Speedfighter Help....
thuglyf06
PostPosted: 20:41 - 03 May 2008    Post subject: Speedfighter Help.... Reply with quote
ive recently got a speed fighter y reg but its all in bits.
have been told the starter motor is dead and got a new one. but i wired it up without the relay as i think its bust so i put some copper wire across the two terminals and pronto the starter motor fired up but then died.
since that the starter motor wont work. hav a blown it??? there is power in the red cable to the starter motor........
also how do i start the bike?? hold right brake and push red button??
PostPosted: 22:07 - 03 May 2008    Post subject: Reply with quote
To start it you can hold either brakes and press the button.
Bets thing to do is put the bike completely back together and then start fixing the problems. If the starter motor doesn't work after you've put it back together, that's the time to replace it.
thuglyf06
PostPosted: 09:15 - 04 May 2008    Post subject: Reply with quote
when i press a brake in and push the putton the engine oil can lights comes on...
PostPosted: 13:13 - 04 May 2008    Post subject: Reply with quote
Souns like something is wired up wrong then. As if you had wired the starter button to the oil light Confused
The oil light should come on when you turn the ignition on and turn off when you start the bike up.
thuglyf06
PostPosted: 17:09 - 04 May 2008    Post subject: Reply with quote
i decieded to go for your idea and put the starter motor actaully on the bike. i have done this and it wont kick over. but when i took the relay off and put a wire from the red from batter to red too the starter motor it turned over staraight away without pressing any buttons or anything like that. :S.
rezzin
PostPosted: 18:27 - 04 May 2008    Post subject: Reply with quote
First thing,speedfight formerly known as speedshite. Done. Thumbs Up
PostPosted: 19:23 - 04 May 2008    Post subject: Reply with quote
They can't be that bad or else why would so many people own them Wink
thuglyf06
PostPosted: 20:26 - 04 May 2008    Post subject: Reply with quote
anyone know where i can get a cheap relay from?
binge
Emo Kiddy
PostPosted: 20:43 - 04 May 2008    Post subject: Reply with quote
Agreed. The Speedfight isnt bad at all. I had 4 of them. Thumbs Up
Sounds like you have a dead relay if its firing up when you short the two terminals across and bypass the relay.
Failing that, You have a pair of broken brake light switches.
Does your brake light come on when you pull either of the levers?
If the brake light doesn't come on, then obviously the brake light switches don't work, Meaning it wont start, as the brakes need to be applied (either one) to engage the starter motor.
Also IIRC, the Starter motor uses its fixings on the scooter as an earth, So it wont work unless it is bolted to the bike I don't think.
Ben
thuglyf06
PostPosted: 19:33 - 05 May 2008    Post subject: Reply with quote
good thinking mate!
all the wiring is disconnected as the bike it in bits and plastics everywhere lol.
so i have to have the brake lights hooked up to get it going....
so relay still might be fine??
The last post was made 18 years, 136 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 1.13 - MySQL Queries: 13 - Page Size: 62.25 Kb
