Front sprocket O ring (oil seal)
PostPosted: 10:37 - 04 May 2008    Post subject: Front sprocket O ring (oil seal) Reply with quote
Hi,
I changed the "O" ring on my front sprocket a few weeks ago,and all was well,until a few day's ago.
It has started leaking againĀ  :11doh:
When i fitted the new ring,i pushed it too far back and it was not flush with the outer casing the way it should be,but to correct it at the time would have meant destroying the "O" ring to get it back out,so i just left it like that and it was fine.
Anyway,i have just took it back out now to get it ready for the new O ring coming tomorrow,and i thought id try fitting it back in,but this time flush with the casing the way it should be.
Did that and started the engine,and it's leaking quite bad.
I did'nt think the oil behind this o ring would be under so much pressure?
I can actually see the oil forcing it's way past the o ring(at the point of the o ring where i stuck a screwdriver into it,to get it out,so it does have a split in it.)
Is this normal?>and if i just fit another new o ring,should it solve the problem~?
https://i187.photobucket.com/albums/x13/fronterapics/DSC00159.jpg
https://i187.photobucket.com/albums/x13/fronterapics/DSC00158.jpg
https://i187.photobucket.com/albums/x13/fronterapics/DSC00157.jpg
Thanks
Dave
DRZ-400sm
petemell
PostPosted: 10:54 - 04 May 2008    Post subject: Reply with quote
If the sprocket shaft bearing was wearing out this would cause the front sprocket to oscillate, this may make it leak.
PostPosted: 11:02 - 04 May 2008    Post subject: Reply with quote
Thanks for the reply Thumbs Up
I have started the bike and put it into gear,and the shaft looks straight.That was including taking into 6th gear(spinning quite fast),so im fairly sure the shaft is straight,or if it is off,it is only very slightly,and barely visable.
As for the mileage,the bike has only done 23k kms,so i think it's unlikely.
However,the drive chain was a little too tight Crying or Very sad .
Thanks for the reply.
Dave
DRZ-400sm
petemell
PostPosted: 11:20 - 04 May 2008    Post subject: Reply with quote
Hi again Dave, if you just put the bike in neutral, then get hold of the front sprocket shaft with the engine turned off of course.
Can you detect any play in the shaft when you try and shake it by hand?
Or are there any clicking noises when you rotate the shaft forwards and backwards?
If this is ok it may just need another new seal.
PostPosted: 16:10 - 04 May 2008    Post subject: Re: Front sprock oil seal leaking. Reply with quote
Hi,thanks
There is movement in and out maybe 3mm ish,but not side to side.
And if i turn it while pushing it inwards,it make a clicking noise (2 clicks per full revolution),but if i pull it out as much as possible and turn it,there is no noise at all.
I know it is an oil seal,but i thought the o ring was mainly there just to stop like an oil vapour,but it looks like it fills with oil quite a bit behind there?
Thanks for your time,appreciate it Thumbs Up
Dave
DRZ-400sm
PostPosted: 22:47 - 08 May 2008    Post subject: Reply with quote
Just thought id update this thread incase anyone else has this problem with this bike.(not that anyone other than me owns a klr650 Smile )
In the pic below you can see the splined shaft where the front sprocket fit's on.
The outer ring or collar on this shaft pulls off,and below it is a small o ring(oil seal).
I replaced this smaller o ring,aswell as the collar,and the outer o ring and the leak is now fixed Thumbs Up
Had a great day today,back on the road on my klr Laughing .
Been using my 100cc scooter while the klr was broke. tis a great feeling being back on a real bike Twisted Evil
DRZ-400sm
There is a gap of 1 year, 80 days between these two posts...
UB3ER
PostPosted: 01:15 - 28 Jul 2009    Post subject: Reply with quote
did you have to split the cases bro?
PostPosted: 10:43 - 28 Jul 2009    Post subject: Reply with quote
Nope.
The o-ring just pulls out and the new one pushes in.Quick and easy 5min job Thumbs Up
DRZ-400sm
UB3ER
PostPosted: 16:20 - 28 Jul 2009    Post subject: Reply with quote
is the oil seal with a lip or not ? o_O cuz mine with a lip
The last post was made 17 years, 50 days ago. Instead of replying here, would creating a new thread be more useful?
Debug Mode: ON - Server: birks (www) - Page Generation Time: 0.07 Sec - Server Load: 0.89 - MySQL Queries: 13 - Page Size: 60.92 Kb
