| loply |
 loply World Chat Champion
 Posted: 20:25 - 03 May 2008 Post subject: Big single won't start - backfiring through airbox |
Hi folks,
I have a Yamaha SZR660 which I don't ride. I start the engine once a month or so and give it a few handfulls for 10 minutes to keep it running.
Normally its a bit hard to start but after a few mins comes in.
The other night it started then died right away (this is normal), but it won't start again after that.
The engine turns over fine and once every few seconds a "puff" noise comes from the airbox. It's like a pop of air coming up out of the engine.
Some investigation revealed the airbox had been popped off the carbs. I put it back on but it still does the same noise (albeit without the airbox coming off).
Any ideas where to start? it has a spark, fuel is going through, starter is turning over nice and fast...
Thanks for any advice folks. ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| LeeR |
 LeeR World Chat Champion
 Posted: 20:33 - 03 May 2008 Post subject: |
I owned a 650cc 1cyl and only had it back fire on start-up a couple of times, it was down to a bone dry air filter on both occasions. I appreciate this may not be the fix for you problem but it could be worth checking the condition of the air filter.  ____________________ My claim to fame: Austin Vince nicked my pen... |
| ssray |
 ssray Borekit Bruiser
| 2006 _p1 |
 2006 _p1 Crazy Courier
 Posted: 09:39 - 04 May 2008 Post subject: |
if you keep trying to start it and its gettting a spark and fuel on the plug it has problary gone. try a new plug and see what happends. happend to me when i kept trying to start my bike.  |
| loply |
 Posted: 11:21 - 04 May 2008 Post subject: |
This is an SZR660 btw.
I'll pop the plug out and give it a good clean, then replace it if it's no different.
Thanks for the tips thusfar. ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| Odie |
 Odie World Chat Champion
| 2006 _p1 |
| thegubner |
 thegubner World Chat Champion
| loply |
 Posted: 13:53 - 04 May 2008 Post subject: |
It's been there for quite a while (since September or so), but having said that it did usually run fine once every three or four weeks.
I accept that it could do with changing though
These engines are supposed to be able to run on anything that's vaguely liquid in form though... ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| tutton |
 tutton World Chat Champion
| thegubner |
| loply |
 Posted: 18:07 - 04 May 2008 Post subject: |
Okay folks I popped the spark plug out and it did look a bit gummed up but it was sparking. I have little or no experience with spark plug problems but to me it looked intermittent.
I went out and bought a new spark plug and now it won't spark at all! Even with the old one back in... Because of the design of the HT lead you can't try the lead against the chasis for a spark.
As far as I can see the HT lead is permanently fixed into a black cylinder (which I guess is the coil).
Any suggestions what to try? Is there a way I can verify if the coil is working or blown?
I guess the HT lead or spark plug cap could be at fault, but it generally looks in good nic, how do you normally disconnect it to test/replace?
Thanks for any help. ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| tutton |
| Ariel Badger |
 Ariel Badger Super Spammer
| loply |
 Posted: 08:31 - 05 May 2008 Post subject: |
yeah there's plenty of battery, I hooked up a booster battery just in case too.
I have the plug out of the cylinder, does part of the plug body need to be grounding on the engine/frame? ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
| Ichy |
 Ichy World Chat Champion
| Ariel Badger |
| Irezumi aka Reuben |
 Irezumi aka Reuben Carrot Top
| loply |
 Posted: 12:16 - 06 May 2008 Post subject: |
Hi folks,
Oddly when I first removed the old spark plug I tested it without grounding it on the frame and it sparked intermittently, hence it never occured to me to ground the new one on the frame either.
In any case the spark was fine after I did this but it still wouldn't start.
Popped off the carbs, took them all apart and cleaned and wiped everything. Nothing was particularly dirty but did it anyway. Sprayed them with loads of WD40 followed by copious amounts of compressed air.
Put them back on, put fresh fuel in and it fired up within a few minutes.
Thanks for the help guys! ____________________ Yamaha SZR660 Caution to the wind, the throttle pinned! |
The last post was made 18 years, 125 days ago. Instead of replying here, would creating a new thread be more useful? |
