Serious front end moddage
Itchy
PostPosted: 12:33 - 03 May 2008    Post subject: Serious front end moddage Reply with quote
I utterly hate doing fork seals , and my NTV ones are looking decidedly dodgy...
also might need some stanchions as one of them is rotting pretty badly.
So I thought of the Hassock front end....which needs no fork seals per se,.
I thought hold on , on ebay I can get REAR shocks for £50 a pop off CBR600RRs , so in my mind I've imagined replacing the stanchions with 2 CBR600RR rear shocks, with my NTV as a test bed anybody actually any ideas on how to secure it? as rear shocks have bearings at the top and bottom which mean you can't just stick a solid piece of steel into them as your forks will rotate. Or has anybody actually done this?.
Any thoughts?
Thanks
Damon
PostPosted: 15:31 - 03 May 2008    Post subject: Re: Serious front end moddage Reply with quote
Any thoughts?
Thanks
umm... interesting
good luck Rolling Eyes
aero
PostPosted: 16:38 - 03 May 2008    Post subject: Reply with quote
must be talking in his sleep.
hmmmnz
PostPosted: 19:08 - 03 May 2008    Post subject: Reply with quote
a hossock system is the same as whats on the britten or alot of the bmw bikes
solid forks that dont move but connected to a pivot with either 1 or 2 shocks, the benifit is that both forks move at the same rate and the wheel always stays centered to the bike,unlike normal forks is you have a oil leak or a stuffed spring they can move at different rate, and the only think keeping the wheel center is the axle
https://easyweb.easynet.co.uk/ian.huntly/BRITOP.jpg
https://images.sportrider.com/bikes/2005/2005-bmw-k12s-g-22-zoom.jpg
https://www.tonyfoale.com/Articles/Steer/Steer3.gif
https://www.tonyfoale.com/gallery/FrontEnd/images/Hossack_jpg.jpg
https://www.tonyfoale.com/gallery/QL/QL_P6.jpg
the humans are dead
I kick arse for the lord
sickpup
Old Timer
PostPosted: 13:42 - 04 May 2008    Post subject: Reply with quote
Note its Hossack NOT Hassock
hmmmnz
PostPosted: 14:13 - 04 May 2008    Post subject: Reply with quote
sorry, spelling mistakes DO happen Mr. Green
the humans are dead
dr_adams
PostPosted: 05:43 - 05 May 2008    Post subject: Re: Serious front end moddage Reply with quote
Any thoughts?
Thanks
yeah, it wouldn't work, the rear shock is set for forces that are very different from the front. The hossock setup normally works by having levers on the frame and the shock controls their action, like a swinging arm for the front, thus a similar shock can be used so you would need to replicate this, the amount of travel on a rear shock is small as it normally works on the swinging arm acting as a lever so the travel is reduced proportationally. would maybe suggest changing the forks to different ones if you want to improve it... yokes can be made but beware of changing the geometry of the bike to much!
Ariel Badger
PostPosted: 09:08 - 05 May 2008    Post subject: Reply with quote
We old boys always knew that telescopic forks were a fad and girders would come back as the fork of choice. Mr. Green
The last post was made 18 years, 163 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.12 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 77.55 Kb
