Big single won't start - backfiring through airbox
loply
PostPosted: 20:25 - 03 May 2008    Post subject: Big single won't start - backfiring through airbox Reply with quote
Hi folks,
I have a Yamaha SZR660 which I don't ride. I start the engine once a month or so and give it a few handfulls for 10 minutes to keep it running.
Normally its a bit hard to start but after a few mins comes in.
The other night it started then died right away (this is normal), but it won't start again after that.
The engine turns over fine and once every few seconds a "puff" noise comes from the airbox. It's like a pop of air coming up out of the engine.
Some investigation revealed the airbox had been popped off the carbs. I put it back on but it still does the same noise (albeit without the airbox coming off).
Any ideas where to start? it has a spark, fuel is going through, starter is turning over nice and fast...
Thanks for any advice folks.
Yamaha SZR660 Caution to the wind, the throttle pinned!
LeeR
PostPosted: 20:33 - 03 May 2008    Post subject: Reply with quote
I owned a 650cc 1cyl and only had it back fire on start-up a couple of times, it was down to a bone dry air filter on both occasions. I appreciate this may not be the fix for you problem but it could be worth checking the condition of the air filter. Thumbs Up
My claim to fame: Austin Vince nicked my pen...
ssray
PostPosted: 22:54 - 03 May 2008    Post subject: Reply with quote
Try a brand new sparkplug, if its started and not run the plug will not get hot enough to burn off any fuel residue on the plug.
The only times i had a single spit back was timing out,not very likely
on a szr or the cam timing had slipped.
look for thumper club on google
2006 _p1
PostPosted: 09:39 - 04 May 2008    Post subject: Reply with quote
if you keep trying to start it and its gettting a spark and fuel on the plug it has problary gone. try a new plug and see what happends. happend to me when i kept trying to start my bike. Thumbs Up
loply
PostPosted: 11:21 - 04 May 2008    Post subject: Reply with quote
This is an SZR660 btw.
I'll pop the plug out and give it a good clean, then replace it if it's no different.
Thanks for the tips thusfar.
Odie
PostPosted: 12:36 - 04 May 2008    Post subject: Reply with quote
Had similar happen on a CX500 i had laid up, turned out to be stale fuel!
2006 _p1
PostPosted: 13:04 - 04 May 2008    Post subject: Reply with quote
cleaning it dont usually work if its been coverd in fuel with out igniteing it.
well try it if not pop out and get a new one! Thumbs Up
thegubner
PostPosted: 13:33 - 04 May 2008    Post subject: Reply with quote
Has the fuel in the tank been there a long time?
loply
PostPosted: 13:53 - 04 May 2008    Post subject: Reply with quote
It's been there for quite a while (since September or so), but having said that it did usually run fine once every three or four weeks.
I accept that it could do with changing though Smile
These engines are supposed to be able to run on anything that's vaguely liquid in form though...
tutton
PostPosted: 15:01 - 04 May 2008    Post subject: Reply with quote
People say that,
but obviously will run better on fresh fuel.
bet that fuel in there has no vapour left at all
hence the shit starting qualities of it.
thegubner
PostPosted: 17:12 - 04 May 2008    Post subject: Reply with quote
tutton wrote:
People say that,
And it leaves a jelly like film on stuff I believe which also prevents starting.
loply
PostPosted: 18:07 - 04 May 2008    Post subject: Reply with quote
Okay folks I popped the spark plug out and it did look a bit gummed up but it was sparking. I have little or no experience with spark plug problems but to me it looked intermittent.
I went out and bought a new spark plug and now it won't spark at all! Even with the old one back in... Because of the design of the HT lead you can't try the lead against the chasis for a spark.
As far as I can see the HT lead is permanently fixed into a black cylinder (which I guess is the coil).
Any suggestions what to try? Is there a way I can verify if the coil is working or blown?
I guess the HT lead or spark plug cap could be at fault, but it generally looks in good nic, how do you normally disconnect it to test/replace?
Thanks for any help.
tutton
PostPosted: 20:13 - 04 May 2008    Post subject: Reply with quote
You do have the plug in the ht lead out of the cylinder when putting against frame to try see for a spark right?
Ariel Badger
PostPosted: 21:59 - 04 May 2008    Post subject: Reply with quote
I take it that there is some electricity in the battery?
loply
PostPosted: 08:31 - 05 May 2008    Post subject: Reply with quote
yeah there's plenty of battery, I hooked up a booster battery just in case too.
I have the plug out of the cylinder, does part of the plug body need to be grounding on the engine/frame?
Ichy
PostPosted: 08:45 - 05 May 2008    Post subject: Reply with quote
The threaded bit that screws into the cylinder head should be earthed.
Ariel Badger
PostPosted: 08:57 - 05 May 2008    Post subject: Reply with quote
If the plug is not going to earth it will not spark. If you can not earth it put your finger up the plug cap, you should get a high voltage low ampage shock when you turn the engine over. It will tickle a bit but it will not hurt you seriously.
Irezumi aka Reuben
Carrot Top
PostPosted: 12:01 - 05 May 2008    Post subject: Reply with quote
Try cutting the end off the HT lead.
They corrode and exposing a new bit can make it spark a lot better.
loply
PostPosted: 12:16 - 06 May 2008    Post subject: Reply with quote
Hi folks,
Oddly when I first removed the old spark plug I tested it without grounding it on the frame and it sparked intermittently, hence it never occured to me to ground the new one on the frame either.
In any case the spark was fine after I did this but it still wouldn't start.
Popped off the carbs, took them all apart and cleaned and wiped everything. Nothing was particularly dirty but did it anyway. Sprayed them with loads of WD40 followed by copious amounts of compressed air.
Put them back on, put fresh fuel in and it fired up within a few minutes.
Thanks for the help guys!
The last post was made 18 years, 125 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.10 Sec - Server Load: 0.29 - MySQL Queries: 13 - Page Size: 100.83 Kb
