yam sr125
nsr125rossie
PostPosted: 18:45 - 01 May 2008    Post subject: yam sr125 Reply with quote
hi where to start i have a yam sr125 it keeps cutting out i have cleaned the carb caecked all the wirering new spark plug tryed coil and cdi unit so i havent got a clue can some one out there help me please
nightshaddow
PostPosted: 19:01 - 01 May 2008    Post subject: Reply with quote
this could be sooooooo easy as mine used to do the same, it should have a run and cut off switch mine would cutt off without moving the switch but if you put your finger on top of the switch and push down and release it will probably click from under the seat, if it does it is the switch, clean it up and bobs your uncle and all that, if you still have trouble try cross wireing the switch wires,
if its not that they also have a side stand switch which could be faulty or even possibly the fuse
depending on how old the bike is i would almost cirtainly say the engine cutoff switch or the wireing to it
petemell
PostPosted: 19:04 - 01 May 2008    Post subject: Reply with quote
Have you checked the ignition barrel for corrosion, it may need replacing.
nsr125rossie
PostPosted: 22:46 - 01 May 2008    Post subject: Reply with quote
thanks very much i will try every thing tomorrow and i will let u no it has had my life i like the bike its a nice ride
nsr125rossie
PostPosted: 16:20 - 02 May 2008    Post subject: Reply with quote
hi i tryed every thing and still doing it some times it feels like it is runing out ov petrol but i have cleaned the carb and the tap on the tank has like a plastic nut thing i tuc that off and that was clean it seems ok when u go slow and not flog it in the gears so i am stuk help i am good with bikes and cars but this has got me stunped
FreshAL
Sir Crashalot
PostPosted: 16:41 - 02 May 2008    Post subject: Reply with quote
Water in petrol maybe?
nsr125rossie
PostPosted: 18:15 - 02 May 2008    Post subject: Reply with quote
no new petrol in it am going to take the tap off the tank tomoz b
petemell
PostPosted: 18:35 - 02 May 2008    Post subject: Reply with quote
Is the carb float set to the right height. If it is too low it could be causing fuel starvation.
nsr125rossie
PostPosted: 19:21 - 03 May 2008    Post subject: Reply with quote
hi every one i think i have sorted the problem out i think it was the float in the carb the pin that the float pushes up there is a little plate on the float it was sqaust sort ov so i have opened it about 6 mm so its ok so far done about 20mile on it but how fast are sr s ment to go mine only gose about 55mph it is fast getting there like
nightshaddow
PostPosted: 19:54 - 03 May 2008    Post subject: Reply with quote
they do about 55 60 mph though mine did 70 with a bit of playing with the sprockets and a bit of jetting i had a k&n air filter 115 main jet 15 tooth frount sproket
nsr125rossie
PostPosted: 16:36 - 07 May 2008    Post subject: Reply with quote
hi every one bike going ok but i come off it so its back in the garage sick as first time i have ever come off a bike no much damage indercater lense /gear lever bent not to bad i am ok just my pride lol
The last post was made 18 years, 137 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.06 Sec - Server Load: 0.75 - MySQL Queries: 13 - Page Size: 68.18 Kb
