up again...Anyways ive put WD40 on both pedals if that dont work then i'll change the gear oil and put greece on the break pedal. Hopefuly that will sort it.
Dam you snow!!! lol Neutral
Also any other ideas if that is not the case tho?
syris
PostPosted: 00:52 - 20 Feb 2004    Post subject: Reply with quote
Over the 3 weeks during winter my bike was away the gear lever stuck and a drop of motor oil done the trick.
Irdawood the 2nd
PostPosted: 01:01 - 20 Feb 2004    Post subject: Reply with quote
Was is completly stuck or just sometimes when changing gears...as mines sometimes changes gear like butter. But othertime its a real real hard
syris
PostPosted: 01:24 - 20 Feb 2004    Post subject: Reply with quote
It was completely stuck but with some oil and alot of abuse it eventually gave in, after about 20 minutes riding.
Irdawood the 2nd
PostPosted: 23:21 - 20 Feb 2004    Post subject: Reply with quote
I put WD40 on and some more greace put still no luck i think it isnt the pedal and is something on the inside. Dont have a clue what else it could be. And it is now starting to worry me. Im going to change the gear oil over the weekend sometime.
But like what else could it be if its not the gear oil?
PostPosted: 23:24 - 20 Feb 2004    Post subject: Reply with quote
You went all the way to Greece to find something to help your gear pedal problems? Blimey...
Irdawood the 2nd
PostPosted: 23:28 - 20 Feb 2004    Post subject: Reply with quote
Woops best correct that Smile
but at this moment in time im willing to goto japan and back to correct the problem. I really want to get it all nice and perfect to how it was. Laughing
Irdawood the 2nd
PostPosted: 00:26 - 01 Mar 2004    Post subject: Reply with quote
Heya just an update and a request for further help/advice.
I have now changed the gear oil, put a shed load of greace and stuff on the pedal but to no avail... anyone have any other ideas?
cheers
PostPosted: 00:35 - 01 Mar 2004    Post subject: Reply with quote
Adjust the clutch, check the chain is adjusted correctly, and check the gear change shaft is not bent (can happen if the chain snaps).
The last post was made 22 years, 223 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.11 Sec - Server Load: 1.01 - MySQL Queries: 13 - Page Size: 79.52 Kb
